#1597 |
Drives: 2013 BRZ Limited
Just noticed this one yesterday. But it wasn't there at the end of the day...
[ame]http://youtu.be/OoLo3712hC4[/ame] Sent from my SAMSUNG-SGH-I337 using Tapatalk |
#1598 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
Also using a cogged pulley the 21mm (recommended) between the plate and under the bolt would be too loose and will give you a lot of belt wobble/play. It will need a bit more based on my experience in installing the kit. BTW: The more tension the more whine, so play with the tension a little bit until you hit your sweet spot. |
#1599 | |
Drives: 1st RBv2 10 Series FRS
Thx I'll give that a try, I'm using the smooth idler pulleys. Cogged ones have yet to come in. Sent from my iPhone using Tapatalk |
#1600 | |
I think this applies to @NCItaly as well... |
#1601 |
Drives: frs
normal?
Can someone tell me if this sound normal?
[ame]http://youtu.be/C7EoFF5z7vo[/ame] |
#1602 |
#1603 |
Drives: frs
what about now? I think i forgot to hit publish
#1604 |
All of it sounds the same
#1605 |
Check your belt tension guys... sounds a little too much tension. And make sure that the cogged belt does not bounce to much up and down.
Correction if the belt moves to much then you have to add more tension and that sound will go away as well. |
#1606 |
Drives: 2022 BRZ Limited
That's what I thought too since the first time I had a similar noise, the tension was not enough (belt was a bit loose) once the tension bolt is set to ~21mm it should go away
#1607 |
Drives: Whiteout FR-S, Evo 8 RS
#1608 |
Kraftwerks Supercharger Owners Thread
Mine was set to 22mm with smooth pulley. Set it to 21mm spec, still has same noise. Should I tighten more ??, the belt does not move at all.
#1609 |
Would wait for @KraftWerks to chime in on that so there aren't any warranty issues...
Sent from my SGH-M919 using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#1610 | |
Also have you re-check the torque on all the idler pulley's. |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
