Old 06-20-2014, 08:35 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
Adjust camber/caster from top or bottom?
Looking at purchasing a set of Bilstein, (without top hats) and it's got me a little stumped as to whether to get a top hat or a lower control arm.
Pros for getting the LCA instead of a top hat
Much more adjustment range
Roll centre correction
Replaces the soft oem lca bushings
Price wise they work out about the same for me. Arguably the lca option is cheaper, because if I went top hat, I'd still have some lca bushings to replace.
So is there a more technical reason as to whether camber and caster should be made from either the top or bottom?
diss7 is offline   Reply With Quote
Old 06-20-2014, 08:43 PM   #2
Malt
Drives: 2015 WRX
If I'm not mistaken adjusting from the top hat messes with SAI, which is the less ideal choice.
Malt is offline   Reply With Quote
Old 06-20-2014, 09:02 PM   #3
RBbugBITme
Drives: S60R/Corvette
I would lean more toward taking advantage of adjustable camber AND caster so I vote upper mount.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
Old 06-20-2014, 09:03 PM   #4
Malt
Drives: 2015 WRX
You can do that from lower control arms.
Sent from my SCH-R970C using Tapatalk
Old 06-20-2014, 09:09 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
Enjoy
The Following User Says Thank You to Calum For This Useful Post:
diss7 (06-20-2014)
Old 06-20-2014, 09:11 PM   #6
RBbugBITme
Holy shiza, you guys really do have a badass platform with the LCA designed the way it is. I had to google that one.
Well then its a trade off of LCA bushing or upper mount compliance until you replace both. It probably doesn't really matter when considering (I assume) a mostly street driven car so get the LCA and forgo the aftermarket bushings and then get the upper mount when you can afford it later. It looks like the LCA will allow you to correct your RC when you lower it too.
Ryan M.
Strange Engineering
The Following User Says Thank You to RBbugBITme For This Useful Post:
Malt (06-20-2014)
Old 06-20-2014, 09:26 PM   #7
RBbugBITme
Originally Posted by Calum View Post
Unfortunately that data means very little without camber gain in roll. Obviously you will never see zero roll when iterating through various steering scenarios.
Ryan M.
Strange Engineering
Old 06-22-2014, 08:59 AM   #8
wparsons
wparsons's Avatar
Doesn't matter if you're adjusting from the LCA or the upper mount, the effect on SAI is the same.
The only way to add front camber without messing with it is at the knuckle (camber bolts, slotted struts)
flickr
Malt (06-22-2014)
Old 06-22-2014, 10:03 AM   #9
RBbugBITme
And I guess you'll need an alignment if you adjust via LCA.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Ryan M.
Strange Engineering
Old 06-22-2014, 10:55 AM   #10
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I highly recommend top hats. Do NOT buy the Whiteline ones. They pulled them do to many problems.
Unfortunately, many vendors are still selling them.
Currently, HVT would be your best bet for a top hat.
Not sure what your setup is. I'm on Konis with Eibach Pro Kit Springs.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 06-22-2014, 03:42 PM   #11
wparsons
wparsons's Avatar
You'll need an alignment either way. Changing camber will change toe.
flickr
Old 06-22-2014, 04:03 PM   #12
RBbugBITme
I'm talking minor changes at a track event. Moving the lower pivot which also changes your track width would probably have a more drastic effect on toe.
Ryan M.
Strange Engineering
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 01:21 AM
Caster, SAI, Steering and Camber Wepeel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 02-24-2015 08:09 PM
Raceseng | Billet Aluminum Caster Camber Plates Raceseng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 162 12-29-2014 10:32 AM
HVT vs Raceseng Caster Camber Plates? Phaedrus29 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 12-22-2014 05:34 PM
The proper way to adjust camber independently? Cheeseballs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-27-2013 08:03 PM
