Old 05-31-2014, 11:17 AM   #1
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Shifter rattle WOT over 4500rpm
Basically my car is making this noise
[ame="https://www.youtube.com/watch?v=9d5rIBnwQrQ"]Toyota 86 shift knob rattle - YouTube[/ame]
In 2nd over 4500rpm under WOT, no idea what's making it car has 21000km on it. Anyone else had this noise?
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
The Following User Says Thank You to Khorne For This Useful Post:
ZionsWrath (05-31-2014)
Old 05-31-2014, 11:26 AM   #2
jibai
Drives: frs
I noticed rattling noise in my shifter also but then I figured out it was a loose shift knob. Tightened it up and it solved it for me
jibai is offline   Reply With Quote
The Following User Says Thank You to jibai For This Useful Post:
Old 05-31-2014, 11:31 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
I didn't hear a noise, mine vibrates if you hold it loosely but my girl says she doesn't mind
wait wut
The Following 3 Users Say Thank You to ZionsWrath For This Useful Post:
Purdue FR-S (06-19-2014), SportInjected (05-31-2014), Sportsguy83 (07-03-2014)
Old 06-01-2014, 01:28 AM   #4
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
I was able to replicate the noise slightly by putting the car into 2nd while off and wiggling the gearstick back and fourth fast.
Then i went for a drive tried to see if it would make it in 3rd as well, and it was fine in 2nd and 3rd, No idea why but its not doing it anymore.
Build thread
Old 06-03-2014, 01:26 AM   #5
jibai
Drives: frs
MAGIC!
Old 06-03-2014, 01:32 AM   #6
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by jibai View Post
MAGIC!
I wish, its come back but a lot quieter in 2nd, still above 5Krpm.
I do remember dropping a bolt down there while doing my vinyl work on my shifter surround so that might be it.
I'm going to get under the car next week, change the diff and tranny oil and have a look around.
Build thread
Old 06-03-2014, 01:42 AM   #7
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
My second one did it in every gear once past 4k rpm. I'm am now on my third shift lever.
Old 06-18-2014, 08:30 AM   #8
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Mine rattles just like that... Is this the adequate fix? http://www.ft86club.com/forums/showthread.php?t=50512
Guillaume is offline   Reply With Quote
Old 06-18-2014, 08:37 AM   #9
boredom.is.me
Custom User Title
When I replaced mine, the tech told me that there was a TSB for the rattle. My third one so far hasn't rattled, but I haven't even hit the 500 mile mark with it.
Old 06-19-2014, 08:49 PM   #10
KayC
Drives: 2013 whiteout FRS 6mt
I have the exact same issue.
Try holding your reverse lockout and push it to the side and see if it happens. I find out it's the metal piece in the shift rod that the reverse lockout pin is screw into. At high rpm the metal piece is knocking on the side of the rod.
If you take off your reverse lockout you will know what I mean.
KayC is offline   Reply With Quote
Old 06-19-2014, 09:32 PM   #11
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Mine rattled very slightly. The lockout had some play in it, causing vibrations at high RPM and a Fast and Furious-esque "snick" sound while shifting gears. After wrapping teflon tape and lubing with white lithium grease, the noises are all gone.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 06-19-2014, 09:58 PM   #12
Lonewolf
Lonewolf's Avatar
Drives: Moped
When I first saw the thread I thought the title said "Shitter rattle WOT..." I thought you had just gone to Chipotle or something
Old 06-20-2014, 10:45 AM   #13
tobin
tobin's Avatar
Drives: '13 BRZ
There is a TSB for this. Bring your car back to the dealer and they will take care of it. My dealer confirmed the noise a couple of days ago and has ordered the new shifter assembly. It is a revised part, I believe it is an entire new shifter assembly that they replace.
tobin is offline   Reply With Quote
Old 06-20-2014, 10:50 AM   #14
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Would you happen to have a copy of the Subaru TSB so that I can show it to my dealer? The Scion TSB has (understandably) Scion part #s on it, so it doesn't help my Subaru dealer getting the right parts (it appears there is no TSB for that in Europe, yet).
Audible shifter rattle Hanzo Issues | Warranty | Recalls / TSB 134 08-17-2022 03:34 AM
Shifter Rattle and Replacement boredom.is.me Issues | Warranty | Recalls / TSB 19 04-27-2015 05:29 PM
2014 Shifter Rattle becauseracecar1 Issues | Warranty | Recalls / TSB 1 05-24-2014 07:06 PM
BRZ Shifter Rattle TSB sc0urge BRZ First-Gen (2012+) — General Topics 2 08-26-2013 09:53 PM
Loud rattle, lots of shaking from shifter...not the knob...its the trans linkage continuecrushing Issues | Warranty | Recalls / TSB 8 05-18-2013 12:56 PM
