Old 06-19-2014, 07:17 PM   #57
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
also one little thing to add, the last time I checked a v8 swap from Flyin Miata cost about $42k since you cannot simply change the engine and Ecu
Here is a complete list of the parts that need to be changed for those who are interested :
http://www.flyinmiata.com/V8/turnkey.php
glamcem is offline   Reply With Quote
Old 06-19-2014, 07:34 PM   #58
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Originally Posted by Malt View Post
A fully dressed LS3 weighs 418 lbs. I don't know the exact weight of a FA20 but it cant be significantly less than that. Adding at most 30-40 lbs (and I'm being VERY generous here) to the front of the car isn't going to make it handle like a truck.
EDIT: Also, I'd say that 430hp/430lbft is WELL worth the tiny bit of added weight while staying NA and have an essentially bullet proof engine.
Well...I stand corrected. It may well be light. Idk how much the FA engine weighs. But if it's similar, then your points are good and I agree.. having that much NA power would def be awesome.
fooddude is offline   Reply With Quote
Old 06-19-2014, 11:52 PM   #59
Poodles
Drives: 2015 Series.Blue
Keep in mind that they're not using used parts at all, there's a lot of fluff added to that, and you're paying all the labor.
It's a hell of a lot cheaper than that to do the swap in reality, they just overbuild it because their name is on it.
Now to answer the original question in the thread, because it's STILL CHEAPER than buying a Ferrari or high end Porsche, etc. Not to mention making those people cry when they can't keep up.
The Following User Says Thank You to Poodles For This Useful Post:
andrew20195 (06-20-2014)
Old 06-20-2014, 12:35 AM   #60
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Found this on the FRS Enthusiast FB page today. Dunno if it's been posted here but I think it's relevant:
For those of you that say that the V-8 swap ruins the FRS, here is my final corner balance: LS2 fully built, T 56 transmission, full interior, 17 X9 .5 wheels, 275 drag radials, and Optima battery in the passenger rear of the trunk. I'm pretty sure when my car was turbo it was almost this heavy. — at Pure Automotive Performance.
Jyn is offline   Reply With Quote
Old 06-20-2014, 02:16 AM   #61
fooddude
56:44 F:R weight ratio... not bad and pretty impressive actually
Looks like a super tight fit...modified firewall too?
Is the LSx motor actually lighter than a 2JZ or RB engine or 3-4 rotary engine?
Old 06-20-2014, 02:18 AM   #62
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by jsimon7777 View Post
Why have plain sex with a model when you can hire a cheap prostitute, dress up in a bear suit, and bring in some chains? Different strokes.
Had to quote this in my sig. Gold sir, pure gold.
1974 TA22 Celica
2013 86 GT
Old 06-20-2014, 07:34 AM   #63
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
How does anyone explain the "need" to modify (improve) cars from the way they left the factory? Fact is modding/tuning/hopping up/ricing (choose term based on your point of view) is a huge part of the automobile culture and has been for decades. Whether you like it or not this forum would not exist without the advertising funds generated by companies that service the modding industry.
All that said, a motor swap seems to be highly impracticle compared to tune/bolt-on and FI choices that are proven reliable on the stock motor. But I do get the novelty aspect and hats off to those who pave the trail.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 06-20-2014, 08:18 AM   #64
Malt
Drives: 2015 WRX
Originally Posted by Jyn View Post
Numbers copied over from photo of LS2, T56 trans, full interior, 17*9.5 wheels, 275 drag radials, and optima battery in the passenger rear of trunk FRS.
LF: 827 RF: 815
LR:630 RR: 647
2919lbs total
When I had my BRZ corner balanced here were the final figures.
LF: 773 RF: 759
LR: 607 RR: 603
2742lbs total.
Granted I've done some small weight reduction mods, I was on stock wheels and tires. There's a slight difference in weights between premium and limited models as well (I have a premium). 177lbs difference with an LS2 and 9.5 wide wheels and drag radials is actually quite amazing.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
fooddude (06-20-2014)
Old 06-20-2014, 08:53 AM   #65
Mooseknuckle44
Mooseknuckle44's Avatar
430hp/430tq.......MUSTANG MURDERER!!!.
God I'd love to be at the drag strip for that shelacking. Just to see all the fanboys faces.....
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Mooseknuckle44 is offline   Reply With Quote
Old 06-20-2014, 02:07 PM   #66
fooddude
Ya....in a tiny lightweight little car no less, lol. Mustang V8 weighs 3500-3800..almost 1k lb difference! wow.
Idk if I'd be down to put a domestic engine in the twin tho... I think I'd rather put a 2JZ or Rotary engine in it lol. But, don't get me wrong....NA is always best...especially 430 NA hp
Old 06-20-2014, 03:06 PM   #67
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
A guy named Turdinator is a fan. Yay...
Old 06-20-2014, 03:08 PM   #68
J_kennington
Drives: 2013 asphalt scion FRS
So...now your OK with engine swaps? I'm confused...
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 06-20-2014, 03:33 PM   #69
cf6mech
Drives: FRS Silver LS1 swapped.
FA20 weighs exactly 480lbs engine and transmission that's a lot of weight/complexity/moving parts for a measly 200bhp in a modern day engine.
cf6mech is offline   Reply With Quote
Old 06-20-2014, 03:46 PM   #70
Poodles
LS motor is lighter than a 2JZ-GTE with everything else needed to run it (turbos, intercooler, etc)
Lots of cast iron there...
After the "Ferrari" 86, we now have the "Porsche" BRZ Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 30 07-06-2013 11:41 AM
Portland people meet with Seattle area people before going into ForumFest 2013? stockysnail Northwest 24 06-18-2013 06:19 PM
First spotting in the wild! pr0j AUSTRALIA 3 07-22-2012 03:48 AM
Official: The new Ferrari V12 Ferrari Berlinetta Levi Other Vehicles & General Automotive Discussions 27 03-07-2012 11:31 PM
First Ferrari, now Porsche??? zoomzoomers Other Vehicles & General Automotive Discussions 33 02-26-2012 11:45 AM
