Old 02-29-2012, 08:04 AM   #1
Levi
Drives: Toyota
Official: The new Ferrari V12 Ferrari Berlinetta
Presenting the all-new 6262cc V12 Ferrari Berlinetta
Maranello, 29th February 2012 – Today’s on-line unveiling of the F12berlinetta ushers in a new generation of Ferrari 12-cylinders in the form of a car that delivers unprecedented performance from an exceptional new engine, combined with innovative design that redefines classic themes along with extreme aerodynamics.
Revealed to the world for the first time on Ferrari.com in preparation for its official debut at the Geneva International Motor Show, the F12berlinetta, finished in an attractive new Rosso Berlinetta three-layer colour, represents the very cutting-edge of mid-front-engined sports cars.
This is, in fact, the most powerful and high-performance Ferrari road car ever launched thanks to the incredibly efficient engine – in terms of mechanical, combustion and fluid-dynamics efficiency – which, together with advanced vehicle architecture, aerodynamics, components and electronic controls, guarantee unsurpassed driving involvement whatever the road or track.
Ferrari’s traditional transaxle layout has been revolutionised to match the more extreme performance of the car. The wheelbase has been shortened and the engine, dashboard and seats have been lowered in the chassis, while the new layout of the rear suspension and gearbox enabled Ferrari’s engineers to make the rear volume of the car smaller. The overall result is a very compact car with a lower centre of gravity that is further back in the chassis, and a level of aerodynamic efficiency that sets new standards.
Scaglietti, renowned for its expertise in aluminium materials and construction, designed an all-new spaceframe chassis and bodyshell using 12 different kinds of alloys, some of which have been used here for the first time in the automotive sector, and employing new assembly and joining techniques. This has resulted in a 20 per cent increase in structural rigidity while reducing weight to just 1525 kg (70 kg less than the previous V12 coupé) with an ideal distribution between the axles (54 per cent over the rear).
The F12berlinetta’s 6262cc 65° V12 engine delivers unprecedented performance and revs for a naturally-aspirated 12-cylinder. Its maximum power output is 740 CV which translates to a specific output of 118 CV/l. Torque reaches a peak of 690 Nm, 80 per cent of which is already available at just 2,500 rpm, and which provides an unrelenting surge of acceleration all the way to the 8,700 rpm limit. The engine is mated to the F1 dual-clutch transmission, which has closer gear ratios developed specifically for this car’s performance. The F12berlinetta boasts a weight-to-power ratio of just 2.1 kg/CV .
Fuel consumption has been reduced by 30%, with CO2 emissions of just 350 g/km – figures which put the F12berlinetta at the top of the high-performance league. These results have been obtained by extensive research and development which focused on efficiencies of the whole vehicle: engine, aerodynamics, tyres and weights.
Similarly excellent results have been obtained with the car’s aerodynamic development, thanks to the integration of the design process with extensive computational fluid dynamics (CFD) simulations and lengthy testing in the wind tunnel. Downforce has been boosted by 76 per cent (123 kg at 200 km/h) while drag has been significantly reduced (the Cd is just 0.299). These results come courtesy of two new solutions. The first of these is the Aero Bridge which uses the bonnet to generate downforce by channelling air away from the upper part of the car to its flanks where it interacts with the wake from the wheel wells to decrease drag. The second is Active Brake Cooling, a system that opens guide vanes to the brake cooling ducts only at high operating temperatures, again reducing drag.
The F12berlinetta’s impressive technical specifications are completed by Ferrari’s latest generation carbon-ceramic brakes (CCM3) and the evolution of the magnetorheological suspension control system (SCM-E). As is now traditional with all Ferraris, its control systems (E-Diff, ESC, F1-Trac, and high-performance ABS) are all fully integrated.
The result is that the new Prancing Horse 12-cylinder accelerates from 0-100 km/h in 3.1 seconds and from 0 to 200 km/h in 8.5 seconds. It also completes a lap of the Fiorano circuit in 1’23”, faster than any other Ferrari road car. Benchmark performance and maximum driving involvement are guaranteed by immediate turn-in, with smaller steering wheel angles, and increased cornering speed. Stopping distances have also been drastically reduced.
The design of the F12berlinetta is a result of the collaboration between the Ferrari Styling Centre and Pininfarina and is a perfect balance of uncompromising aerodynamics with harmonious proportions interpreting the typical elements of Ferrari’s front-engined V12 cars in an original and innovative way. A coupé with sleek, aggressive lines whose compact exterior dimensions conceal exceptional in-car space and comfort. The all-new Frau leather interior highlights the balance of advanced technology and sophisticated, handcrafted detailing. In the middle of the light and lean dashboard, there are new carbon fiber and aluminium airvents clearly inspired by the aeronautic field.
The cabin has been optimised to ensure maximum usability of the interior space with additional luggage capacity behind the seats, which can also be easily reached thanks to the large aperture offered by the tail-gate. With the ****pit designed around the driver, typical of all Ferraris, the Human Machine Interface approach is emphasised, grouping all the major commands within immediate reach to guarantee maximum ergonomics for the most involving driving experience.
TECHNICAL SPECIFICATIONS:
Engine
Type 65-degree V12
Total displacement 6262 cc
Maximum power output 740 CV at 8500 rpm
Maximum torque 690 Nm at 6000 rpm
Dimensions and weight
Length 4618 mm
Width 1942 mm
Height 1273 mm
Dry weight* 1525 kg
Weight distribution 46% front, 54% rear
Weight-power ratio 2.1 kg/CV
Performance
Maximum speed over 340 km/h0-100 km/h 3.1 seconds
Fuel consumption and emissions (ECE + EUDC combined cycle)
Consumption** 15l/100 kmCO2** 350 g/km
*With lightweight options
**With HELE System
Levi is offline   Reply With Quote
Old 02-29-2012, 09:00 AM   #2
Grateful Dave
2nd 86 member
Grateful Dave's Avatar
Drives: 2013 Asphalt AT FR-S
Looks awesome! I wish I could own this Prancing Horse. Doesn't it remind you of another car that some of are interested in? Could it be it looks like the FR-S/GT86? I think so. More of the concept version of the FR-S. Either way I like this F12 Berlinetta but I also like the the FR-S. I can't afford the F12 but I can afford the FR-S. I can't wait to get my FR-S!!!
Grateful Dave is offline   Reply With Quote
Old 02-29-2012, 09:23 AM   #3
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
That side view is hideous. Everything else is okay...
No doubt it'll be fast though...
- The Ancient BRZ Sacrament
by Zaku
Old 02-29-2012, 09:39 AM   #4
Chupacabra
'it's the yeti of Texas'
Chupacabra's Avatar
Drives: 2013 Whiteout 6MT FR-S
If I see this car out in the open in a few weeks, I'll get a photo of it when I'm in Maranello and post it up here.
BRZerhood & FR-Society
Chupacabra is offline   Reply With Quote
Old 02-29-2012, 09:53 AM   #5
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
I think it looks good. Just don't like the interior. Too busy looking.
tranzformer is offline   Reply With Quote
Old 02-29-2012, 10:22 AM   #6
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
I think it doesn't look that good just ok and too much is going on for the steering wheel. Can't wait to see how fast it goes though.
Old 02-29-2012, 10:35 AM   #7
Longhorn248
Hook 'em
Longhorn248's Avatar
I love the steering wheel and digital gauges.
Longhorn248 is offline   Reply With Quote
Old 02-29-2012, 10:44 AM   #8
LSxJunkie
LSxJunkie's Avatar
Drives: Car
I love it. Front end off the FF, greenhouse from a 575, back end from an Alfa 8C.
LSxJunkie is offline   Reply With Quote
Old 02-29-2012, 11:50 AM   #9
CSSM
Still Dreamin'
CSSM's Avatar
Drives: 2001 Chevrolet Tahoe
What's with the Iphone on the rear?
CSSM is offline   Reply With Quote
Old 02-29-2012, 11:58 AM   #10
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
Oh Ferarri, your interiors make me feel like I'm looking at the ****pit of a fighter jet.... a luxury fighter jet.
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
Old 02-29-2012, 12:06 PM   #11
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
Love the red and sinister smile,its nice :-D
Old 02-29-2012, 12:21 PM   #12
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Damn. I love how it's smaller than the 599. 182" long and only 50" tall with a weight of only 3355lbs....with a million HP at a million RPM. Kudos to Ferrari. It even looks good.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 02-29-2012, 12:27 PM   #13
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
I wonder what 0-60 in 3.1 seconds even feels like on the street...
Old 02-29-2012, 03:13 PM   #14
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Reverse light. It's supposed to recall the brake light of the F1 cars.
Ferrari 620 leaked DIG1992 Other Vehicles & General Automotive Discussions 28 02-29-2012 01:05 PM
FRS vs Ferrari 250 GT Lusso mrybczyn FR-S / BRZ vs.... 16 02-27-2012 08:34 PM
First Ferrari, now Porsche??? zoomzoomers Other Vehicles & General Automotive Discussions 33 02-26-2012 11:45 AM
Ferrari is a cheater? Dark Other Vehicles & General Automotive Discussions 18 11-11-2011 06:26 PM
Ferrari 458 style rims CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 20 04-13-2010 11:20 PM
