Old 06-19-2014, 01:05 PM   #29
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Originally Posted by malave7567 View Post
One comment, it irks me when someone refers to an LSx engine as a huge engine just because they see the liters number... It's not very big at all. In fact, it doesn't really add much weight at all. Cam-in-block may be considered "old tech", but it allows the engine to remain compact and aluminum block keeps the weight down. Fully dressed weight of the LS3 with all accessories on it (as configured in a C6 vette) is around 450 lbs. and not much bigger a package than an I4, just wider, which is why it can be swapped into virtually anything.
This pic is very misleading. The engine on the left has full accessories/alternator/thermo/pulleys/etc bolted on, full intake manifold fuel delivery and tb, valve covers, etc., etc. Take all that off and it'll look like an Ethiopian child next to that V8, maybe 2-3x smaller, lol.
The one on the right is basically a naked engine. No valve covers, no intake manifold fuel delivery tb's, no acc/alt/thermo/belts/pulleys, it's also missing the very lower portion of the block oilpan case and the crankshaft cradle/girdle (once you add all that, that's at least another .5' of engine height).
fooddude is offline   Reply With Quote
The Following 2 Users Say Thank You to fooddude For This Useful Post:
Ammonia (06-21-2014), DriftinFRS (07-06-2014)
Old 06-19-2014, 01:20 PM   #30
Mooseknuckle44
Mooseknuckle44's Avatar
I'm thinkin a stroked twin turbo'd Busa engine. Could you imagine the looks you'd get when you bumped the limiter on that at a meet?
LMAO!!
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Mooseknuckle44 is offline   Reply With Quote
The Following User Says Thank You to Mooseknuckle44 For This Useful Post:
fooddude (06-19-2014)
Old 06-19-2014, 01:23 PM   #31
fooddude
Originally Posted by Efferalgan View Post
I can buy a Corvette, F-type S, Boxster GTS, M4 etc in addition (because I can’t imagine selling it and anyway it costs less than 25% of any of the above mentioned cars) to my GT86 without much trouble to my budget but my Hachiroku keeps the “car enthusiast” part of me so satisfied for over 1.5y already because of the never ending tuning process, so I simply don't want another "toy" car. So, despite money spent on GT86’s tuning on literally weekly basis, it effectively saves me from buying new, much more expensive "amusement" cars – like methadone therapy instead of heroine
Yes, I enjoy tuning too. Especially a car like this. And great points.
I guess I'm just saying that I am kinda against disrupting the weight balance and cog of this car by plopping a big motor in it. Also kinda against ruining the great handling/suspension engineering behind it.
Now, if it was a different car, especially like a classic car with old engineering that handles like crp anyways and is nowhere as good as a modern car (like a 240z, a 510, etc), then I am totally all for it. But ruining a modern and very well designed chassis is kinda funny to me. (kinda like plopping a V8 in a porsche lol)
Old 06-19-2014, 01:45 PM   #32
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
Good observation, and I figured most knowledgeable of engines could look at just the engines themselves. Yes, the I4 will look skinny as heck next to the v8, but the height is, like you said, only .5" to 1.0" once the LS is in full trim (especially since in ours cars, you would be using a custom shallow pan/dry sump system). I agree with what you said. If it fits in a low hood-line car like ours... it has no problem fitting in almost anything that has the width necessary for the V.
So for info, I will post with more trim. No A/C, but hey, screw A/C.
malave7567 is offline   Reply With Quote
Old 06-19-2014, 01:47 PM   #33
J_kennington
Drives: 2013 asphalt scion FRS
Have you rode on a properly set up swapped frs? How do you it will magically make the car handle like crap? You talked about constant reliability issues...what about any modified car? Seen the thread of the boosted frs on here where the owner said they were in the shop every week or two to fix something else? Taking a perfect running motor, putting it a different car...will still be a perfect running stock motor. With the same power as a modified fa20, that WILL have issues.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 06-19-2014, 01:47 PM   #34
malave7567
malave7567's Avatar
Rotary sounds sexy!
I miss my old one
Old 06-19-2014, 01:55 PM   #35
jdm-az-fuk
Drives: 2013 Fr-S
I will never forget the day that I beat a turbo gallardo in my 4 cylinder turbo integra.
jdm-az-fuk is offline   Reply With Quote
The Following User Says Thank You to jdm-az-fuk For This Useful Post:
Old 06-19-2014, 01:57 PM   #36
Mooseknuckle44
Then changed the settings on Forza from rookie to novice.
Old 06-19-2014, 02:08 PM   #37
sluflyer06
Drives: 2014 BRZ Ltd - DGM
That pic seems to give evidence to those your using it to disprove. That almost naked LS1 with no accessories, no valve covers, no intake manifold or anything is already almost as big as that fully dressed Mazda motor.
Now for sure many people assume a V8 swap is going to weigh much more, when typically the difference is not so much..at least considering the engine itself..not sure how those swaps always end up after transmission, sub frame stuff, rear end, etc
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
The Following 2 Users Say Thank You to sluflyer06 For This Useful Post:
Ammonia (06-21-2014), fooddude (06-19-2014)
Old 06-19-2014, 02:17 PM   #38
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I will be doing something like this to a 1989 Mazda rx7 hopefully. The one and only vanity plate I have ever liked was on an rx7 and it said "Rotorless".
It makes the car unique and it can be a challenge which requires true skill (and loads of engineering and math) to make a functional car. Next level Shiz compared to buying and bolting on parts.
GotBRZ1691 is offline   Reply With Quote
The Following 2 Users Say Thank You to GotBRZ1691 For This Useful Post:
fooddude (06-19-2014), malave7567 (06-19-2014)
Old 06-19-2014, 02:19 PM   #39
fooddude
I said foot, not inches ...and that's in comparison to that standard tall i4 in the pic.
Now, compare that to our short, flat, boxer 4.. even worse of a difference in height.
After swapping in that LSx... there goes the Twin's wonderfully super low COG out the door
Old 06-19-2014, 02:20 PM   #40
malave7567
malave7567's Avatar
I did specifically say, if it has the width for the V right? My main point being the overall height/weight of the engine stays relatively the same in a lot of cases, which will not kill the balance of a car. Of course the LS is a bigger package, but its mostly different in width, not height, so you're not killing the COG/balance on most cars. Maybe a little on ours since its a flat-4. Sorry if I didn't word it correctly. The valve covers and intake manifold aren't exactly huge (and the intake is plastic, so its a light piece too).
Sorry, I will stop de-railing this thread now. lol
Old 06-19-2014, 02:21 PM   #41
malave7567
malave7567's Avatar
yup, I agree with you on the twins, it loses it's super low COG. But then i heard one with the swap, and I fall back in love with it lol
Old 06-19-2014, 02:33 PM   #42
fooddude
No I haven't.
Maybe it won't make it handle like super crap... but it won't have the same nice low COG anymore and you'll need to do months of study, research, development, testing and tuning of all suspension parts to make everything handle good after having new weights and positioning of the new engine.
Yes I agree, that is true of any modified car, original engine or not. But, a swapped stock motor won't necessarily be trouble free. Maybe it will be very reliable internally...but, there will still be probable issues down the road/build with mounts or design, positioning and fitment, chassis mods, drivetrain, engine harness and electrical, ecu, etc., etc.
After the "Ferrari" 86, we now have the "Porsche" BRZ Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 30 07-06-2013 11:41 AM
Portland people meet with Seattle area people before going into ForumFest 2013? stockysnail Northwest 24 06-18-2013 06:19 PM
First spotting in the wild! pr0j AUSTRALIA 3 07-22-2012 03:48 AM
Official: The new Ferrari V12 Ferrari Berlinetta Levi Other Vehicles & General Automotive Discussions 27 03-07-2012 11:31 PM
First Ferrari, now Porsche??? zoomzoomers Other Vehicles & General Automotive Discussions 33 02-26-2012 11:45 AM
