Old 06-19-2014, 12:16 AM   #1303
d4wt
d4wt's Avatar
Drives: a couple + an frs
looks like im going to have to join the oft club. i've had unichip installed since the third week of owning my car and was hoping that the development wouldn't have died off completely. especially after installing bpb's and seeing no support at all for them other than hearsay.
no offense to jack of course, i've been a supporter of unichip for a very long time. i had one installed on my mazdaspeed protege back in the day. i think they have a great place depending on what you're trying to accomplish but for frs/brz/gt86 owners, going with the oft is a no brainer.
d4wt is offline   Reply With Quote
The Following User Says Thank You to d4wt For This Useful Post:
Shiv@Openflash (06-19-2014)
Old 06-19-2014, 11:00 AM   #1304
phrosty
Originally Posted by edeekeos View Post
Also, my ABS light and traction control symbol seem to be appearing at random when data logging. At least it seems random, I tried braking hard, and breaking the tires loose and it didn't do it every time. Not sure what would be causing this, but it has only happened when data logging?
This isn't normal behavior.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
DC2R (06-19-2014)
Old 06-19-2014, 11:48 AM   #1305
Leapo
Drives: 2013 Scion FR-S AT
Originally Posted by shiv@vishnu View Post
What isn't working well with the touchscreen? Touch accuracy? If so, try re-calibrating the screen. It will fix that up right away.
It just didn't seem to want to respond at all. I could hit what I wanted, but I have to press rather hard.
I'll go ahead and try calibrating it. I'll let you know if it helps or fixes it.
Originally Posted by Danklvr View Post
what version factory tune / cal ID was on your car before you went stage 1?
If you are on the newest B01c/d series rom, dealer will have no need to plug in and update ECU.
If you are on an older version, and request the update for lets say.... AC idle dip TSB, then yes, deff flash back to stock first, let em flash newest ROM, - re-marry OFT and flash stg 1 back.... unneeded though, as all the new OTS maps are based on the new roms.
Yeah, they shouldn't have any reason to touch the ECU, but I'll probably flash back to stock just to be totally safe.
Is flashing the stock ROM back to the car enough to "un-marry" the OFT from the car, or is there something further I need to do?
Leapo is offline   Reply With Quote
Old 06-19-2014, 12:01 PM   #1306
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Definitely sounds like the screen is out of calibration. So calibrating it in the calibration menu will definitely do the trick. Just make sure you use a stylus for this step so it calibrates properly. From that point onwards, you can use your fingers.
To un-marry the OFT, just flash back to stock first. Then connect the OFT to OF Manager (with WIFI connection) and go to Erase Data and click on START. At that point, your OFT will be like new again and ready for installation in the same (or another) car. That's it
Shiv@Openflash is offline   Reply With Quote
Old 06-19-2014, 12:15 PM   #1307
GhostShield
Drives: 2013 silver FRS
OFT has been the best 500$ I've spent on the FRS!! Only running OTS stage 1, but the car is way more responsive, I love how the idle holds steady at 700-900 RPMs, I hated the stock idle and it would always dip and fluctuate from the shitty ass stock tune!
Car def pulls harder! Can't wait to try UEL stage 2 when my header arrives
Thanks shiv!
GhostShield is offline   Reply With Quote
The Following User Says Thank You to GhostShield For This Useful Post:
Old 06-19-2014, 12:16 PM   #1308
GhostShield
Shiv@vishnu
Old 06-19-2014, 12:21 PM   #1309
Shiv@Openflash
Drives: 2013 FRS
Thanks shiv!
That's great to hear! All of us here at Vishnu are thrilled with the positive feedback we have been getting from this community
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Cross (06-21-2014)
Old 06-19-2014, 12:22 PM   #1310
Shiv@Openflash
Drives: 2013 FRS
Hi Guys,
Received my OFT today! Everything has been super smooth thus far, FT's, and AFR are well within spec. Running the e85 tune, and 'WOW' doesn't even describe this thing. I feel like I unleashed the beast inside. It pulls like a f'kin banshee now! No longer does it feel 'tired' towards the redline. It pulls super hard all the way through and the torque dip' is WAY less noticeable. Really happy with this device. It improved the feel of this car, ten fold.
My only qualm is the valve-train noise around the 3500-4000 region. But I guess that's just the nature of the beast, and the revised VTT mapping. Also, my ABS light and traction control symbol seem to be appearing at random when data logging. At least it seems random, I tried braking hard, and breaking the tires loose and it didn't do it every time. Not sure what would be causing this, but it has only happened when data logging?
Old 06-19-2014, 12:27 PM   #1311
driftu
driftu's Avatar
Drives: 13 FR-S: Raven
OFT Customer Receipt #16137172 haha! E85 less than a block from home. Also, police and state patrol stations
driftu is offline   Reply With Quote
Old 06-19-2014, 12:39 PM   #1312
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by cnk View Post
It has the OEM updates applied to the tunes and an increased idle of about 900rpm so you shouldn't experience those issues unless it's a mechanical issue.
Running e85 Stg2 and my idle fluctuates ~150-200 rpm. Maybe I should re-download and apply the Tune again?
Old 06-19-2014, 12:51 PM   #1313
cnk
Drives: '13 DGM BRZ Limited
Worth a shot, you always want to try to run the latest tune released as it has the most recent updates. Read the notes that come with each tune version as maybe you're running an older tune that didn't have the updates yet. Also, if your A/C is on, that fluctuation is normal when the compressor kicks on/off.
Old 06-19-2014, 12:57 PM   #1314
Kids Heart
Kids Heart's Avatar
Drives: 2013 BRZ Limited SWP
Thanks shiv!
Pretty much exactly what he said. I even offered a couple of my friends to try the tune for a day to convince them to go ahead and get the OFT
Kids Heart is offline   Reply With Quote
Old 06-19-2014, 01:15 PM   #1315
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
I'm gonna try to recreate the instance today, Any idea what would cause this?
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 06-19-2014, 02:41 PM   #1316
s2d4
s2d4's Avatar
pull out technique.
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
