Old 06-18-2014, 03:15 PM   #1289
spdbydesign
spdbydesign's Avatar
Drives: 2010 Nissan GTR
Speed By Design Turbo FRS Vishnu/Openflash Tuned: [ame]http://youtu.be/n2oiYP1YbWA[/ame]
spdbydesign is offline   Reply With Quote
Old 06-18-2014, 03:22 PM   #1290
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Dyno?
sent from HTC one M8 while driving
cruizin01 is offline   Reply With Quote
Old 06-18-2014, 03:28 PM   #1291
Sniper2606
Sniper2606's Avatar
Originally Posted by cruizin01 View Post
Dyno?
Wait....that's Dino.
If i have to guess i say 260ish 270ish
Sniper2606 is offline   Reply With Quote
Old 06-18-2014, 04:10 PM   #1292
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
nice job on the turbo! Anyone have idea when the 1.6 updates are coming?
calmtigers is offline   Reply With Quote
Old 06-18-2014, 05:17 PM   #1293
Leapo
Drives: 2013 Scion FR-S AT
Got my OFT a couple days ago, and I've been loving the Stage 1 tune. Very nice.
Not quite as impressed with the quality of the OFT itself, though. The touch screen is incredibly bad, and the plastic clip that holds the ODBII cable into the OFT snapped off of the tablet the first time I went to unplug it.
Is this normal, or is my unit some kind of factory fluke?
Edit: Also, I'm taking my car into the dealership to fix a scratch on my rear bumper. Should I bother flashing back to stock settings before taking it down?
Leapo is offline   Reply With Quote
Old 06-18-2014, 05:49 PM   #1294
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Same thing happened to mine. The connection seems to be just fine without the tab, I wouldn't be too concerned about it.
Old 06-18-2014, 05:53 PM   #1295
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I would say yes. Even though there is no reason to, if they hook it up and do an update without telling you, the ecu will no longer match your "married" tune, so the OFT might not recognize your car.. "I could be completely wrong though"
Target70 is offline   Reply With Quote
Old 06-18-2014, 05:57 PM   #1296
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Mine also did that on the clips after a short time. I haven't worried about it since it is secure. The touch screen may seem cheap, but trust me, you wouldn't want a nicer one as this is a much sturdier design. We have multi-million dollar machines at work that use the same type of screen for durability.
Luckrider is offline   Reply With Quote
Old 06-18-2014, 05:59 PM   #1297
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
what version factory tune / cal ID was on your car before you went stage 1?
If you are on the newest B01c/d series rom, dealer will have no need to plug in and update ECU.
If you are on an older version, and request the update for lets say.... AC idle dip TSB, then yes, deff flash back to stock first, let em flash newest ROM, - re-marry OFT and flash stg 1 back.... unneeded though, as all the new OTS maps are based on the new roms.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 06-18-2014, 08:39 PM   #1298
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
What isn't working well with the touchscreen? Touch accuracy? If so, try re-calibrating the screen. It will fix that up right away.
Shiv@Openflash is offline   Reply With Quote
Old 06-18-2014, 08:41 PM   #1299
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Choosing your datalog 'X' is the miserable part for me. Sometimes they X and sometimes they don't.
Old 06-18-2014, 08:49 PM   #1300
calmtigers
I kept the cord connected to it for that reason!
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
Old 06-18-2014, 09:25 PM   #1301
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Same, I haven unplugged it since I received it
Kronos is offline   Reply With Quote
Old 06-18-2014, 11:01 PM   #1302
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Hi Guys,
Received my OFT today! Everything has been super smooth thus far, FT's, and AFR are well within spec. Running the e85 tune, and 'WOW' doesn't even describe this thing. I feel like I unleashed the beast inside. It pulls like a f'kin banshee now! No longer does it feel 'tired' towards the redline. It pulls super hard all the way through and the torque dip' is WAY less noticeable. Really happy with this device. It improved the feel of this car, ten fold.
My only qualm is the valve-train noise around the 3500-4000 region. But I guess that's just the nature of the beast, and the revised VTT mapping. Also, my ABS light and traction control symbol seem to be appearing at random when data logging. At least it seems random, I tried braking hard, and breaking the tires loose and it didn't do it every time. Not sure what would be causing this, but it has only happened when data logging?
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
