Old 06-18-2014, 09:50 PM   #1527
CSG Mike
CSG Mike's Avatar
Originally Posted by Kiske View Post
Had my first track day today. Really re-fell in love with the car. For my first time out I decided to keep the stock equipment and tires. I was really suprised with how well the car did on them in a track enviorment.
Went out with all off (hold down trac for 3+seconds) and am glad I did. The car was very predicitible and I felt much better. Only had the tc light flash once when I had to yeild to another infront of me completely screwing up my rythem and line.
My question. On the track I was at there is one turn in which you come out of a "S" into a very slow left hand turn (around 30 degree angle.) In this turn I could hit the apex however to do so I had to drop into 2nd gear. All the instructors told me to just waste the turn, throw it away and just focus on getting through it slowly and back on the gas as quickly as possible. Making it though the turn I come put somewhere low 2500-3000 rpm range way out of the BRZ's idea rpm range. Should I go ahead and dropped into first gear? Comming out of the turn felt like the slowest thing on the track.
1st is fine if you're that low.
Old 06-18-2014, 09:51 PM   #1528
CSG Mike
CSG Mike's Avatar
Originally Posted by nyfries View Post
Doesn't lighter rims really make that much of a difference to a beginner? Have a chance to grab a set of 17x9 rota torque. Seems to be slightly lighter than stock but def heavier than the rpf1 I wanted. It is also half the price. Does the weight saving of the rpf1 warrant another $600? Money that could be use to put towards nice tire?
You'll notice it, even street driving. Would you notice if you were driving a car with more power?
Old 06-18-2014, 10:11 PM   #1529
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Originally Posted by CSG David View Post
Bent so many RPF1s...
I didn't know they bent so easy. I guess they aint no better than Rotas... not surprising as the RPF1s are only $1k too and also just mere cast alloy
...more reason to try and find some 17" RKRs
fooddude is offline   Reply With Quote
Old 06-18-2014, 10:20 PM   #1530
CSG Mike
CSG Mike's Avatar
It's more a result of making a wheel as light as possible. When you're doing heavy stress testing, you're bound to break things, including wheels.
fooddude (06-19-2014)
Old 06-18-2014, 10:28 PM   #1531
nyfries
Drives: 14 FRS Whiteout
So really 17 inch rota are better for this price? It's cheaper only slightly heavier in some cases (most still lighter than stock) and this a little stronger? Not the mention this is cheaper? Can this be? I been saving up for the rpf1 the whole time
nyfries is offline   Reply With Quote
The Following User Says Thank You to nyfries For This Useful Post:
CSG Mike (06-18-2014)
Old 06-18-2014, 11:52 PM   #1532
CSG Mike
CSG Mike's Avatar
I'd never rock a Rota.
No, the rpf1 is still the best value.
I'd bet the lifespan of a Rota under our testing would be much shorter.
I've never bent a volk or bbs wheel before.
Old 06-19-2014, 12:50 AM   #1533
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Assuming the use of the same high performance tire compound, what do you gain from going with the OEM 17x7+48 215/45/17 sizing to the popular 17x9+35 245/40/17 sizing?
mit_peid is offline   Reply With Quote
Old 06-19-2014, 02:56 AM   #1534
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
How does RPF1 toughness compare to OEM toughness?
Old 06-19-2014, 04:09 AM   #1535
CSG Mike
CSG Mike's Avatar
I'd imagine marginally better. We haven't really used the OEM rims on track...
Old 06-19-2014, 04:10 AM   #1536
CSG Mike
CSG Mike's Avatar
More heat capacity, more cornering grip, more rolling resistance and more rotational inertia.
FRSfan111 (06-19-2014), mit_peid (06-19-2014)
Old 06-19-2014, 10:13 AM   #1537
mit_peid
Boosted Noob
mit_peid's Avatar
So in other words, you gain some capability on the track, but you'd probably lose some off-the-line acceleration and may impact MPG a bit (and I guess obviously the car looks better with the wider wheels/tires).
The Following User Says Thank You to mit_peid For This Useful Post:
CSG Mike (06-19-2014)
Old 06-19-2014, 12:05 PM   #1538
CSG Mike
CSG Mike's Avatar
Precisely. You have to balance everything; more is not always better.
Old 06-19-2014, 12:27 PM   #1539
DarkSunrise
DarkSunrise's Avatar
I think RPF-1's are manufactured using MAT technology (i.e., flow-form cast). They should be about 10-15% lighter than a comparable strength gravity-cast wheel like Rota.
Whether that 10-15% matters is the question.
2022 BRZ Build
2013 FR-S Build
Old 06-19-2014, 01:02 PM   #1540
CSG David
CSG David's Avatar
While RPF1s bend, Rotas will crack. Pick a failure mode: engineered failure or uncontrolled catastrophic failure. Casting parts is an engineered manufacturing process. It's not as simple as just pouring molten metal into a mold and expect great results, the method in which you inject the metal into the mold needs to be thought out as it "cools" in the mold. If done improperly, you get air pockets and non-uniform cooling/hardening of the material. On top of that, heat treatment of the product needs to be carefully regulated to reduce/relieve the intergranular stresses that could cause epic dislocations resulting in a crack due to load paths from improper casting. While Rota is actually a slight tier higher than the other replica brands, it does not exactly have a stellar track record either. When people buy into failures, it just reinforces the fact that "it's okay to mess up for the sake of others' safety". That's a huge flaw in engineering ethics that's difficult to support.
The Following 4 Users Say Thank You to CSG David For This Useful Post:
fooddude (06-19-2014), ImperiousRex (06-19-2014), kavanagh (06-20-2014), SexyPirates (07-12-2021)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
