Old 06-18-2014, 06:07 PM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Silicone coupler or similar that is 4" I.D., and 1 inch Thick... (SOLVED)
Got what I needed, read the end of OP.....
I need HELP. I have a 4" turbo inlet. I need a very short filter to fit it. AFE has a 5" filter that would fit perfect. Because of this, I am looking for a silicone coupler of rubber hose or something I can put in the turbo flange, that is 1 inch in thickness and thus allows me to use that 5" filter on the mouth of my turbo...
Anyone have any ideas? I've searched and searched the net for it to no avail...
EDIT: Got exactly what I needed... Read below!
So incredible that I have had the answer right in my face all this weeks.....
The brand of my current turbo silicone couplers has the part I need EXACTLY....
http://racepartsolutions.com/index.p...part-solutions
Old 06-18-2014, 07:02 PM   #2
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
eBay can't help? You need a reducer from the sounds of it. Or you can flare a short piece of piping.
I have a truck shop in the OKC area that sells all manner of couplers, clamps and such that I browse through when I'm in dire need. Otherwise, creative use of Google and/or eBay generally net what I'm looking for.
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
The Following User Says Thank You to Boss Paco For This Useful Post:
Sportsguy83 (06-18-2014)
Old 06-18-2014, 07:05 PM   #3
Gunman
Drives: 2019 Mazda Miata RF
It's 3" long, but I don't think you'll find anything shorter.
http://www.siliconeintakes.com/produ...89c756586d9300
The Following User Says Thank You to Gunman For This Useful Post:
Old 06-18-2014, 07:47 PM   #4
Sportsguy83
Drives: Limited BRZ
I can't use a reducer. There is no space... It needs to be something that fits over the turbo mouth and that's it. Can't make it any longer or it will hit sandwich plate lines. That is why it needs to be 4" ID and 1" thick to simulate the turbo being 5" inlet. Added a pic to better explain the space constrains. That big filter is no longer there, as I needed to make room for Oil cooler hoses.
Old 06-18-2014, 08:08 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
4" ID coolant hose might be thick enough.
Or you could have a piece machined and welded onto the turbo inlet.
The Following User Says Thank You to Calum For This Useful Post:
Old 06-18-2014, 09:10 PM   #6
Sportsguy83
Drives: Limited BRZ
Thinking about it, maybe the 4-5 inch silicone coupler might work, just need to cut it shorter.....
Old 06-18-2014, 09:27 PM   #7
Sportsguy83
Drives: Limited BRZ
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Gunman (06-18-2014)
Old 06-18-2014, 10:35 PM   #8
BadBRZ
Drives: Subaru
for the record if it was 4" ID and 1" thick your filter would need to be 6" ID to fit over it...
:P
and your missing an oil filter in your picture
BadBRZ is offline   Reply With Quote
Old 06-18-2014, 10:46 PM   #9
Sportsguy83
Drives: Limited BRZ
:P
I'm also missing a bumper, battery is disconnected, catch can not installed, EBCS not installed. Lucky me that pic is about 3 months old
Sent from my SM-N900A using Tapatalk
Old 06-18-2014, 10:52 PM   #10
BadBRZ
Drives: Subaru
Not really, filter would need to be 5.001" to fit. 4 in I.D. +1 in thick= 5 in O.D. you are adding 1 inch of diameter across the circle.
... I am looking for a silicone coupler of rubber hose or something I can put in the turbo flange, that is 1 inch in thickness and thus allows me to use that 5" filter on the mouth of my turbo...
*cough *cough ... 1" Thickness
haha that is good for you, and in all actuality this is right about where my car currently sits, until July 1 or so, WOOT !!!
Old 06-18-2014, 10:57 PM   #11
Sportsguy83
Drives: Limited BRZ
That's true... 1 inch thickness means 1 inch at each side so it would need to be 6".... I did find hose that are 4" and 4.5 OD....
Thanks!! Good luck with your project.
Old 06-18-2014, 11:29 PM   #12
BadBRZ
Drives: Subaru
I'm basicly copying you so i imagine it will go well, lol
The Following User Says Thank You to BadBRZ For This Useful Post:
Sportsguy83 (06-19-2014)
Centric Premium Rotors - too thick? smbstyle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-31-2014 01:01 AM
17 inch in the front, 18 inch in the back ? brz_fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-16-2014 09:35 PM
FS: AVO Silicone inlet (red) SOLD Panda Grahams Engine, Exhaust, Bolt-Ons 7 09-18-2013 08:16 AM
FS: AVO Silicone Intake Panda Grahams Engine, Exhaust, Bolt-Ons 5 08-10-2013 12:23 PM
