Old 11-17-2013, 12:24 PM   #1
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Centric Premium Rotors - too thick?
So I got around to installing OEM replacement rotors (Centric Premium), and after installing them with the OEM pads w/ shims (OEM pads have about 2k miles on them), I found that I couldn't get the caliper around the pads and rotor, and actually had to remove the first shim on the backing plates for the caliper to even squeeze on.
There is no space at all for the pads to move, and are pressed against the rotor.
Has anyone else running Centric premium rotors had this issue?
My only solution at this point is try out a new set or have them turned.
smbstyle is offline   Reply With Quote
Old 11-17-2013, 12:41 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Or let the pads wear down the little bit until.
Old 11-17-2013, 12:46 PM   #3
smbstyle
smbstyle's Avatar
My concern is when I put the race pads on which are a tad bit thicker than the lightly OEM pads; I don't think they'll even fit.
Old 11-17-2013, 05:43 PM   #4
Calum
That Guy
Bastard file?
The Following User Says Thank You to Calum For This Useful Post:
smbstyle (11-17-2013)
Old 11-17-2013, 06:19 PM   #5
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
Did you spread the pistons all the way back out?
Carolina Dyno is offline   Reply With Quote
Old 11-17-2013, 06:40 PM   #6
smbstyle
smbstyle's Avatar
lol, yes, definitely did.
Old 11-17-2013, 08:38 PM   #7
Carolina Dyno
Drives: 2013
Sorry, had to ask... I've seen simpler things overlooked.
Old 11-17-2013, 08:53 PM   #8
smbstyle
smbstyle's Avatar
Exact same reason for my lol, watched a guy scratch his head for an hour at the track trying to get his new pads on, not realizing he needs to compress the pistons!
Old 11-19-2013, 07:37 AM   #9
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
I'm using Centric Premium rotors and have had no such issues. Initial installation was new rotors with new Hawk DC60 pads, using the OEM pad shims.
celica73 is offline   Reply With Quote
Old 11-19-2013, 07:42 AM   #10
smbstyle
smbstyle's Avatar
Hm, interesting. Do you know what the total overall thickness of the new Hawk pads were?
Old 11-19-2013, 11:33 AM   #11
subielife
Subaru Ambassador
subielife's Avatar
Drives: 13 BRZ 18 Silverado
i have used them on the BRZ with both street and track pads. no issues
subielife is offline   Reply With Quote
Old 11-19-2013, 11:40 AM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
What is the minimum thickness of the rotors you have? Are they the right ones for the car?
It may very well be a case of mispackaged rotors.
-alex
Old 11-19-2013, 11:50 AM   #13
smbstyle
smbstyle's Avatar
-alex
These rotors measure 0.949", my OEM rotors measured about 0.943", so really not that big of a difference, but just enough that they're dragging a bit, and couldn't fit that top shim on the OEM pads on.
I drove around for about 20 miles yesterday, which was enough to take off enough pad material to get the second top shim on the OEM pads.
Old 11-19-2013, 12:03 PM   #14
TemeCal
Drives: 86
I ran them last track season, with Carbotech XP10 (fronts) and XP8 (rears). I never had an issue like this. Mine seems to fit just fine. I believe my centric blank part numbers were:
Front- 120.47021
Rear- 120.47031
TemeCal is offline   Reply With Quote
R1 Concepts Premium Rotors/ Hawk/ Stoptech/ Posi Quiet Pads/ S.S. brakelines Sale! r1concepts Brakes, Suspension, Chassis 419 06-10-2016 06:19 PM
Carbotech XP12 & Centric Premium rotors (Both New) Hanakuso Brakes, Suspension, Chassis 3 11-25-2013 06:50 PM
FS: Brand New Centric Premium Rotors Texas BRZ Brakes, Suspension, Chassis 6 07-21-2013 10:57 PM
FS: Hub centric rings 63 > 56.1 mm JDMSushi Australia Classifieds 3 02-09-2013 08:52 PM
