Old 06-18-2014, 12:36 PM   #43
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Originally Posted by sw20kosh View Post
Why? The IC is pre-PCV. The PCV doesn't dump into the IC unless you are talking about innovate twin screw IC?
Are you talking about the breather? That doesn't seem to blow out any oil.
He is right
Track it and you will see
Oil embolism tendencies exist and are for real.
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-18-2014, 01:24 PM   #44
Dezoris
Dezoris's Avatar
Originally Posted by kiichiro View Post
He is right
PCV has nothing to do with the IC. Catching PCV vapor is for reducing oil in intake manifold.
The breather line which is routed from the block to the intake tube normally on a stock car, is re-routed to the intake tract of forced induction cars. In the case of turbo or SC cars it's universally accepted any blow by from the breather system will accumulate in your IC and over time and hurt efficiency of the IC, this is nothing new.
Its pretty much common sense to catch it, if you don't then just accept you will have to pull your IC off eventually to clean it out.
Old 06-18-2014, 05:11 PM   #45
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
What are the benefits or disadvantages of having a ventilated PCV catch can against a closed loop system like these two items here?
My gut tells me that the breather system helps protect against a blocked system and the rough idle and other symptoms associated with it?
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 06-18-2014, 05:39 PM   #46
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Ran a generic moroso initially, didn't catch much
Mine is routed inline with the rear PCV and I catch a decent amount every thousand or so miles. I empty it after every track day (over 10 so far) and always have some accumulation in there.
Originally Posted by Dezoris View Post
In all fairness the Moroso can is junk.
I disagree. Just because it's cheaper doesn't make it any less functional. It couldn't be easier to drain, either.
Lots of good reviews here. http://amzn.com/B004K9BIY4
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
DAEMANO (12-18-2014), Marchy (06-20-2014)
Old 06-18-2014, 05:41 PM   #47
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Any DIY of your mounting solution?
φφκα
Old 06-18-2014, 05:43 PM   #48
ATL BRZ
ATL BRZ's Avatar
Just removed the cross brace, measured and drilled two holes in it using the provided mounting bracket as a template, screwed in the provided screws and put a couple heavy duty zip ties around the screws/bracket/bar for extra security. Pretty simple.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Cjymiller (06-18-2014)
Old 06-18-2014, 05:59 PM   #49
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I think even the cheap catch cans should work just fine to catch the vapors so we basically pay more for being able to remove the bottom part easily, and ability to check the oil level (indicator or dip stick) so is it worth paying about $100-150 extra? I don't know that is the question you should ask yourself
even after my fifth track event (within the couple months lol) and numerous pulls and daily driving I have nothing in the breather side, maybe I will collect some amount down the road but I believe it will be something negligible ..
glamcem is offline   Reply With Quote
Old 06-18-2014, 06:01 PM   #50
glamcem
glamcem's Avatar
Originally Posted by nocwage View Post
For those using Teflon tape make sure you are using the proper kind meant for contact with petroleum.
If you're using the super thin white stuff it typically dissolves in gasoline, just dip it in some and see..
Lots of people messing with fuel lines make that mistake..
interesting point, never though about that I will most likely change mine sometime
Originally Posted by solidONE View Post
Don't think it would be a huge problem since we are talking about vacuum lines no fuel lines, but good to know regardless.
yes and no, since the collected oil also consists of unburned fuel I am not sure if it would affect the white teflon tape
Old 06-18-2014, 06:52 PM   #51
Dezoris
Dezoris's Avatar
Sorry about that, I was thinking of the Cusco can, my mistake.
Old 06-18-2014, 07:03 PM   #52
nunonuna
nunonuna's Avatar
so ptfe type of teflon is ok?
nunonuna is offline   Reply With Quote
Old 06-19-2014, 05:50 PM   #53
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Picked this up last night
http://www.ebay.com/itm/ADD-W1-Black...-/141097569813
Once I find a convenient place to mount I'll post some feedback in a separate thread.
φφκα
Old 06-19-2014, 08:56 PM   #54
nunonuna
nunonuna's Avatar
I put mine here.
I really couldn't find any better place.
Borrowed Dezoris idea of location and made my own bracket.
If you have removed intake sound generator, then you
can use that mid point to bolt up to make it hold better.
The Following User Says Thank You to nunonuna For This Useful Post:
Cjymiller (06-20-2014)
Old 06-20-2014, 12:53 AM   #55
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Originally Posted by nunonuna View Post
I put mine here.
Thank you, much appreciated! What is connected to the mid bolt in your images? Also How has your experience been with it thus far?
φφκα
Old 06-20-2014, 08:50 AM   #56
nunonuna
nunonuna's Avatar
So far I like it.
I think its great for some one who doesn't want to spend or can't afford $200/can. If you look my previous post, there is picture taken after only about 3 weeks of DD with few times of WOT.
For mid bolt, there is black metal piece that used to hold small hose part of noise generator. If you remove noise generator, you will see. That piece of metal is bendable so you can align it with your bracket easily.
Radium Engineering Catch Cans FRS2000 Engine, Exhaust, Transmission 111 03-02-2016 12:49 AM
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 07:17 AM
Radium or Crawford catch cans/AOS diss7 Forced Induction 16 02-18-2014 07:50 AM
Catch Can breather line question protpibe Engine, Exhaust, Transmission 1 01-18-2014 03:20 PM
cusco catch cans difference Silverdub Engine, Exhaust, Transmission 15 04-23-2013 09:17 AM
