Old 06-18-2014, 09:01 AM   #6301
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Target70 View Post
+1
If the shipment goes out late July, I hope to have it early Aug. Expecting my OFH to ship about the same time. While waiting on my ESC, I wanted to install the header and run the stage 2 tune to make sure that I didn't have any strange codes, leaks or other issues. It's kind of funny, If they get here at the same time, I think it will be quicker to bolt on my supercharger kit then it would be to change out the exhaust manifold, so I may do that first.
*sigh, I'll still need to finish up my battery relocation, and order my dump packs, and get the Phantom tune from Shiv. so much to do, so little time.
Took me ~1.5 hours installing my ESC. And that was at a leisure pace. Everything is upside and in-cabin.
3-4 hours for me to do headers. Crawling in and out under my car numerous . Struggling to remove the damn overpipe bolts. Got down and dirty.
TM is offline   Reply With Quote
Old 06-18-2014, 09:15 AM   #6302
DAEMANO
Time Traveller
Originally Posted by enwave View Post
Alright, installation all complete.
Took her for a test run after installation... wow. Even with the ECU being freshly flashed and the batteries not conditioned and being flashed back to 91oct instead of E85, I'm thoroughly impressed. Really great bang for the buck, and already significantly better than I anticipated. I expect it only gets better as batteries get warmed up. My AFR seemed good, though a little lean in the mids. I'm told this is because the 1.5OFH isnt ready, so I'm running 1.0OFH tune.
I heard from a little birdie earlier today that a true 1.5dump tune as early as the beginning of next week; and 1.5E85 not long after. the 1.5dump is going on shop car this week.
I can't even imagine what that will be like. I have to admit, I was excited with a small bit of skepticism. Now I'm thrilled.
Congrats man. You waited quite some time so I know the ending reward was sweet. Time to burn some rubber!
The Following User Says Thank You to DAEMANO For This Useful Post:
enwave (06-18-2014)
Old 06-18-2014, 09:18 AM   #6303
shif7i7down
Erected Member
Drives: frs
OMG, why did you have to go and say something like that. now I'll be glued to the computer constantly refreshing the page waiting for the new tune.
shif7i7down is offline   Reply With Quote
Old 06-18-2014, 09:50 AM   #6304
WNDSRFR
Drives: FR-S,GTI
Originally Posted by fenton View Post
don't you love how easy it easy.
Holy man is this thing down on power though....it feels like I'm crawling...Toyota seinnas are passing me when I'm trying to merge.
I can't believe how much the phantom transforms the car now that I'm back to stock.
might not think 40hp is much but in a car this light it is a dramatic difference.
It's not so much the HP as it is the increase in low end torque that really makes the difference.
Old 06-18-2014, 10:16 AM   #6305
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Definitely. For me, engaging around 3-3.5k just pulls me hard through that midrange with gobs of torque (compared to stock at least). Great to pull you through second gear especially.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 06-18-2014, 10:30 AM   #6306
raven1231
And at 2k you chirp tires lol
Old 06-19-2014, 08:38 PM   #6307
martinEZ
martinEZ's Avatar
Is it just the inner ricer in me, or does any one else wish there was a BOV? Just for the sound... plan on getting it either way though.
martinEZ is offline   Reply With Quote
Old 06-19-2014, 09:14 PM   #6308
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
There is a whoosh.
Installed Mods:
Old 06-19-2014, 10:16 PM   #6309
enwave
enwave's Avatar
Shifting while on boost sounds pretty hot with my exhaust setup too. It's like a little pop as the airflow changes. Definitely sounds like boost.
Old 06-19-2014, 11:07 PM   #6310
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
What's gonna trigger it? It's not like we have abundant boost. You'd have to set it at 4psi. Seems perfectly wasteful.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
raven1231 (06-20-2014)
Old 06-19-2014, 11:09 PM   #6311
jflogerzi
jflogerzi's Avatar
I am going to take the plunge. I hope to get in on the batch thats @ the end of July. By then lets hope the E85 and proper 1.5dump tunes come out
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
DAEMANO (06-20-2014), raven1231 (06-20-2014)
Old 06-19-2014, 11:21 PM   #6312
fenton
shiv has said he has new batteries on order for the 1.5 pack. Once they get them they will get to some new tunes for us
on a side note.... has anyone monitored cylinder misfire? I monitored it today and when the engine is idling sometime the count can go up 1 or 2 and then back to 0. You cant really tell anything is happening bit I have always had a bumby idle a bit.
it certainly doesn't feel broken of anything.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Old 06-20-2014, 06:47 AM   #6313
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
1.5 dump received and installed. Directions were clear and easy to follow, took me about 30-40 minutes I think. Can definitely tell the difference - going to spend some more time "conditioning the batteries" this weekend.
Once I have an E85 tune for this setup, I'm not entirely sure what the heck to do next as far as go-faster bits are concerned.
VR46 is offline   Reply With Quote
The Following 2 Users Say Thank You to VR46 For This Useful Post:
raven1231 (06-20-2014), Sojhinn (06-20-2014)
Old 06-20-2014, 06:55 AM   #6314
07jazzrs5gt86
Drives: Firestorm 86
Have the june batch be sent out yet?
I'm 2nd in line for it and still haven't heard from rob yet
07jazzrs5gt86 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
