Old 06-17-2014, 11:33 PM   #6287
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I will say this. Nothing. Like drinking a helluva a lot to forget about your ticket.
Installed Mods:
Old 06-17-2014, 11:33 PM   #6288
Sojhinn
Sojhinn's Avatar
Originally Posted by enwave View Post
Hey y'all. I'm almost done with the installation but struggling with the airbox resonator removal. How did you all do that?
Drill is your friend.
Installed Mods:
Old 06-17-2014, 11:37 PM   #6289
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
So did you just drill right through the two metal rivets then?
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 06-17-2014, 11:39 PM   #6290
Sojhinn
Sojhinn's Avatar
Yeah. I used a small gauge drill to start it. And if needed a larger one.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
enwave (06-18-2014)
Old 06-17-2014, 11:43 PM   #6291
enwave
enwave's Avatar
Huh. That part of the instructions made me nervous for some reason -- thought maybe there was a way around the drilling. Thanks!
Old 06-17-2014, 11:45 PM   #6292
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Yep drill it out - no room for it with the phantom compressor so it has to go.
I'm hoping to get to Home Depot this weeks and fab a pipe to the sound tube from the airbox - Rob thinks it might sound cool so we shall see.
Course, the bay looks so open and clean with the sound tube and resonators removed, especially with a nice header.
Khyron686 is offline   Reply With Quote
The Following User Says Thank You to Khyron686 For This Useful Post:
enwave (06-18-2014)
Old 06-18-2014, 12:12 AM   #6293
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
You don't have to drill all the way through. when I got about 1/8th of an inch in, the rivets started free spinning. Just drill below the surface of the rivet, then look inside the air box lid, and you will see the rivet stud sticking out the back, grab with a pair of pliers and twist sideways. The head will pop off pretty easily
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
enwave (06-18-2014)
Old 06-18-2014, 12:35 AM   #6294
enwave
enwave's Avatar
Also, the eyelets coming from the controller that are supposed to hit the starter post bolts seem a bit too small. Am I sending them the wrong place?
Old 06-18-2014, 12:50 AM   #6295
enwave
enwave's Avatar
Of course, clamp bolts not post bolts.
Old 06-18-2014, 01:59 AM   #6296
enwave
enwave's Avatar
Full throttle Electric Supercharger Build Thread
Alright, installation all complete.
I noticed three minor hiccups in the installation. First, the turbine stuck out just a little too far to the left at first, making it hard to connect with the throttle body. I figured that out fairly quickly. The drilling of the rivets was something I didn't really love the idea of, but it all worked out perfectly. The battery cover and tie down are a tad awkward, but really not bad and the tie down isn't any worse than stock.
Overall, installation was super easy. Still need to pretty up the wires in the cabin though.
Took her for a test run after installation... wow. Even with the ECU being freshly flashed and the batteries not conditioned and being flashed back to 91oct instead of E85, I'm thoroughly impressed. Really great bang for the buck, and already significantly better than I anticipated. I expect it only gets better as batteries get warmed up. My AFR seemed good, though a little lean in the mids. I'm told this is because the 1.5OFH isnt ready, so I'm running 1.0OFH tune.
I heard from a little birdie earlier today that a true 1.5dump tune as early as the beginning of next week; and 1.5E85 not long after. the 1.5dump is going on shop car this week.
I can't even imagine what that will be like. I have to admit, I was excited with a small bit of skepticism. Now I'm thrilled.
The Following 8 Users Say Thank You to enwave For This Useful Post:
DAEMANO (06-18-2014), Gums (06-19-2014), raven1231 (06-18-2014), robwbright (06-21-2014), shif7i7down (06-18-2014), Sojhinn (06-18-2014), VR46 (06-18-2014), WRB5titch (06-18-2014)
Old 06-18-2014, 04:26 AM   #6297
raven1231
Glad to hear it brother ! I hope for all of our sakes your little birdie.is right
Old 06-18-2014, 04:34 AM   #6298
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Hey does anyone have any info on when the next batch is going to be released? Don't want to miss out and have have been anticipating this mod for awhile. I heard sometime in July but wondering if any new developments are known.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-18-2014, 05:32 AM   #6299
Target70
Target70's Avatar
+1
If the shipment goes out late July, I hope to have it early Aug. Expecting my OFH to ship about the same time. While waiting on my ESC, I wanted to install the header and run the stage 2 tune to make sure that I didn't have any strange codes, leaks or other issues. It's kind of funny, If they get here at the same time, I think it will be quicker to bolt on my supercharger kit then it would be to change out the exhaust manifold, so I may do that first.
*sigh, I'll still need to finish up my battery relocation, and order my dump packs, and get the Phantom tune from Shiv. so much to do, so little time.
Old 06-18-2014, 06:54 AM   #6300
raven1231
Originally Posted by Target70 View Post
+1
It sure will be lol
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
