Old 06-11-2014, 08:27 AM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Manual shifter rattle?
Hi,
Just started noticing when i get about 4k in 2nd and 3rd gear my shifter makes a loud rattle. I removed the knob just to make sure that wasnt giving me issues and its doing it in the actual shift. In 4th gear no rattle works fine. Any help on this would be greatly appreciated
Thanks
Frs32907 is offline   Reply With Quote
Old 06-15-2014, 11:22 PM   #2
becauseracecar1
becauseracecar1's Avatar
Drives:
I have the same problem... Would also appreciate some help. 2014 FRS, build date March 2014.
2014 Ultramarine Scion FR-S
facebook.com/86motorsports
becauseracecar1 is offline   Reply With Quote
Old 06-17-2014, 09:03 AM   #3
Frs32907
Well toyota covered it under the tsb on the shifter hopeful no more issues but I did notice they have me flagged cause of my mods.
Can the shifter assembly be changed in the cabin or do you have to be under the car?
Old 06-17-2014, 01:54 PM   #4
becauseracecar1
Drives:
How long did it take for them to fix it?
Thanks!!
Old 06-17-2014, 06:03 PM   #5
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Try this?
http://www.ft86club.com/forums/showthread.php?t=50512
unsurety is offline   Reply With Quote
Old 06-21-2014, 09:54 AM   #6
becauseracecar1
Drives:
Got the TSB done and now it rattles 1st-6th gear FML
Old 07-19-2014, 11:14 AM   #7
Ingen
Drives: Ultramarine FR-S 6MT
I had the same problem. Just got the tsb done and it was awesome... For 100 miles. I can hear it creeping back in and I'm sad
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 01-18-2015, 11:28 PM   #8
Wyattkb
Drives: 2014 Whiteout FRS
I have this same issue, 3 different shifters all had the same issue.
Went from Stock, Shiftek, then to a Kart Boy. All rattle, most noticeably under full throttle and higher RPMs.
Only thing I can think of that I haven't tried is removing the Whiteline KDT926 Gearbox Bushing. Maybe after installing it increased the NVH enough to cause this?
Anyone else with this issue have the gearbox bushing?
2014 FRS here
Wyattkb is offline   Reply With Quote
Old 01-19-2015, 12:42 AM   #9
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Thats odd, i have 2013 and my stock never had any issues with rattle, i'd take it to dealer.
2014 FRS here
I have the kartboy, remove the shift knob exposing an allen screw, and use an allen key to take off the screw. Remove the spring inside and put some grease in there. That was able to remove the rattle for me. Just engage the reverse lock out a few times and wipe off the grease that comes out. You dont need to add too much
Old 01-19-2015, 02:22 AM   #10
Wyattkb
Thanks for the info. Just added some grease to it now. Will test drive tomorrow to see if anything changes.
Old 01-19-2015, 02:26 AM   #11
Wes
Wes's Avatar
make sure you move the reverse lockout up and down prior to driving to remove any excess grease
i accidentally added too much lol
Old 01-19-2015, 05:49 PM   #12
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
I have this rattle as well, everything related to the trans/shifter assembly is 100% stock and never been touched. At high rpm, say 5k+, it starts to rattle really bad. Never taken it anywhere yet, but the amount of problems I'm having with this car are really starting to build up.
Anyone know what this problem is?
Apex_BRZ is offline   Reply With Quote
Old 01-20-2015, 08:10 AM   #13
Wyattkb
After adding some grease it did quite it down very very mildy while on cruise control.
Getting on the throttle/anything past 3k and it still rattles.
I am going to chalk it up to the positive shift bushing I installed and move on. I might install the perrin rear shifter bushing as well, maybe it will change the NVH and make it stop.
I'm afraid if I take it into the dealership they will just say its an issue with the kartboy.
Old 03-23-2015, 02:42 AM   #14
Wyattkb
Just an update. Removed Whiteline transmission bushing insert. Rattle is gone.
It also stopped making a high pitched soft whine in 6th gear while under 65 MPH.
Audible shifter rattle Hanzo Issues | Warranty | Recalls / TSB 134 08-17-2022 02:34 AM
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
Shifter Rattle and Replacement boredom.is.me Issues | Warranty | Recalls / TSB 19 04-27-2015 04:29 PM
2014 Shifter Rattle becauseracecar1 Issues | Warranty | Recalls / TSB 1 05-24-2014 06:06 PM
BRZ Shifter Rattle TSB sc0urge BRZ First-Gen (2012+) — General Topics 2 08-26-2013 08:53 PM
