Old 06-16-2014, 12:54 PM   #29
nunonuna
nunonuna's Avatar
Same catch can installed on NA.
Picture is only after 3 weeks of DD(about 1k miles) with very few times of WOT.
Oh and any one who has same can on NA car experienced CEL?
Mine throw CEL with this until I used teflon tape on every single thread it has.
nunonuna is offline   Reply With Quote
Old 06-16-2014, 05:06 PM   #30
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Yeah, if there was a vacuum leak in the catch can the unsteady idle should have hinted you before the CEL came on. I had to put teflon tape on all the threaded fittings as well. Are you using the same ADD catch can that i'm using? If so, try throwing some scrubbers or screen in the baffle chamber.
Old 06-16-2014, 05:10 PM   #31
solidONE
solidONE's Avatar
Originally Posted by kiichiro View Post
No catch can
No problem
60k miles mixed on and off track on one car
20k miles heavy track and high boost on the other
Ran a generic moroso initially, didn't catch much.
When will my motor implode since I don't really think I need a catch can?
I doubt it, but you will end up with oil residue in the intake mani and possibly the back of your intake valves.
Old 06-16-2014, 05:35 PM   #32
nunonuna
nunonuna's Avatar
yes its same ADD one.
where can I get screen thing?
and does it make difference?
Old 06-16-2014, 06:43 PM   #33
solidONE
solidONE's Avatar
I'm not 100% positive but I believe it does. You will have to make your own. I've seen people use stainless scouring pads for 'scrubbers' in catch cans lol. I imagine you can cut some scotchbright pads in the correct diameter and use that as well. Or hit up the hardware store for some metal screen and cut with a hole saw the correct diameter. I think that's what Radium uses as baffle in the catch cans. The stronger the vacuum the more material you need and vice versa. The idea is to catch vaporized oil in the air before it goes into the intake mani.
The Following User Says Thank You to solidONE For This Useful Post:
nunonuna (06-16-2014)
Old 06-16-2014, 07:07 PM   #34
Model Citizen
Lacking brains
Drives: frz
i made my catch can from a can of nair.
my balls got shiny as a bonus
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 06-16-2014, 07:37 PM   #35
nunonuna
nunonuna's Avatar
thanks~
I will try that.
Old 06-16-2014, 10:17 PM   #36
Dezoris
Dezoris's Avatar
No catch can
No problem
In all fairness the Moroso can is junk. Have you pulled your IC to see if you have any oil accumulation yet?
Its more of a maintenance item to keep intake manifold and IC free of sludge. Sure it helps intake valves too but much less an issue with the port injection on this car.
Old 06-16-2014, 11:51 PM   #37
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
It's not dry but it's not oily, if that makes sense
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-17-2014, 07:56 AM   #38
stevesnj
stevesnj's Avatar
Originally Posted by TemeCal View Post
Isn't there cause for concern with the high amount of blowby some of you are getting?? I have one Radium catch can for the PCV, and one for the breather. The breather is bone dry, and the PCV only has a few drops.
This is after 4 track days and aprox 5k miles of daily driving. I don't quite understand how some of you are getting sooooooo much blowby.
Cause they beat the crap out of the car and rev it high more than you I suppose
Old 06-17-2014, 09:37 AM   #39
nocwage
MMTT
Drives: 2019 Subaru BRZ
For those using Teflon tape make sure you are using the proper kind meant for contact with petroleum.
If you're using the super thin white stuff it typically dissolves in gasoline, just dip it in some and see..
Lots of people messing with fuel lines make that mistake..
nocwage is offline   Reply With Quote
The Following User Says Thank You to nocwage For This Useful Post:
glamcem (06-18-2014)
Old 06-17-2014, 07:16 PM   #40
solidONE
solidONE's Avatar
Don't think it would be a huge problem since we are talking about vacuum lines no fuel lines, but good to know regardless.
Old 06-17-2014, 07:49 PM   #41
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
Loctite 567 thread sealer is much better than thread tape for npt fittings
JP is offline   Reply With Quote
The Following User Says Thank You to JP For This Useful Post:
kiichiro (07-21-2014)
Old 06-17-2014, 08:35 PM   #42
sw20kosh
Drives: 2013 Black FR-S
Why? The IC is pre-PCV. The PCV doesn't dump into the IC unless you are talking about innovate twin screw IC?
Are you talking about the breather? That doesn't seem to blow out any oil.
Radium Engineering Catch Cans FRS2000 Engine, Exhaust, Transmission 111 03-02-2016 12:49 AM
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 07:17 AM
Radium or Crawford catch cans/AOS diss7 Forced Induction 16 02-18-2014 07:50 AM
Catch Can breather line question protpibe Engine, Exhaust, Transmission 1 01-18-2014 03:20 PM
cusco catch cans difference Silverdub Engine, Exhaust, Transmission 15 04-23-2013 09:17 AM
