Old 06-11-2014, 02:59 PM   #239
grostoine
Drives: Subaru BRZ
Finished product on mine.
grostoine is offline   Reply With Quote
The Following 5 Users Say Thank You to grostoine For This Useful Post:
BRZZZZZZZZZZ (06-11-2014), chanomatik (06-11-2014), JonAvalon (06-11-2014), microbionic (06-11-2014), SkAsphalt (07-16-2014)
Old 06-12-2014, 03:05 AM   #240
DSOmegaX
DSOmegaX's Avatar
Here's mine on. Fits perfectly under the STi 18x7.5 wheels
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
Guillaume (07-09-2014)
Old 06-12-2014, 04:17 AM   #241
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Whoa....IMO that's gotta be the coolest looking brembo i've seen!
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
grostoine (06-12-2014)
Old 06-14-2014, 01:56 AM   #242
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Installed mine yesterday, front and rear brembo's with new pads, rotors and SS lines... But the pedal is long and soft. Bled twice with motive power bleeder. Brakes are strong when stomped hard...even engages ABS...but very spongy
Old 06-16-2014, 03:37 PM   #243
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Bleeders are on top? Try hitting each caliper with a rubber mallet to release any bubbles that might be caught to the top of the caliper where the bleeder is and then bleed them again.
Old 06-16-2014, 03:49 PM   #244
STV3
Señor Member
STV3's Avatar
Originally Posted by RB Performance Brakes View Post
For those of you planning on retro fitting or already have the STi Brembo calipers.
RacingBrake offers Front Light Weight Two Piece Rotors for Subaru STi’s (2004-2012)
That will work with your FRS/BRZ STi Caliper swap.
(Hats have both 5x100 + 5x114.3 bolt pattern)
FT86Forums member receive free shipping to the lower 48 states using coupon code FT86-SHIP
Reference Photo
RacingBrake Rotors feature 3 patented designs
  • Center Mount – Hat mounts onto the surface of the rotor ring, balancing stress load and improving cooling by allowing air flow to enter from both the inboard and outboard side of the rotor
  • Convergent Vane – Provides efficient air flow and temperature across the disc surface
  • Open Slot – Advantage of both drilled and slotted, optimizes the friction between pad and disc
Street and Track brake pads are also available for your STi Calipers.
To learn more about us,
Visit our website at
www.RacingBrake.com
Hot damn those are some pricey rotors!
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
chanomatik (06-16-2014)
Old 06-16-2014, 09:42 PM   #245
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yup bleeders on top. So anyway I've re-bled the lines and it's all good now....nice and firm. Brake feel even during normal daily driving is so much better. But on VERY hard braking (say from 70+mph) I can feel the front end nose diving more than before and the ABS kicks in sooner. I'm currently running Stoptech pads all round, but i'm going to try a slightly higher friction rear pads to see how that feels.
Anyway here are some pics:
Old 07-03-2014, 02:13 PM   #246
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following 3 Users Say Thank You to Figo For This Useful Post:
chanomatik (07-03-2014), Racecomp Engineering (07-03-2014), STV3 (07-03-2014)
Old 07-03-2014, 02:22 PM   #247
STV3
Señor Member
STV3's Avatar
Originally Posted by Figo View Post
Your car good sir makes me want to touch myself...
Figo (07-03-2014)
Old 07-03-2014, 03:47 PM   #248
Figo
Figo's Avatar
And a Black-White-Red version.
Old 07-03-2014, 04:32 PM   #249
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Figo pictures, everywhere.
The Following User Says Thank You to SkAsphalt For This Useful Post:
civicdrivr (07-03-2014)
Old 07-05-2014, 07:58 PM   #250
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
2011 STI Brembo calipers, painted bright yellow with black STI logos.
Adam's Rotors custom rotors, "Race" slotting. 2004 STI front, 2011 STI rear drilled 5x100.
Stoptech braided lines.
Cusco front strut bar w/ MC brace.
I also currently have CarboTech AX6 pads in them. But they won't stay bedded in daily driving, so I'm going to get a set of 1521 "Bobcat" pads for street use.
The Following 5 Users Say Thank You to Draco-REX For This Useful Post:
chanomatik (07-05-2014), charged86 (08-24-2014), civicdrivr (07-06-2014), fooyc (07-24-2014), Karl07 (07-17-2014)
Old 07-06-2014, 02:48 AM   #251
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Love the yellow. I'm also planning to remove mine and get them painted yellow as well.
Old 07-16-2014, 05:22 PM   #252
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You front end could be diving more because your bias is off, many people note that installing the STI rears throws off your bias and actually reduces the effectiveness of the rear braking (thus more nose diving)
chanomatik (07-16-2014)
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
