Old 06-16-2014, 04:40 AM   #1
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Catalytic converters and E85
Friend of mine who ran E85 on his Evo warned me to look into this... I'm sure there are members here who have cats in their system and run an E85 tune. Track their cars like that, even. I haven't heard any problems about cats melting, is this a concern? Or does it affect OEM ceramic cats differently than metallic, high flow cats?
I plan to get a Berk catted front pipe, which IIRC uses a Magnaflow cat. Running the OFT E85 tune.
unsurety is offline   Reply With Quote
Old 06-16-2014, 04:45 AM   #2
s2d4
s2d4's Avatar
Is he saying running e85 was the reason for the melting cat?
Old 06-16-2014, 05:17 AM   #3
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Initially I thought the higher EGTs due to the turbo would have caused that. We both knew that E85 is supposed to burn cleaner... but he told me that E85 leaves deposits on the honeycomb. Something about sugar content in E85.
Could be increased boost too? My friend didn't say it was guaranteed, just to be wary of it. If it's temperature related, I'm not too worried. Catless header, catted FP is the plan.
Old 06-16-2014, 05:19 AM   #4
zooki
Drives: waiting on a 2021...
If I'm not mistaken I think E85 burns cooler than normal gasoline. I think it would actually take longer to heat up the converters to optimum temperature. But I could be mistaken.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 06-16-2014, 05:26 AM   #5
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
You're right in a way, it does have a cooling effect. It lower IATs if I'm not mistaken.
The problem he described is the deposits clump up. If it doesn't clog the cat, it forms a mass that absorbs more heat and takes longer to dissipate heat. And so the HFC turns into a straight pipe.
Old 06-16-2014, 08:04 AM   #6
s2d4
s2d4's Avatar
What happens when you leave some ethanol in a cup?
Old 06-16-2014, 09:09 AM   #7
steve99
Drives: FT86
http://www.empa.ch/plugin/template/e...143273/---/l=2
s2d4 (06-17-2014)
Old 06-17-2014, 06:19 AM   #8
reeves
Until I see a hole in my catalytic converter, I'm not too concerned.
Old 06-17-2014, 06:23 PM   #9
djliquidsteele
Drives: Scion FR-S
Run 0 cats with E85. Smells nice. Problem solved. Because Racecar!!
djliquidsteele is offline   Reply With Quote
Old 06-17-2014, 10:13 PM   #10
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
If it weren't for rasp and drone, I'd go catless.
With a V8 or turbo engine you can just weld in multiple resonators... not sure if that would sound nice with our cars.
Old 06-17-2014, 10:16 PM   #11
s2d4
s2d4's Avatar
Keep stock midpipe and CBE.
Old 06-17-2014, 10:26 PM   #12
BadBRZ
Drives: Subaru
there are thousands of holes in your cats ....
why would another one concern you?
BadBRZ is offline   Reply With Quote
Old 06-17-2014, 11:00 PM   #13
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Every flex fuel vehicle on the market today uses cats made of the same material and they dont have problems.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
unsurety (06-18-2014)
Old 06-19-2014, 07:21 PM   #14
djliquidsteele
Drives: Scion FR-S
I still have the stock header so I do have 1 cat, but I am running Motiv overpipe, motif catless mid pipe, and mach v dual exit muffler delete. I have no complaints about the sound. We'll see if I still think so once I go with a header.
I always refer to the Griffon Concept car though. Full catless and I absolutely love the sound.
cats, e85, melt, tune
Catalytic Converter recommendations lastexile1987 Engine, Exhaust, Transmission 13 06-01-2014 01:07 PM
Newb question regarding aftermarket catalytic converters BigFatFlip Engine, Exhaust, Transmission 9 03-24-2014 11:01 AM
Performamce Catalytic Converters. LBC Por Siempre Forced Induction 3 01-14-2014 05:43 PM
Header with Catalytic Converter ScionFR-S Engine, Exhaust, Transmission 21 09-21-2013 12:29 PM
Catalytic Converter question! destinharper Engine, Exhaust, Transmission 4 08-27-2013 09:56 AM
