Old 06-15-2014, 08:35 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
OFT glitching? can't flash
Not sure if I'm retarded butmy oft won't let me flash my og tune (or any for that matter). Says there's an error after the key on message. Anyone experience this? After I tried and failed I lost power steering and random lights like brake and abs were on, turned car off and on and it fixed.
I've had it for about 2k miles only but haven't flashed since I first got it.
I'll upload pics and video when I'm home. Phone is being difficult.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-15-2014, 08:49 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The only reasons for the OFT not being able to flash your ECU back to stock is if the OBD2 connector wasn't pushed in all the way or if the ignition power wasn't turned on fully (accessory power isn't enough). I suggest unplugging the OFT, turning off the ignition and starting again. I've seen cases were going straight from datalogging functions to flashing will cause a communication error since the ECU is still stuck in diagnostic/datalogging mode. Turn off the ignition and starting over will sort that out if that is the case.
Regards,
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 06-15-2014, 09:04 PM   #3
l0aded
Addicted
l0aded's Avatar
Regards,
Shiv
Thanks for the quick response. I'll give it a shot when I get home in case.
Old 06-15-2014, 10:02 PM   #4
l0aded
Addicted
l0aded's Avatar
Yup you were right. I pushed in the connections harder and flashed back to stock for dealer visit. Didn't realize how sensitive the obdii was. Thanks!
Old 06-15-2014, 10:58 PM   #5
Shiv@Openflash
Drives: 2013 FRS
Glad to be of help . Go enjoy your Sunday!
Old 06-15-2014, 11:13 PM   #6
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
I just absolutely love the support I see provided by Vishnu Tuning. So glad I went with OFT, CANT WAIT to receive mine!!
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 06-16-2014, 01:16 AM   #7
l0aded
Addicted
l0aded's Avatar
You'll have fun with it. After switching back to stock the difference is obvious lol. Can't wait to get my oil change over with and reflash.
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
HKS Flash Device xwd Software Tuning 1 11-23-2013 09:29 PM
ecu flash? jybrd Engine, Exhaust, Transmission 69 07-15-2013 03:36 PM
Why no ECU Flash? ngabdala Engine, Exhaust, Transmission 26 09-03-2012 07:27 PM
ECU flash drei CANADA 8 08-10-2012 01:31 PM
