Old 06-13-2014, 02:03 PM   #253
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Originally Posted by RiskyTrousers View Post
Haha, I didn't know LCAs where rated according to skill level! Nice jab.
Yes absolutely, a highly skilled driver can easily bend and destroy a weak LCA, both front and rear
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 06-13-2014, 02:04 PM   #254
CSG Mike
CSG Mike's Avatar
SPC has a long track record of parts failing on track. I've seen many failures in *person* on track. I will never recommend a SPC part to be used unless it is a last resort, or a piece that cannot possibly fail (camber bolt).
RehabJeff86 (06-13-2014)
Old 06-13-2014, 02:07 PM   #255
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
And with that I'm out.
Sorry for the high jack!
RiskyTrousers is offline   Reply With Quote
Old 06-13-2014, 02:09 PM   #256
CSG Mike
CSG Mike's Avatar
This is from one of our sponsored drivers' cars.
Failed SPC part on the right, SPL on the left
SPC on top, SPL on bottom.
fooddude (06-13-2014), RehabJeff86 (06-13-2014)
Old 06-13-2014, 02:13 PM   #257
gramicci101
Off Topic
So for a mild drop, say RCE Yellows, with a mild alignment for mostly DD with the very occasional auto-x, what do you recommend for rear camber? SPLs and Whitelines etc... are gorgeous and stout, but they're also a huge chunk of money.
I ask because FT-86SF has an RCE Yellow package deal with SPC camber bolts and RLCAs, but you have the option to upgrade to other RLCAs for additional money. And I really don't think my usage level justifies a $500 billet aluminum control arm.
Old 06-13-2014, 02:17 PM   #258
was385
Drives: MT WRB BRZ Limited, 2007 911s
Fr just RCE yellows I would say stock. You'll be right around 2 degrees of negative camber which is perfectly fine for street and autox.
was385 is offline   Reply With Quote
The Following User Says Thank You to was385 For This Useful Post:
gramicci101 (06-13-2014)
Old 06-13-2014, 02:21 PM   #259
gramicci101
Off Topic
I saw RCE recommending -1.75 or so in the rear, with just a hint of toe. -2 is close enough to -1.75, I guess.
Do you know how much adjustability there is with the OEM system? I'd prefer not to have -1.8 on one side and -2.1 on the other due to slack in the OEM tolerances.
Old 06-13-2014, 02:27 PM   #260
CSG Mike
CSG Mike's Avatar
The SPC part pictured above broke on a dip.
Old 06-13-2014, 02:30 PM   #261
M1K3
M1K3's Avatar
Drives: vrooom...
One question is - what SPC LCA was on Asabos car? Same as this below?
Attachment 81914
Aasbo is running the new version SPC LCA for the FRS/BRZ Here. The image your post had both old and new version. I run the new SPC LCA and think they are good for the street, but I totally agree with CSG Mike and think that the SPL stuff is the best stuff out there.
M1K3 is offline   Reply With Quote
The Following User Says Thank You to M1K3 For This Useful Post:
Old 06-13-2014, 02:52 PM   #262
RehabJeff86
Nonetheless, it is very impressive that SPC LCA is able to match with Asobo driving for the entire season, this says a lot.
Old 06-13-2014, 06:03 PM   #263
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Those SPL parts look serious. Like high quality baja/off-road race truck parts
fooddude is offline   Reply With Quote
Old 06-13-2014, 06:26 PM   #264
was385
There's no rear camber adjustment in the oem system unfortunately. I'm about .2 degrees off from left to right, which more than likely makes almost no difference in my times. Bottom line for me is that it just wasn't worth the $500 it would have cost to get a quality LCA.
Old 06-13-2014, 06:28 PM   #265
was385
I originally bought spc camber bolts and was having the performance shop around me throw them on while doing an alignment. When I made the appt, the guy told me to go out and get the OEM crash bolts to bring with me because they won't touch spc camber bolts anymore due to seeing them fail so often.
Old 06-13-2014, 07:34 PM   #266
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Do they touch whiteline bolts? Cuz they are the same part and people seem to run them no problem
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
Some observations Nardi330 AUSTRALIA 20 02-07-2013 06:18 AM
90 Day Anniversary ..some Observations Scooby South BRZ First-Gen (2012+) — General Topics 6 09-03-2012 11:17 AM
Mike's track videos. CSG Mike Tracking / Autocross / HPDE / Drifting 2 08-16-2012 04:00 AM
First Payment sent, Observations after 6 weeks. Scooby South BRZ First-Gen (2012+) — General Topics 27 08-01-2012 02:02 PM
