Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 07-24-2012, 02:48 AM   #1
Nardi330
Nardi330's Avatar
Drives: 86
Some observations
fitted the scangauge on the 86 over the weekend and observed a few things after a few days driving.
- the stock intake is quite good. on the move it's around 4-5 degree above ambient temperature (reading off the external temp figure of the factory dash). which is pretty much similar to what my old Type R with a CAI installed.
- the water temp gets up quite quickly. it shows about 80 degrees after around 5 minutes of normal driving. once it's warmed up it's around 90 degrees and stays there.
Nardi330 is offline   Reply With Quote
Old 07-24-2012, 03:10 AM   #2
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
Water temp rises quick due to the d-4s system for start-up benefits, port injector is used on the down stroke of the piston to create lean mixture then direct injector is used on the upstroke to correct the lean mixture and allows it to retard ign more than usual, increasing EGT and warming engine up quicker
jet86 is offline   Reply With Quote
Old 07-24-2012, 03:18 AM   #3
Nardi330
Nardi330's Avatar
Drives: 86
wow so technical!!!
Old 07-24-2012, 03:21 AM   #4
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
lol, i have to do my homework if im going to be boosting and tuning lol.
Old 07-24-2012, 03:22 AM   #5
JiB
JiB's Avatar
Drives: GT86
clever cookie indeed
JiB is offline   Reply With Quote
Old 07-24-2012, 03:35 AM   #6
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
Also im loving the fact that it only uses the direct port injector at high rpm, meaning there it more than enough fuel delivery between the 8 injectors for FI. Running only direct injector would mean the intake temps would be really REALLY low
Old 07-24-2012, 03:36 AM   #7
Nardi330
Nardi330's Avatar
Drives: 86
which means the engine is pretty efficient already!!
Old 07-24-2012, 03:50 AM   #8
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
probably should of studied it before i bought a ls7 crate motor lol.
Old 07-24-2012, 08:47 AM   #9
Blue86
Drives: Sonic Blue 86GT Manual
ahaahah awesome
Blue86 is offline   Reply With Quote
Old 02-06-2013, 03:07 AM   #10
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
dug this out of the grave to see if anyone here has played more with the scangauge, Ill have a mess when i have time, want to see if i can get oil temp up... the ecu does provide and you can program the scangauge to accept new gauges...
86•BRZ is offline   Reply With Quote
Old 02-06-2013, 03:16 AM   #11
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
My oil temp gets to 100 at normal motorway driving. Gets up to about 120 pretty quickly on the track and peaks at about 124. Others here have had oil temp at around 130 on the track with the more aggressive track drivers hitting a peak of 140.
Not using scan gauge though, usng HKS OB-Link.
All of the above are in Celsius.
Water temp for me is like above - hits and stays at around 90 Celsius.
nzer is offline   Reply With Quote
Old 02-06-2013, 04:05 AM   #12
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
cheers. I wonder if someone has the code for 86 oil temp for the scangauge... ill see what i can see..
Old 02-06-2013, 04:37 AM   #13
nzer
nzer's Avatar
As the scan gauge uses the OBD2 port it will read the usual stuff but the 86 or BRZ doesn't use the standard PID code but rather a specific Toyota/Subaru one.
@andreyiv found the oil temp PID and posted it here http://www.ft86club.com/forums/showp...&postcount=123
If you can add this into the scan gauge then you may be in luck.
Old 02-06-2013, 03:21 PM   #14
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
cheers, i might have some time tonight, see how i go
1st Oil Change Experience, Observations & a Surprise Black Tire Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 100 09-14-2015 09:23 PM
First Payment sent, Observations after 6 weeks. Scooby South BRZ First-Gen (2012+) — General Topics 27 08-01-2012 02:02 PM
