Old 06-05-2014, 07:41 PM   #71
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
9. Once all of them are removed you should be able to pull the hub assembly away from the car
This isn't going my way. Sensor 10mm bolt is off. 4, 14mm bolts from behind are off. Big 32mm axle nut is off. Am I missing something? This damn thing is not coming off!
Jaylyons1 is offline   Reply With Quote
Old 06-05-2014, 08:39 PM   #72
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Did you remove the sensor or just the 10mm bolt? You have to remove the sensor as well. You may have to hammer the axle out to free the hub assembly from the drum assembly.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-05-2014, 10:31 PM   #73
Jaylyons1
Jaylyons1's Avatar
Yea, I had everything removed. It really needed some lovin. I ended up having to pry it off with a flathead all around. The dirt/gunk made it difficult, but that one is done at least!
Old 06-06-2014, 04:16 PM   #74
jarednoel
Drives: Asphalt
Just had a wheel stud replaced last week on the back. Just so you guys know, you don't have to take off the axel nut to expose the studs. There are two threaded holes on the rotor/drum that you can use to insert a bolt that basically pushes it out evenly if you alternate one after another. Just don't know the size. I think it's the same for the front IIRC.
jarednoel is offline   Reply With Quote
The Following User Says Thank You to jarednoel For This Useful Post:
DAEMANO (10-11-2014)
Old 06-06-2014, 04:52 PM   #75
qoncept
qoncept's Avatar
Yep.
I don't know the size either. I know I don't have a bolt that fits.
qoncept is offline   Reply With Quote
Old 06-08-2014, 02:30 AM   #76
jflogerzi
jflogerzi's Avatar
Originally Posted by qoncept View Post
Yep.
I was doing this with a member. What he did was used a larger washer and then a nut that threaded on. Then used an open end lug nut and used an impact drill and just tighten which pulled the stud. No need to remove the hub and the threads were perfect. This guy is smart
The Following User Says Thank You to jflogerzi For This Useful Post:
Trap63 (06-08-2014)
Old 06-12-2014, 09:53 PM   #77
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
No need to remove hub if you're fitting stock or slightly longer than stock wheel studs. But if you're fitting the ARP studs for example, you'll definitely have to remove hub. But yes, tightening the studs with an impact wrench is waaay easier and faster than doing it manually.
Fizz is offline   Reply With Quote
Old 06-13-2014, 11:33 AM   #78
qoncept
qoncept's Avatar
I didn't have any problems fitting my ARP long studs with the hub in place.
The Following User Says Thank You to qoncept For This Useful Post:
Old 06-13-2014, 12:57 PM   #79
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Rear as well? How did u manage to wriggle it in with all the e-brake mechanism in the way? My nismo stud were only slightly longer than stock and it juuust squeezed in.
Old 06-13-2014, 01:25 PM   #80
qoncept
qoncept's Avatar
Oh, not rear. I only did the fronts.
Old 06-14-2014, 10:56 PM   #81
Frs123
Frs123's Avatar
Drives: Raven
Wheel stud replacement
Finally got around to install my Nismo studs. The fronts were very easy, I just hammered the old one's out and used the nut and washer method to install new studs. As you can see they're only 10mm longer than stock studs, which is more than sufficient for spacers up to that thick. Even without the spacers on I was able to use my Leggdura 35mm nuts with space to spare....no need to run ugly open ended nuts.
I haven't done the rears yet because they wouldn't fit without removing the hub...and i was too lazy to do all that. Will do the rears next weekend.
Anyway these wheel studs are perfect for those who want something stronger than OEM but without having extra long studs sticking out.
Where did you purchase the nismo stud?
Instagram: erik239
Frs123 is offline   Reply With Quote
Old 06-14-2014, 11:31 PM   #82
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Got them from japanparts.com but I've seen frsport.com selling them as we'll.
Old 06-14-2014, 11:32 PM   #83
Frs123
Frs123's Avatar
Drives: Raven
Thanks
Instagram: erik239
Old 06-23-2014, 06:02 PM   #84
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Might be a stupid question or I missed it somewhere but, do I need to put spacers on with these apr studs? I don't want to put them in just for them to be too long and not tight. Thanks!
texasbound972 is offline   Reply With Quote
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 05:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 03:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 11:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 03:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
