Old 06-12-2014, 04:12 PM   #15
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Originally Posted by Venator View Post
WHY!? Their lead time is ridiculous, and I get it. But why aren't there any others out there?
The answers are very simple.
A catted aftermarket header is just as illegal for carb as no cat at all.
A catted header is more expensive to manufacture and can't be ceramic coated on the inside
A Catted header is generally believed to produce less performance gains.
All of these reasons are powerful disincentives to develop and produce catted aftermarket headers.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following 2 Users Say Thank You to FrsDuke For This Useful Post:
Dephective (07-18-2014), juliog (06-12-2014)
Old 06-12-2014, 04:16 PM   #16
gramicci101
Off Topic
Originally Posted by OICU812 View Post
We need MORE (EL) catted options if anything.
P&L makes one.
Originally Posted by husker741 View Post
I'll sell you mine for $3k.
It's a seller's market, really. How much is it worth to them?
Old 06-12-2014, 04:37 PM   #17
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
HKS makes catted headers as well
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 06-12-2014, 05:00 PM   #18
Venator
Venator's Avatar
Drives: Asphalt FR-S
Well clearly the HUGE wait time for the FT86 Speed Factory should show that there is a consumer interest out there...
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 06-12-2014, 05:09 PM   #19
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
I will not pretend to be an expert at header development, however, my technical background has shown me that there are a number of ways to approach header design. JDL, Borla, Nameless, HKS, and FT-86SpeedFactory have all produced headers of different forms, producing different numbers and sounds.
At the end of the day a customer has to look at a company's customer service reputation, quality, design, performance and plug-n-play capability. I knew I wanted a catted header to pass visual inspection (the rest is more a wave of the hand if you know the right people...). I also chose UEL since I felt it better fit the platform, sound, and general upgrade path I have planned (no forced induction).
FT-86SpeedFactory has created a header that can work bolted on, with or without a tune. So for those looking to take one step at a time, it is ideal (tune later).
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 06-12-2014, 07:30 PM   #20
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Originally Posted by kiichiro View Post
My catted header sits on a shelf, cat is toast,literally it just a ball that will pass out thru the tail pipe one of these days
Avoid catted header.
So you ran lean and melted it or to rich and burned it up...........I wonder where the fault is at, the header or lack of / bad tune?
My Catted header works just fine, but it is an equal length header as I want performance over sound.
IceFyre13th is offline   Reply With Quote
Old 06-12-2014, 07:38 PM   #21
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Avoid poor quality catted headers
Fixed
Old 06-12-2014, 07:50 PM   #22
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
Not trying to sound like an ass here but this sentence doesn't make much sense. I get the decision for a EL header but if you wanted top end power that bad you would have gone uncatted for best results. Also UEL's have proven time and time again to make a ton of power especially JDL's UEL. it makes more peak power than many EL headers and being uncatted will probably perform just as well if not better than your catted EL.
JDL UEL on stock car + panel filter made ~188hp
HKS EL with full exhaust made ~195hp
edit: also see http://www.ft86club.com/forums/showp...postcount=1932 for FT86SF tuned tuned info to match up with tuned JDL UEL and HKS EL power numbers listed above.
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline   Reply With Quote
Old 06-12-2014, 10:19 PM   #23
jflogerzi
jflogerzi's Avatar
Some places require the same amount of cats as factory, here they do a visual inspection to make sure you have whatever was put in place by the factory.
If your going supercharger, Don't even worry about a header. Its a waste of money. Stick with stock. I rather dump money into a flex flue kit (if you have E85) which will net you way more power then a header.
The Following User Says Thank You to jflogerzi For This Useful Post:
jack43 (06-26-2014)
Old 06-12-2014, 11:06 PM   #24
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Because a cat that close to your engine block is robbing you of easy power.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 06-12-2014, 11:59 PM   #25
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
let's review 1 it is illegal to replace a catalytic converter unless it is defective that is federal law. 2 switching out to a header with a catalytic converter does nothing for power. so therefore 3 you're wasting your money go catless or don't go at all.
skye67 is offline   Reply With Quote
Old 06-13-2014, 12:06 AM   #26
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Ha, wow. You obviously have done no research or you are just plain ignorant.
husker741 is offline   Reply With Quote
The Following 4 Users Say Thank You to husker741 For This Useful Post:
EpicNameBro (06-13-2014), nunonuna (06-18-2014), Re~Mix (06-13-2014), tennisfreak (06-13-2014)
Old 06-13-2014, 12:07 AM   #27
husker741
It is most certainly not a waste of money. If I did any type of FI, the first thing I would change is the header.
The Following User Says Thank You to husker741 For This Useful Post:
Basket Case (06-13-2014)
Old 06-13-2014, 12:09 AM   #28
jflogerzi
jflogerzi's Avatar
Well then you have looked at many dyno's have you The headers do not add much on the supercharger side. Like I said Flex Fuel would be a much wiser choice
FT86Speedfactory Catted UEL Header review! (Photos and Videos) fender9530 Engine, Exhaust, Transmission 72 06-20-2019 11:16 AM
Catted Headers EN2_Squirrel Engine, Exhaust, Transmission 53 12-16-2016 09:52 PM
Top Speed Pro-1 Catted UEL Headers. Hotlava86 Engine, Exhaust, Transmission 64 08-17-2015 02:44 PM
Decision making for headers Ravenft86 BRZ First-Gen (2012+) — General Topics 19 07-01-2013 12:50 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
