CANADA Canada
Old 06-09-2014, 08:32 PM   #4145
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
I drove the car about 10km home and there wasn't any vibration, so I assumed everything was good. I'm about to go swap lug nuts since I forgot my "tuner" nuts at home. I'll check the bore of the wheels while I'm at it and see what I find online
HeadBanger is offline   Reply With Quote
Old 06-09-2014, 09:57 PM   #4146
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by HeadBanger View Post
Can somebody educate me on the whole hubcentric thing?
CarGuy explained it well, it's essentially a ring that allows the wheel to centre onto the hub, just like OEM wheels do.
Originally Posted by Simon99 View Post
Just from experience, I had a friend who forgot to put one ring back, although everything was tight, there was a wobble in the car. A 1$ ring/spacer from ebay solvef everything
The reason your friend had the wobble was because the lugs weren't seated properly before tightening.
Star pattern always, tighten a bit at a time and they'll seat well. I still prefer the rings though.
Slick is offline   Reply With Quote
The Following 2 Users Say Thank You to Slick For This Useful Post:
CarGuy (06-10-2014), HeadBanger (06-09-2014)
Old 06-09-2014, 11:32 PM   #4147
86gt?
86gt?'s Avatar
Drives: asphalt 86
^ This ^ Don't waste your time trying to find rings online unless they are specific to that exact wheel and obviously your bore size, I have bought or should I say have been sold the wrong sizes before and they are tough to match. I have used 10 + sets of rims without and only have issues. He must have had an issue with: a unbalanced tire, warped rim, blown belt, improper torquing or wrong lugs.
86gt? is offline   Reply With Quote
The Following User Says Thank You to 86gt? For This Useful Post:
CarGuy (06-10-2014)
Old 06-09-2014, 11:34 PM   #4148
HeadBanger
HeadBanger's Avatar
Thanks Andre!
Old 06-09-2014, 11:34 PM   #4149
86gt?
86gt?'s Avatar
Drives: asphalt 86
Originally Posted by Slick View Post
So did anyone make it to Calabogie for the show/cruise yesterday?
Pat was last to puss out before me! Haha. Think my cousin still made it in the work van!
Old 06-09-2014, 11:44 PM   #4150
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I know how to torque, maybe he didnt tho ? I only know that after getting thwm, he didnt have that wobble anymore !
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 06-10-2014, 12:43 AM   #4151
CarGuy
Track Rat
CarGuy's Avatar
Ditto when I have a set that fits. It's one less thing to worry about when I rotate my wheels at the track.
CarGuy
'12 BMW 128i (daily driver)
'14 Subaru BRZ (track car)
Racing is life. Anything before or after is just waiting. - Steve McQueen
CarGuy is offline   Reply With Quote
Old 06-10-2014, 11:31 AM   #4152
Slick
Slick's Avatar
St.Lac Results are up!
http://www.casc.on.ca/forums/showthread.php?t=29972
Good job Kenny on Day 1, fastest FT86 and 19th overall on PAX! STX Class.
Looks like Colin had some good competition too in CStock with other twins!
Good job guys! Way to represent.
The Following User Says Thank You to Slick For This Useful Post:
CarGuy (06-10-2014)
Old 06-10-2014, 06:00 PM   #4153
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Just got these in the mail. RCE TARMAC 2. Waiting for rear subframe bushings and Dunlop z2 tires before installing these. Should make quite a bit of difference.
vignesh is offline   Reply With Quote
The Following 3 Users Say Thank You to vignesh For This Useful Post:
CarGuy (06-10-2014), FRS_Ken (06-10-2014), Slick (06-10-2014)
Old 06-10-2014, 09:16 PM   #4154
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
I can make ABS plastic hub rings to custom fit your rims to our hubs
I made a set that were better than my supplied ones for a set of wheels once
You'd be surprised how strong they are and when they fit correctly they will last forever
I also take payment in Quiznos, pizza, wings or nachos
PM me if interested - I'd run one sample first to test fit based on dimensions I take off your wheel with digital calipers
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
FRS_Ken is offline   Reply With Quote
The Following 4 Users Say Thank You to FRS_Ken For This Useful Post:
86gt? (06-10-2014), CarGuy (06-10-2014), Simon99 (06-10-2014), UMB FR-S (06-10-2014)
Old 06-10-2014, 10:56 PM   #4155
CarGuy
Track Rat
CarGuy's Avatar
Niiiicce! I am seriously considering this setup. Will you be tracking the car after the install? If so I'd like you know your impressions
CarGuy
Old 06-10-2014, 11:25 PM   #4156
CarGuy
Track Rat
CarGuy's Avatar
I might be interested in a set.
Having said that; what I find frustrating with plastic rings is that they tend to loosen from the wheel and stick the front hub. It's caused by the ring design and the heat from braking on the track I figure. When I rotate wheels I often miss the fact that the front ring is stuck and then I try to mount the rear wheel with the ring still on it over top of the front ring.
One might say that if the front and rear rings were to remain on the hubs that would solve the problem. Technically, yes. But it would potentially cause another problem of the ring getting permanently stuck on the hub and having to break it off to remove it (yes I've had to do this) in order to put the stock wheels back on; for example.
What I'd like is a ring that stays on the wheel regardless of the heat conditions I put them through. I'm not sure it's possible but I'd be very interested in rings that remain with the wheel upon removal.
CarGuy
Old 06-10-2014, 11:26 PM   #4157
Slick
Slick's Avatar
I've driven a car with this coilover setup, and it handled very well, great spring rates and the damping was fantastic. It just did what you wanted, very neutral on track and did not seem unsettled at any point.
Old 06-11-2014, 12:04 AM   #4158
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Well, you'd want solid aluminum ones then
For normal dd use plastic should be fine
For my Mille Miglia Spiders they came with a really cheap plastic set of rings - I ended up ordering real aluminum ones that used a clip ring to retain them on the wheel - only ones I've seen like that since though
Someone with a simple lathe could turn you a set if you can't buy them directly from the wheel mfg
The Following User Says Thank You to FRS_Ken For This Useful Post:
CarGuy (06-11-2014)
