#4145 |
Drives: '14 Subaru BRZ
I drove the car about 10km home and there wasn't any vibration, so I assumed everything was good. I'm about to go swap lug nuts since I forgot my "tuner" nuts at home. I'll check the bore of the wheels while I'm at it and see what I find online
#4146 | |
Drives: FR-S Firestorm 6MT
CarGuy explained it well, it's essentially a ring that allows the wheel to centre onto the hub, just like OEM wheels do.
Star pattern always, tighten a bit at a time and they'll seat well. I still prefer the rings though. Last edited by Slick; 06-09-2014 at 09:50 PM. |
| The Following 2 Users Say Thank You to Slick For This Useful Post: | CarGuy (06-09-2014), HeadBanger (06-09-2014) |
#4147 |
Drives: asphalt 86
^ This ^ Don't waste your time trying to find rings online unless they are specific to that exact wheel and obviously your bore size, I have bought or should I say have been sold the wrong sizes before and they are tough to match. I have used 10 + sets of rims without and only have issues. He must have had an issue with: a unbalanced tire, warped rim, blown belt, improper torquing or wrong lugs.
| The Following User Says Thank You to 86gt? For This Useful Post: | CarGuy (06-09-2014) |
#4148 |
Thanks Andre!
#4149 |
Drives: asphalt 86
#4150 | ||
Drives: 2013 BRZ Limited WRB
#4151 |
Track Rat
Ditto when I have a set that fits. It's one less thing to worry about when I rotate my wheels at the track.
CarGuy
'12 BMW 128i (daily driver) '14 Subaru BRZ (track car) Racing is life. Anything before or after is just waiting. - Steve McQueen |
#4152 |
St.Lac Results are up!
http://www.casc.on.ca/forums/showthread.php?t=29972 Good job Kenny on Day 1, fastest FT86 and 19th overall on PAX! STX Class. Looks like Colin had some good competition too in CStock with other twins! Good job guys! Way to represent. |
| The Following User Says Thank You to Slick For This Useful Post: | CarGuy (06-10-2014) |
#4153 |
Engineer
Drives: WRB 2022 Subaru Brz
Just got these in the mail. RCE TARMAC 2. Waiting for rear subframe bushings and Dunlop z2 tires before installing these. Should make quite a bit of difference.
#4154 |
((•||=(86)=||•))
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
I can make ABS plastic hub rings to custom fit your rims to our hubs
I made a set that were better than my supplied ones for a set of wheels once You'd be surprised how strong they are and when they fit correctly they will last forever I also take payment in Quiznos, pizza, wings or nachos ![]() PM me if interested - I'd run one sample first to test fit based on dimensions I take off your wheel with digital calipers
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
#4155 |
Track Rat
Niiiicce! I am seriously considering this setup. Will you be tracking the car after the install? If so I'd like you know your impressions
CarGuy
#4156 | |
Track Rat
Having said that; what I find frustrating with plastic rings is that they tend to loosen from the wheel and stick the front hub. It's caused by the ring design and the heat from braking on the track I figure. When I rotate wheels I often miss the fact that the front ring is stuck and then I try to mount the rear wheel with the ring still on it over top of the front ring. ![]() One might say that if the front and rear rings were to remain on the hubs that would solve the problem. Technically, yes. But it would potentially cause another problem of the ring getting permanently stuck on the hub and having to break it off to remove it (yes I've had to do this) in order to put the stock wheels back on; for example. What I'd like is a ring that stays on the wheel regardless of the heat conditions I put them through. I'm not sure it's possible but I'd be very interested in rings that remain with the wheel upon removal.
CarGuy
#4157 |
I've driven a car with this coilover setup, and it handled very well, great spring rates and the damping was fantastic. It just did what you wanted, very neutral on track and did not seem unsettled at any point.
#4158 | |
((•||=(86)=||•))
For normal dd use plastic should be fine For my Mille Miglia Spiders they came with a really cheap plastic set of rings - I ended up ordering real aluminum ones that used a clip ring to retain them on the wheel - only ones I've seen like that since though Someone with a simple lathe could turn you a set if you can't buy them directly from the wheel mfg
| The Following User Says Thank You to FRS_Ken For This Useful Post: | CarGuy (06-10-2014) |
