Old 06-10-2014, 01:16 PM   #1
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
'Quiet' Header
I've done a lot of research and I know a header is a great way to increase power and remove the TQ dip (or at least lessen it)
I have an ARK DT-S exhaust and ARK test pipe and I love the sound but I don't want to go too much louder. From what I've see all headers are making our cars significantly louder and that's just not my style. Any recommendations for a 'quiet' header or a way to take the noise level down a notch after a header install?
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 06-10-2014, 01:17 PM   #2
Raven604
Ft86speedfactory header is probably your best bet
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 06-10-2014, 01:24 PM   #3
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Ensuring the header is catted is the one thing that will keep it quieter than most
ToyoburuBRZ is offline   Reply With Quote
Old 06-10-2014, 01:40 PM   #4
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Stock...
Even the FT86 Speedfactory header is fucking loud when paired with the wrong exhaust, basically unless you go with one of the quietest exhausts on the market (Q300, or Perrin) your car will get signifigantly louder with ANY aftermarket header.
Especially on cold starts.
Decay107 is offline   Reply With Quote
Old 06-10-2014, 01:45 PM   #5
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
When I added my FT86SpeedFactory catted header, I just wanted the sound to change and not get much louder. Before that, I had their V1 unresonated catback, Invidia catted front pipe, and a Perrin overpipe. When I added the header, I went with the resonated midpipe. Volume might have increased by like a few decibels, but it mainly changed the sound to more of the UEL boxer rumble, which is exactly what I wanted. So if you are resonated, the header should do the same thing for you as it did for me.
Hope this helps. You can go to my build page in my sig to hear the exhaust set up. I have some from my previous setup without the header, and then new videos with my new set up. That should help you compare.
husker741 is offline   Reply With Quote
Old 06-10-2014, 02:39 PM   #6
P@ul
Apostle
P@ul's Avatar
Drives: JesusMobile
You'll probably have to change your test pipe to a resonated or catted one.
P@ul is offline   Reply With Quote
Old 06-10-2014, 02:57 PM   #7
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Thanks the responses, My test pipe does have the 'Helmholtz' style resonator on the test pipe and catback.
The DT-S is one of the more quiet exhausts I think, I guess its worth a shot and if its too loud ill add in more resonators.
Old 06-10-2014, 03:32 PM   #8
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Wow I just watched the FT86speedfactory video with a full exhaust, that thing is bloody loud!
But I'm impressed that it removed the dip with no tune, if only the factory could of thought of that.
Old 06-10-2014, 03:54 PM   #9
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
I drove with my FT86SF V1 CBE, stock o/p, stock f/p and the FT86SF header for about 15 miles before i put my Nameless combo pipe on and im pretty sure majority of the volume came from me installing my nameless combo pipe. the header seamed to only had a very small amount of volume but gave more of the UEL rumble. even now my exhaust is pretty tame until you get on it. at idle is as quiet as stock.
im willing to bet that your set up with a catted header wont get much louder at all
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline   Reply With Quote
The Following User Says Thank You to Sypher For This Useful Post:
SpeedyJay (06-10-2014)
Old 06-10-2014, 04:04 PM   #10
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
That'll help you with drone, not so much with volume.
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline   Reply With Quote
Old 06-10-2014, 04:12 PM   #11
akahenry
akahenry's Avatar
Drives: '18 STi
Man up and go with a Catless UEL Header :3.
Just change your cat back to something quieter, also get a front pipe that's catted and resonated. Less rasp & volume if paired with a catless header. If you're a Subaru guy and like the rumble, a catless UEL is where it's at for the defined rumble; catted UEL's barely have any rumble/ aren't as pronounced as catless UEL's. If you really want a quiet header, just cut the cats out of the stock headers- the stock headers are designed quite well, it's just the cats that are restricting some extra performance.
akahenry is offline   Reply With Quote
The Following User Says Thank You to akahenry For This Useful Post:
Chad86 (06-03-2016)
Old 06-10-2014, 04:25 PM   #12
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
You might as well just say "the ft86 speed factory UEL header has no rumble".
Because other than the HKS UEL "Catted" header, there are no other options.
and its the length of the runners that make the "rumble". It has nothing to do with the cat.
Actually that entire post has bad information.
If you remove the cat and weld what you need. The exhaust is going to be loud.
Old 06-10-2014, 04:42 PM   #13
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
^Yes that's what I was thinking too
I wonder if going back to an OEM f/p would negate any gains from an aftermarket header.. it would sure keep the noise down a notch.
Old 06-10-2014, 05:26 PM   #14
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Actually looking at the dyno chart FT86SF provided they made the gains with a completely stock car.
http://www.ft86club.com/forums/showthread.php?t=52835
So maybe a Catted header - OEM over pipe - OEM front pipe - and a 'quiet' aftermarket catback would be more inline with my goals.
quiet and loud exhaust both in 1 JonMotoring Engine, Exhaust, Transmission 28 04-24-2020 02:22 PM
Quiet sway bars protpibe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 03-03-2016 09:51 PM
B Quiet Sound Dampening RandomHero Electronics | Audio | NAV | Infotainment 13 02-20-2013 09:54 PM
WA orders gone quiet? Bounce AUSTRALIA 8 12-05-2012 12:54 AM
Quiet exhaust s2kdrew Engine, Exhaust, Transmission 21 06-25-2012 11:22 PM
