Old 06-09-2014, 10:50 PM   #15
wparsons
wparsons's Avatar
That's nothing That's not really uneven wear at all, just using more of the tire width. It doesn't look bad at all. If you see a major difference in tread depth, or are wearing way over onto the shoulder then you should change something, but based on the pictures I wouldn't worry at all.
From last year, I've got some wear another 1/4" into the triangle now, camber bolts maxed out, swift sport springs, running about 37psi cold.
flickr
1Cor10:23 (06-09-2014)
Old 06-09-2014, 11:38 PM   #16
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
If anyone's interested - here's some gopro footage of one of the later sessions that day. Remember, I'm a complete noob!
[ame="https://www.youtube.com/watch?v=y-pGmDUDMbE"]New 2014 MOSPORT DDT | Scion FR-S | Gopro footage - YouTube[/ame]
1Cor10:23 is offline   Reply With Quote
Old 06-10-2014, 01:51 AM   #17
CSG Mike
CSG Mike's Avatar
You're not wearing the tires too badly, but you definitely need more camber.
RaceSeng camber/caster plates for the front, SPL LCA for the rears. You won't outgrow either one, and you'll get the camber you need now.
High end dampers are available as just dampers without top hats; all you need is the spring perch, bushing/bearing, and top nut ($160 total), and you continue to use your RaceSeng plates.
1Cor10:23 (06-10-2014), wparsons (06-10-2014)
Old 06-10-2014, 02:37 AM   #18
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Please don't wear motorcycle helmets, get a proper Snell approved helmet designed for cars..and, the outside wear looks normal considering the amount of camber..
glamcem is offline   Reply With Quote
Old 06-10-2014, 03:31 AM   #19
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'm far from convinced that, short of a HANS-equipped helmet, anything over a cheap DOT helmet is really going to make a difference. I don't have a roll bar. I don't have a turbo or flex fuel kit to burn the car to the ground. SA helmets cost more, usually have less visibility, and definitely offer less choice. I HATE my SA2005 Pyrotect. The only reason for a beginning driver to get an SA is, from what I can tell, to allow them to drive in events that require an SA helmet. It just sounds like a marketing scam more than anything. Not like Snell has a perfect history of testing. The 2005 designs are supposedly unsafe in smaller helmets.
Old 06-10-2014, 04:13 AM   #20
glamcem
glamcem's Avatar
you don't need to have a roll bar to benefit from a helmet specifically designed to take multiple hits (as opposed to one single impact with motorcycles) and even stock cars can catch a fire in an accident..
Old 06-10-2014, 04:48 AM   #21
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
The HJC AR-10 he's wearing is an SA Snell rated helmet that has attachment points built in for HANS device; the logo on the back is specific only to the HJC automotive racing helmet line - hence HJC Motorsports moniker. Know your helmets...
Tire wear looks absolutely normal...barely scuffed in.
OP... one suggestion would be using your gearbox more. Is there a particular reason you really didn't shift at all after getting on track, going into slower turns with the engine in the absolute worst part of the torque dip? Being in the correct rpm range makes a difference in how the car sets the chassis to turn in. The car won't turn as well when bogged down verses when you are in the power band and able to control the yaw much better. You need weight transfer to better control turn in...whether under braking or acceleration - being in the torque dip range is not good for weight transfer.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 2 Users Say Thank You to Vracer111 For This Useful Post:
1Cor10:23 (06-10-2014), glamcem (06-10-2014)
Old 06-10-2014, 06:22 AM   #22
CSG Mike
CSG Mike's Avatar
The two go through the same testing; unless you're in a race car, there's no appreciable difference.
The difference in testing standards is fire resistance (non-issue unless you mess with your fuel system), and multiple impacts (to simulate hitting your cage/roll bar).
The difference in design is the opening for the visor; motorcycle helmets typically have superior visibility.
Old 06-10-2014, 07:52 AM   #23
1Cor10:23
1Cor10:23's Avatar
@Vracer111 thanks for the comments - Yup, didn't shift much, this was my first time out, and decided to work on lines and keep it simple that's a a great point you bring up about how it affects balance and turn-in, hadn't thought about that.
Old 06-10-2014, 08:54 AM   #24
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
wear doesn't seem that bad
but given the amount of offs you had it did seem like you scrubbed yourself off the course a number of times... curious why you simply didn't apply brakes and went on your way?
keep an eye on those hot pressures. Too much air in a street tires for many laps (and it was also a hot day) will wear them much quicker.
Old 06-10-2014, 09:03 AM   #25
DarkSunrise
DarkSunrise's Avatar
Interesting point on the triangles. I noticed the other day that the triangles on my front tires are almost worn out, and I've got some chunking on the outer tread blocks.
I think I need to put some camber bolts on my car before my next track day and probably inflate my tires higher as well.
2022 BRZ Build
2013 FR-S Build
Old 06-10-2014, 09:10 AM   #26
1Cor10:23
1Cor10:23's Avatar
I'd attribute it just to inexperience, wasn't comfortable slamming I the brakes. ABS was kicking pretty hard during the day, I'm still on stock brakes and lines. Will look to upgrade these before I heard out again. Thanks for your comment!
Old 06-10-2014, 09:40 AM   #27
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
not ABS, it was your traction control, which you've left on, if you look at your own video you can see the thing blinking every time it engages.. which was a lot
while it can certainly keep you safe in a structured environment, I would suggest you start practicing with it off as soon as possible, those counter-steer skills and feeling the back end coming loose are absolutely vital
having said that my first time in the car at MIR I left everything on, lol
The Following 3 Users Say Thank You to 7thgear For This Useful Post:
1Cor10:23 (06-10-2014), CSG Mike (06-10-2014), wparsons (06-10-2014)
Old 06-10-2014, 09:56 AM   #28
1Cor10:23
1Cor10:23's Avatar
@7thgear thanks man - gobbling up all the advice I'm getting, this is why I love this forum community.
Suspension settings for different size tires Pokeguyjai Tracking / Autocross / HPDE / Drifting 2 01-24-2014 03:44 PM
STOCK TIRES CHEAP ! $200 Local Pickup ONLY ! NO WEAR ! BRAND NEW ** ScionFR-S Wheels and Tires 4 11-08-2013 09:28 AM
Suggest some blue wheels SillySaxon Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-22-2013 04:55 PM
Wheels tires suspension chassis brakes Calum Site Announcements / Questions / Issues 1 07-15-2012 11:14 AM
