Old 06-08-2014, 03:57 PM   #1
HRTROB
HRTROB's Avatar
Drives: Toyota 86
DIY: FR-S and GT86 Amber cluster backlight (no soldering)
Hey guys just want to share what I did today. I used some translucent amber sheets to change the color of the gauges from white to amber. Here are the pros and cons of this mod before you decide to try it out for yourself..
Pros:
-100% reversible
-no need to remove the needles and risk messing up the needle motors
-dirt cheap
-relatively easy to do
Cons:
-backlight is a little dimmer compared to stock, but not by much. This can be a pro because since the backlight is a little dimmer, the Shift light is now more noticeable.
DISCLAIMER: I am not responsible if you f*ck something up. Do this mod at your own risk. It should be really easy if you're handy with a pair of scissors
Follow the DIY on removing the cluster hood here:
[ame="https://www.youtube.com/watch?v=3NU5ba3ChgM"]Remove the Gauge Cluster of FR-S, BRZ - YouTube[/ame]
And how to disassemble the cluster itself: http://www.ft86club.com/forums/showthread.php?t=58207
Once the cluster is disassembled, you will have something like this
Now you need to find something that will change the light from white to amber. I used a "clear book" folder I bought from an office supplies store. It's a folder with a translucent cover and clear plastic sheets inside that you can stuff documents into. Cost me 45 pesos or 1 US Dollar
As you can see, it changes white light to amber
Begin by cutting a pattern similar to the one in the photo. Use a sharpie to mark where you need to cut.
You will end up with something like this
Now repeat the same thing for the tach. Make sure you don't cover any of the warning lights
And finally the fuel and temperature gauges
Slide the amber "diffusers" underneath and use some tape to secure them
Reassemble everything and enjoy the fruits of your labor
Matches my Defi Advance CR gauges really well
Comparison of the stock tach and modded speedometer
HRTROB is offline   Reply With Quote
The Following 9 Users Say Thank You to HRTROB For This Useful Post:
Createddeleted (06-08-2014), draggin_az (06-09-2014), illicitstylz (06-08-2014), JonAvalon (06-09-2014), Pekingduck (06-28-2014), Sarlacc (06-10-2014), SkAsphalt (06-10-2014), Trap63 (06-08-2014), Tye300 (06-17-2014)
Old 06-08-2014, 06:28 PM   #2
Createddeleted
Drives: 2014 BRZ - 2004 GLI
Nice simple diy!
Createddeleted is offline   Reply With Quote
Old 06-08-2014, 06:45 PM   #3
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
Didn't know what to expect but I like it a lot! Nicely done.
mikeTee is offline   Reply With Quote
Old 06-08-2014, 06:52 PM   #4
kALMIGHTY
Drives: TRD Ultramarine '13
If I ever do this, I'll do blue!
Old 06-09-2014, 02:57 AM   #5
HRTROB
HRTROB's Avatar
Drives: Toyota 86
^ I'm curious as to what it will look like with blue. I used the same method to change the backlight of the Defi boost gauge in my 90s Land Cruiser from white to green. Turned out great too!
Old 06-09-2014, 03:28 AM   #6
suaveflooder
siiiiiiiiiiiiiiiiiiick!!! Nicely done!
suaveflooder is offline   Reply With Quote
Old 06-09-2014, 07:38 AM   #7
CatDaddysBBQ
Drives: '13 FR-S
That's pretty nice, though it reminds me of 90's pontiacs with all that orange, lol. Great idea on using the folder.
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
roddy (06-10-2014)
Old 06-09-2014, 11:31 AM   #8
Slonie
Slonie's Avatar
Drives: Only ridiculous cars
Green would be appropriate for the early-model AE86 look...
Slonie is offline   Reply With Quote
Old 06-09-2014, 11:35 AM   #9
TM
TM's Avatar
Drives: DGM BRZ 6MT
Wow, very creative!
TM is offline   Reply With Quote
Old 06-10-2014, 12:06 AM   #10
Tony Mac
Tony Mac's Avatar
Drives: SWP BRZ
That folder cover looks a bit thick. Try some lighting gels from Rosco or Lee, usually available from your local camera store.
http://www.adorama.com/catalog.tpl?o...Feature1=Rosco
Tony Mac is offline   Reply With Quote
The Following 2 Users Say Thank You to Tony Mac For This Useful Post:
roddy (06-10-2014), sshole (06-10-2014)
Old 06-10-2014, 08:21 AM   #11
sshole
I used a Rosco lighting gel (cut to size) to dim my high beam indicator. That bitch was bright, now it's tolerable.
sshole is offline   Reply With Quote
The Following User Says Thank You to sshole For This Useful Post:
Bg8780 (06-10-2014)
Old 06-10-2014, 10:10 AM   #12
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
thats a great idea. the lights are too bright on the dash anyway lol i cant stand the 8 different colors they use
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 06-10-2014, 02:13 PM   #13
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
That looks awesome!
Thanks for sharing :-)
Old 06-10-2014, 07:31 PM   #14
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Originally Posted by Sarlacc View Post
That looks awesome!
Came in here because best username I've seen on this site yet.
HeadBanger is offline   Reply With Quote
The Following User Says Thank You to HeadBanger For This Useful Post:
Sarlacc (06-11-2014)
led cluster help Grip Ronin Cosmetic Modification (Interior/Exterior/Lighting) 12 02-14-2014 12:29 PM
Daytime dash backlight k0tkmnd Electronics | Audio | NAV | Infotainment 1 10-18-2013 07:01 PM
Soldering questions Xdragonxb0i Electronics | Audio | NAV | Infotainment 12 01-21-2013 01:22 AM
