Old 06-09-2014, 10:25 PM   #29
bjun
bjun's Avatar
Drives: white premium brz M/T
Originally Posted by carbonBLUE View Post
my leak isnt from here though :/ its form the front, top side not bottom
Try checking the cam cover
bjun is offline   Reply With Quote
Old 06-13-2014, 12:29 AM   #30
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Due to the oil leak being on the front passenger side of the motor I am finally getting it into another dealership on saturday. I got my car on a lift and it doesn't seem to be leaking from the cam plate... yet. It actually looks like the head gasket is leaking (I know it's a subaru) so the dealership has a set in stock just encase that is the issue.
Sent from my Q10
Old 06-13-2014, 10:17 AM   #31
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
There is a reason the new 2015 sti wrx has a different motor
Mine leaks same spot
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-17-2014, 08:57 AM   #32
vgi
Drives: frs
any updates, has anyone got it fixed?
has anyone who's FI tried going to the dealer and see if it can be fixed under warranty?
also, has anyone tried using stop leak?
vgi is offline   Reply With Quote
Old 06-17-2014, 07:38 PM   #33
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
mine must have been over-time, very slow leak. since the oil change i have not seen any new leaks.
i did however find a leak in my rear dif today when i changed the fluid. :/
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 06-17-2014, 08:54 PM   #34
calibrz
Turbo 86
Drives: GT86
can this be a recall?
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 09-17-2014, 12:46 PM   #35
4ak086
Drives: Toyota Gt86 MT
have the same leak at the driver's side. i check the cam plate- its dry and cam plate is on the passenger's side. sitting in toyota dealership now and waiting for something..
i had a massive leak . also had a smoke
4ak086 is offline   Reply With Quote
Old 09-17-2014, 02:57 PM   #36
bjun
bjun's Avatar
I fixed mine but I think my setup is a little different from stock 86s. I have a t-fitting oil line running on top of the cam cover and that's where the oil was leaking. All I had to do was retape with teflon tape
Old 09-28-2015, 01:41 AM   #37
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by choi0706 View Post
this is where the leak is..
That is where mine is leaking... Did you get yours fixed? And if so, how much did it cost to fix it?
Astroboy is offline   Reply With Quote
Old 09-28-2015, 10:43 AM   #38
aagun
Drives: 86
common leak
google it
aagun is offline   Reply With Quote
Old 09-28-2015, 10:45 AM   #39
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by aagun View Post
common leak
google it
I did Google it, and I came across this. Please, if you're not going to help, don't instigate.
Sent from my LG-D850 using Tapatalk
Old 09-28-2015, 10:46 AM   #40
Astroboy
Astroboy's Avatar
Drives: None
common leak
google it
Or at least give me some links, because I only came across this and some cam plate leaks. Thanks
Old 09-28-2015, 11:43 AM   #41
aagun
Drives: 86
4 cam sensor o ring
4 avsc controller o ring
sealant leaked area after spot it and it is same with all 86
Old 10-03-2015, 12:51 AM   #42
Astroboy
Astroboy's Avatar
Drives: None
Any ideas on where it might be leaking from? My friend says it's the valve cover, I say it's either the timing belt cover or the block behind the valve cover', where the valves and valve springs meet..
Water Leak inside passenger side floorboard AtlasMick Issues | Warranty | Recalls / TSB 30 03-28-2019 05:43 PM
New Body Parts from WORKS WORKS Exterior Parts - The Rest 2 06-13-2014 07:58 PM
Tranny fluid or engine oil leak? G.I.Choe Issues | Warranty | Recalls / TSB 1 05-28-2014 07:53 AM
Small Oil Leak under center of engine? brillo Issues | Warranty | Recalls / TSB 6 11-09-2013 10:52 PM
Wanted: drivers side front fender Yruyur Miscellaneous 0 11-26-2012 10:30 PM
