Old 06-09-2014, 08:20 PM   #57
CatDaddysBBQ
Drives: '13 FR-S
Originally Posted by SubieNate View Post
I hate you just a little bit right now.
Btw - from a fellow "Nate" to another, I feel your pain and I'm just plain old sorry!
CatDaddysBBQ is offline   Reply With Quote
Old 06-09-2014, 08:26 PM   #58
fatoni
Originally Posted by CatDaddysBBQ View Post
I dunno, these cars are pretty light, they won't need too much width to grip hard. I love light wheels - the feeling is incredible. Like running in boots and trading up for proper running shoes - feels so much better.
It's not just for grip. Having more volume inside the tire and tighter side wall make for a much more stable tire. I can tell you that the frs can definitely make use of more rim. Whether you want that improvement is something I can't argue with
The Following User Says Thank You to fatoni For This Useful Post:
CatDaddysBBQ (06-10-2014)
Old 08-27-2014, 12:48 PM   #59
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Subbed
hmong337 is offline   Reply With Quote
Old 08-27-2014, 02:28 PM   #60
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
Originally Posted by SkAsphalt View Post
So So cheap...but will they clear brembos...
Just to play devil's advocate...
Why are you worried about saving 2 or 3 lbs on wheels if you are going to bolt on brembo's and add like 10lbs to each front corner?
just curious..
eikond is offline   Reply With Quote
Old 08-27-2014, 02:37 PM   #61
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I think the brembo BBKs weigh less than the OEM brakes.
-Jack Burton
Old 08-27-2014, 03:14 PM   #62
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
just curious..
You know when athletes put on muscular weight its good, but when they put on fat its bad? That's like this. Saving weight on the wheels while increasing breaking capabilities is a win win.
I have done the weight comparisons, and going to a lighter wheel and the brembo front brakes can basically equal out at OEM weight if you do it right.
Old 08-27-2014, 03:32 PM   #63
Luis_GT
just curious..
rotational mass vs static mass.
Old 08-27-2014, 05:06 PM   #64
Foobar
SLO NO MO
Foobar's Avatar
Ding ding ding. This right here.
Old 08-27-2014, 07:44 PM   #65
eikond
eikond's Avatar
umm.. not in this case. The rotor and wheel are tied together and are both rotational.
The stock BRZ rotors are 17.1 lbs each. I think the Brembo is like 26 lbs.
So you're gaining 9 lbs of rotational mass. Plus.. I believe the Brembo calipers are couple lbs heavier than the stock calipers so you're gaining some extra static mass as well.
Old 08-27-2014, 07:47 PM   #66
eikond
eikond's Avatar
Are you sure Brembo's are in increase in braking capability? Have you done any bias calculations? They will certainly keep cooler and resist brake fade. But based on what I've researched, they harm the brake bias and could actually lead to longer stopping distances.
Just curious...
Old 08-27-2014, 08:02 PM   #67
D_Thissen
D_Thissen's Avatar
Subbed
Old 08-27-2014, 08:04 PM   #68
ZionsWrath
Thanks
ZionsWrath's Avatar
Which Brembo? Brembo BBK or STI brembo swap?
Old 08-27-2014, 08:10 PM   #69
eikond
eikond's Avatar
Ah.. that might be the source of confusion.. I assumed he was thinking about the STI Brembo conversion.
If it's the GT BBK, then I think the 2 piece rotors are pretty close in weight to the stockers.. and that would be a good option.
Old 08-27-2014, 10:03 PM   #70
mike the snake
I think Apex is making wheels for our twins now.
I had them on my BMW and they were one of the lightest available.
http://www.apexraceparts.com/apex-pr.../#.U_6OJ6Oy2ig
Wheels similar to Technic mesh wheels on bmw's DYOLF26 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 04-26-2017 10:29 AM
What are the lightest wheels for this car? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 10-15-2014 05:56 PM
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 09:26 AM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
Top 10 Lightest 300 Horsepower Cars Axel Other Vehicles & General Automotive Discussions 2 11-22-2009 02:23 AM
