Old 06-27-2012, 06:28 PM   #1
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
What are the lightest wheels for this car?
I would like to start a table with weight and price. 17s,18s, and 19s
16"
17"
RS Watanabe F8 Magnesium
Offset: +40mm
17x8
Weight: 12.8 lbs.
RS Watanabe F8F Magnesium
Offset: +40mm
17x7
Weight: 13.2 lbs.
Kosei K4R
Offset: 50mm
Backspacing: 5.94"
Rec. Tire Size:215/45-17
Weight: 14.0lbs.
Motegi Traklite
Offsett:+42
17x7
Weight: 14 lbs.
Kosei K1-TS
Offset: +50mm
17x7
Weight: 14.6 lbs.
SSR Type-C
Offset: +49mm
17X7.5
Weight: 14.9Lbs
OZ Alleggerita HLT
Offset: 48mm
Rec. Tire Size:225/45-17
Weight: 15.1lbs.
Enkei Racing RPF1
Offset: +48mm
Backspacing: 6.10"
Weight: 15.2lbs.
Stock
20.1lbs
18"
OZ Alleggerita HLT
Offset: +48mm
Backspacing: 6.18"
Rec. Tire Size:225/40-18
Weight: 16.2lbs.
quik1987 is offline   Reply With Quote
The Following 7 Users Say Thank You to quik1987 For This Useful Post:
adprokid (08-24-2012), Anthony (08-22-2013), Bullnettles (06-07-2013), Chad (09-04-2012), diss7 (08-06-2013), flippy (08-26-2013), G_Ride (08-30-2013)
Old 06-27-2012, 06:57 PM   #2
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
SSR Type-C are also a very light weight option.
17X7.5 +49 are 14.9Lbs
RallySport Direct is offline   Reply With Quote
Old 06-27-2012, 07:17 PM   #3
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Too bad the new colors suck (IMHO of course)
uspspro is offline   Reply With Quote
The Following User Says Thank You to uspspro For This Useful Post:
Lawnik (06-08-2013)
Old 06-27-2012, 08:03 PM   #4
xwd
Probably want to specify widths as well.
Motegi Traklite's in 17x7 +42 are 14 lbs.
Kosei K1-TS 17x7 +50 are 14.6 lbs.
Old 06-27-2012, 08:08 PM   #5
coyote
coyote's Avatar
Drives: Slowly
Yes, weight is pretty useless without it.
coyote is offline   Reply With Quote
Old 06-27-2012, 08:42 PM   #6
UncleFester
Comparing the same width?
UncleFester is offline   Reply With Quote
Old 06-28-2012, 12:09 AM   #7
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
Will 16'' not fit the FRS?
2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily
Asterisked Accolade is offline   Reply With Quote
Old 06-28-2012, 12:40 AM   #8
quik1987
quik1987's Avatar
Thanks, keep em coming. I will try to improve and get all the specs, price, and pics eventually
Old 06-28-2012, 12:42 AM   #9
quik1987
quik1987's Avatar
They do, and are an option in Japan.
But stock is 17" in usdm
If you have specs on wheels that fit the car, I will put them in.
Old 06-28-2012, 12:44 AM   #10
jamal
jamal's Avatar
Drives: Legacy GT
Sure will. Swap to Subaru 4-pots and there are even some 15s that will work.
jamal is offline   Reply With Quote
Old 06-28-2012, 12:48 AM   #11
Asterisked Accolade
Awesome, because 16x7 Enkei RPF1s are only 13.2lbs. The PF01s are 14lbs. Hell, even the Alleggerita HLTs are 13.6lbs.
The Following User Says Thank You to Asterisked Accolade For This Useful Post:
WRB-DZA-BRZ (06-28-2012)
Old 06-28-2012, 12:57 AM   #12
Jimbo
Jimbo's Avatar
Drives: 92 NSX, 08 Accord
And what are the stock weights for comparison?
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ)
2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold)
2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue
Jimbo is offline   Reply With Quote
Old 06-28-2012, 01:01 AM   #13
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
The spare donut
rcm47 is offline   Reply With Quote
The Following User Says Thank You to rcm47 For This Useful Post:
Nasty Sausage (01-20-2014)
Old 06-28-2012, 02:01 AM   #14
yuli8466
Drives: MX5
I remember it is 20.5lbs or 21lbs.
I have seen it before, at this forum. someone has posted, through pictures.
yuli8466 is offline   Reply With Quote
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
TRD Wheels Re~Mix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 06-27-2012 06:11 PM
Forgestar wheels, great wheels at great prices!!!! IslandImportPerformance Wheels and Tires 0 06-15-2012 05:03 PM
O.Z. Wheels Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 02-28-2012 03:21 AM
Top 10 Lightest 300 Horsepower Cars Axel Other Vehicles & General Automotive Discussions 2 11-22-2009 02:23 AM
