Old 06-09-2014, 02:09 PM   #1471
TmP
TmP's Avatar
Drives: A bunch of 'em...
I just bought 0w20 oil for my car.
Isn't that what's recommended?
At least one member on here told me it was.
TmP is offline   Reply With Quote
Old 06-09-2014, 02:18 PM   #1472
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Originally Posted by NCItaly View Post
Are you getting afr off the obd2?
Yes..
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 06-09-2014, 02:39 PM   #1473
NCItaly
Drives: 2013 BRZ Limited
Hahaha just realized what an idiot I am with that question...
NCItaly is offline   Reply With Quote
Old 06-09-2014, 03:52 PM   #1474
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
I found my vacuum leak, now I'm getting -17.7 hg at idle, is that ok? Or maybe I missed another leak, I'm boosting around 9 psi, what you guys think? I have negative 8 psi on idle.
Sent from my SGH-M919 using Tapatalk
Taino-BRZ is offline   Reply With Quote
Old 06-09-2014, 05:14 PM   #1475
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Sure for a stock powered car when you increase the power input by 50-60% ? I don't know since even manual says that a 5w-30 I don't see why people still hesitate..
I have been using 0w-40 Mobil 1 and wanted to try 5w-30 Motul V300 this time ( might be a bit overkill for street only car) mainly because some people claim tthat if the oil is too thick it may increase the friction and oil temps a bit..
I will datalog with the new oil to see if high moly content and slightly thinner oil helps
glamcem is offline   Reply With Quote
Old 06-09-2014, 05:29 PM   #1476
TmP
TmP's Avatar
Well, my car will see pretty much track / canyon time only.
The oil will probably get changed in another 3k miles or so.
We'll see.
I'll keep an eye on the temps and go from there.
Old 06-09-2014, 07:09 PM   #1477
CSG David
CSG David's Avatar
We'll see.
If you don't use the best oils, look to change after 1 or 2 trackdays if you peak at those temperatures. Pretty common knowledge that should be put out there if it hasn't been shared yet.
Old 06-09-2014, 08:01 PM   #1478
FR-S Matt
So the general consensus is, 5w-30 for daily driving and also tracking? Takes longer to warm up? I know mileage will take a hit, but I want to protect the engine best.
My Kraftwerks kit was supposed to deliver today, but I wasn't at home due to work. I'll pick it up from FedEx tomorrow. Radium catch cans show up tomorrow as well.
Possible radiator if necessary, 3 bar Omni, and some gauges and I should be ready to install.
Old 06-09-2014, 08:23 PM   #1479
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Shout out to @KraftWerks and their excellent customer service (specifically my KW POC Jeff G). Jeff has gone out of his way to check up on me occasionally to ensure I'm still enjoying my kit, sending me the necessary items (tunes, parts) to remedy my situation. Recently he sent me parts to address the problem I've been having with my oil reservoir even though admittingly it was installer-error (error by yours truly). Highly recommended for all of you potential owners still out there on the fence about this company and their kit.
mit_peid is offline   Reply With Quote
Old 06-09-2014, 08:59 PM   #1480
zoth
zoth's Avatar
Good luck man, you'll love the kit.
Old 06-10-2014, 08:51 AM   #1481
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I'm excited. I have my delicious tune so now I can compare it to visconti's. I'll be posting logs of both and general feedback on how they compare.
post_break is offline   Reply With Quote
Old 06-10-2014, 03:30 PM   #1482
post_break
post_break's Avatar
So you think that's expensive?
lol
Kids these days...
I knew I remember them saying the sandwich was going to be $99.
http://www.ft86club.com/forums/showp...&postcount=430
Oh well lol.
Old 06-10-2014, 03:42 PM   #1483
TmP
TmP's Avatar
Those bastards :P
Old 06-10-2014, 05:20 PM   #1484
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Oh well lol.
Initially the idea was to come in at that price, however the size and machining drove up the cost.
KraftWerks is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
