Drives: '92 GS-R, '02 RSX-S, '14 BRZ
Electronic Boost Controller Issues
So this is my situation. I have been running a 4 port Mac solenoid ebc plug and play since day one I was boosted. Running 3 maps. 7psi, 11psi and 15psi. Map one holds steady and true. Map two tops at 13psi. Map three I haven't ran as my clutch was slipping on map two so I don't know where it hits. I ran the 4 port as follows:
IN port - To compressor EX port - Vented A port - Top of wastegate B port - Bottom of wastegate I was instructed to use a 3 port ebc vs. the 4 port I have been using. Mind you the 4 port is fine and has no issues aside from 2psi over on map two and known overage on map three. I purchased a Dynosty ebc. It's a Mac solenoid plug and play. Here is my results: 1st hookup Port 1 - To compressor housing w/tee to wastegate bottom port Port 2 - Top port on wastegate Port 3 - Vented Result - 7psi on every map 2nd hookup Port 1 - To compressor housing Port 2 - Bottom of wastegate Port 3 - Vented Result - 7psi on every map 3rd hookup Port 1 - To bottom of wastegate Port 2 - To compressor housing Port 3 - Vented Result - I hit 15 psi+ keeps climbing so I let off every map 4th hookup Port 1 - Vented Port 2 - To bottom of wastegate Port 3 - to compressor housing Result - 7psi on every map So I am at a loss on how to run the lines. Can anyone shed some light??? Makes me want to install the 4 port and live with the 2psi over........
PTE 5758, Turbosmart, JDL, Perrin, Tein, Rays Gramlights, Sumitomo, Raceseng, Beatrush, Buddy Club, Valenti, DSS, Act, Cartboy, Mtec, APR, Beatsonic, FA20CLUB, Radium, JPM Coachworks, VIS, Recaro, IAG, Cleib, Nameless, Zele
Coming soon: Garage Vary, Cleib, Cravenspeed, VEI |
#2 |
Drives: 23 BRZ
I suggest you read this blog, every page. Each boost solenoid will have a diagram of how to connect it. There are two ways to properly connect a 3 port with an external wastegate.
http://blog.perrinperformance.com/bo...ems-explained/ |
| AVO DBW electronic throttle controller Setup | AVOturboworld | DIY (Do-It-Yourself) Guides | 22 | 03-31-2016 06:11 PM |
| Prodrive Boost Controller Installation | pixel67 | Forced Induction | 12 | 05-02-2014 02:32 AM |
| FS Hallman Pro RX Manual Boost Controller | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 2 | 02-28-2014 11:15 AM |
| Fuel economy and electronic toy-86-throttle-controller what do you think? | dssence | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 02-27-2014 06:40 AM |
| Turbosmart E-boost controller | Fl4t fun | Engine, Exhaust, Bolt-Ons | 0 | 01-29-2014 11:29 PM |
