#1863 | |
Drives: 2013 FRS
#1864 | |
Drives: 2013 FRS
![]() Cheers shiv |
#1865 |
Some Dumb Guy
Drives: wanting an Acabian
Could use a little painlessly right now. Sent some attachments to your shop (.bin's, .jpg & OFT log), but haven't heard back. Tried the battery disconnect, nothing changed.
She said it was her or the car. Longest
she had ever seen. |
#1866 | |
Drives: 2013 FRS
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | Blu-by-U (06-04-2014) |
#1867 |
Some Dumb Guy
My thanks for the conversation last evening. My many thanks for the assistance and my apologies to your bride.
she had ever seen.Last edited by Blu-by-U; 06-10-2014 at 06:46 AM. |
#1868 |
Drives: 13 FR-S AT
I have a question because I am close to buying the OFT my car is currently getting the "newest" ecm and I am wondering if there are any problems with writing to this ecm. It is not just an older flashed ecm but a new part number (waiting to get paperwork to verify which part #).
Anyone used the OFT with this newest ecm? Thanks |
#1869 |
Drives: BRZZZ
Just ordered my OFT! Im completely stock now. Planning on flashing a E85 tune and running E85 full time. What are you guys using as far as oil?
| The Following User Says Thank You to k.houan For This Useful Post: | Shiv@Openflash (06-07-2014) |
#1870 | |
#1871 |
Drives: SWP Subaru BRZ Sport-Tech 6AT
Do you guys keep your OFT plugged in all the time? I have mine mounted on the dash and its a pain to keep unplugging it and plugging it back in.
Shiv, are there any plans to have it auto shut off when the car is off and auto on when it is? Kind of tired seeing the "Operation failed" screen everytime I start the car in the morning. And is it OK to have the tab always plugged in and "on"? |
#1872 | |
Drives: FT86
You might also get Screen burn effect from having same image up constantly on screen The tablet may also drain battery if car not used for some time imagine a week or more ![]() The operation failed comes up each time the tablet loses communication to ecu ie you turn car off or start Last edited by steve99; 06-08-2014 at 07:19 PM. |
#1873 |
Drives: 2013 Asphalt 6spd
I wonder if you could mod a cable to have a simple on/off toggle switch to power wire(s)?
#1874 |
Drives: 13 FR-S AT
Actually it is a new ECM, new part number was installed and failed to marry to the car so they had to put my old one back in. I posted a separate thread about this. The ECU/ECM flash tsb was pulled as I am told because they failed to work with old ecm correctly.
#1875 |
Hmm, wonder what issues they discovered. My FR-S is first run, came with 700 firmware. I was flashed to B01 a month ago and it's working great. Do you have a source for this info?
#1876 |
Some Dumb Guy
When did you get yours and why were you flashed a month ago?
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
