Old 06-04-2014, 12:44 PM   #1863
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by meeks View Post
UPDATE:
Thank you. you guys are awesome! i spoke to Robert over the phone and he resolved the issue with me. it was just a matter of downloading the right file to the tablet and writing that on the car's ECU. did i tell you guys that you guys rock? car feels way better now without the "soggy" throttle pedal feel that i had before the flash with the UEL installed.
Awesome. Glad we could help
Shiv@Openflash is offline   Reply With Quote
Old 06-04-2014, 12:46 PM   #1864
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by jdv14476 View Post
Will give this a shot after work before I call my dealer. Is there some kind of residual charge that the battery needs to be disconnected from a given amount of time? Will wait 15 minutes for the hallibut.
If a power off reset doesn't work, I'll try a dead jump from a battery pack.
Shoot me your phone number via PM. I'm pretty sure we can sort this out painlessly
Cheers
shiv
Old 06-04-2014, 08:17 PM   #1865
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Could use a little painlessly right now. Sent some attachments to your shop (.bin's, .jpg & OFT log), but haven't heard back. Tried the battery disconnect, nothing changed.
Cheers
shiv
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 06-04-2014, 10:53 PM   #1866
Shiv@Openflash
Drives: 2013 FRS
Check the phone number you PMd me. Tried calling it and it says the number has been changed or disconnected. I think you may have given me the wrong one
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Blu-by-U (06-04-2014)
Old 06-05-2014, 08:27 PM   #1867
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
My thanks for the conversation last evening. My many thanks for the assistance and my apologies to your bride.
Old 06-06-2014, 05:39 PM   #1868
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
I have a question because I am close to buying the OFT my car is currently getting the "newest" ecm and I am wondering if there are any problems with writing to this ecm. It is not just an older flashed ecm but a new part number (waiting to get paperwork to verify which part #).
Anyone used the OFT with this newest ecm?
Thanks
F1fletch is offline   Reply With Quote
Old 06-07-2014, 10:20 PM   #1869
k.houan
k.houan's Avatar
Drives: BRZZZ
Just ordered my OFT! Im completely stock now. Planning on flashing a E85 tune and running E85 full time. What are you guys using as far as oil?
k.houan is offline   Reply With Quote
The Following User Says Thank You to k.houan For This Useful Post:
Shiv@Openflash (06-07-2014)
Old 06-08-2014, 03:35 AM   #1870
phrosty
Thanks
afaik there is no new hardware available. they list the ecu firmware as a part number, but it's still just a flash, and OFT works fine with the newest version (B01).
phrosty is offline   Reply With Quote
Old 06-08-2014, 04:44 AM   #1871
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
Do you guys keep your OFT plugged in all the time? I have mine mounted on the dash and its a pain to keep unplugging it and plugging it back in.
Shiv, are there any plans to have it auto shut off when the car is off and auto on when it is?
Kind of tired seeing the "Operation failed" screen everytime I start the car in the morning.
And is it OK to have the tab always plugged in and "on"?
01s0uljah is offline   Reply With Quote
Old 06-08-2014, 05:00 AM   #1872
steve99
Drives: FT86
Dont believe its going to hurt tablet, hopefully the plastics are uv stabilised and wont deteriorate with long periods exposed to sun.
You might also get Screen burn effect from having same image up constantly on screen
The tablet may also drain battery if car not used for some time imagine a week or more
The operation failed comes up each time the tablet loses communication to ecu ie you turn car off or start
Old 06-08-2014, 05:42 AM   #1873
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I wonder if you could mod a cable to have a simple on/off toggle switch to power wire(s)?
Target70 is offline   Reply With Quote
Old 06-08-2014, 06:04 PM   #1874
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Actually it is a new ECM, new part number was installed and failed to marry to the car so they had to put my old one back in. I posted a separate thread about this. The ECU/ECM flash tsb was pulled as I am told because they failed to work with old ecm correctly.
Old 06-08-2014, 06:44 PM   #1875
phrosty
Hmm, wonder what issues they discovered. My FR-S is first run, came with 700 firmware. I was flashed to B01 a month ago and it's working great. Do you have a source for this info?
Old 06-08-2014, 07:12 PM   #1876
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
When did you get yours and why were you flashed a month ago?
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
