| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2395 | |
Drives: FR-S Firestorm 6MT
#2396 |
Drives: 2014 Scion FRS, 2014 GTI, 2013 Golf
They are not coil overs just lowering springs with the Bilstein shocks. I was reading threads most of the night and some people say they will fit others say they won't fit. I have seen people that have 255/35's on 18x9.5 with just lowering springs on the same note right after reading that people comment that they won't fit without coil overs.
I am worried the people saying they fit are rubbing and not worried about it. I however don't want to rub and want to be able to turn my wheel all the way. |
#2397 | |
My wheels are 18x9+35, yours are bit more tucked in with the +40 offset. I have about 3-4mm clearance between the wheel lip and the spring perch. If my math is correct, your inside lip would be 11mm further in than mine. So, assuming your wheels already fit, you must have way less camber. What tires are you currently running? Check your clearances (inner and outer) and just do the math and see if you'll fit. I just use the Tirerack's site for specs and compare. My new 255 RS3 are 1/2" wider than my 245 Contis, with the tread width almost an inch wider (rounded vs squarer profile). So just a matter of splitting that difference in two and seeing how that affects each side of the wheel. |
#2398 |
Currently have the Advan GT 18x9.5 +40 with 245/40 front and 255/35 rear. Would like to get away from the staggered setup so it is easier to rotate tires. I have the K110 Hankook evo V12 tires.
Would like to go 255/35 all the way around if possible but worst case I was going to go 245/35 all the way around if the 255/35 won't fit. |
#2399 | |
Your 245/40 is pretty beefy already, so I would just check the inner clearance (just reach through the wheel) but I suspect you should be okay as it's not a drastic change from what you're running. If you've got a 1/4" or more available you should be fine. (only 4/10ths wider overall). |
#2400 |
Drives: SOLD...
Weird question I know..
How about 16x6.5 forester rims with 225/60/16's? (on a BRZ lowered 1") Just need something temporary and the price can't be beat. May only be using em for a couple weeks until new wheels arrive. Then i'd strip the tires off and put winters on in a better size for the winter. (and sell the 225/60's)
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
#2401 | |
#2402 |
Drives: SOLD...
Mostly worried about the 225/60 rubbing fenders. I imagine they are close to 48 or higher offset though
#2403 |
For sure way taller, 2" bigger diameter than stock. But I don't think it will rub and should be okay for short term use. It may just look odd for a few weeks and people may think it's the new BRZ Rally Edition!
#2404 | |
#2405 | |
245/40 is too tall 255/35 is a bit taller but within acceptable range. If you can check it, not that complicated. Here's a sideview looking at the strut/wheel clearance. Just stick your finger through the wheel and get an idea what the gap is. This is my wheel gap with my 245/35R18 Conti on 18x9 wheels. |
#2406 |
Drives: SOLD...
Slick what offset is that wheel?
On another note.. selling my Work wheels for some RPF1's in 17x9 ET35 and planning 245/40 on all corners with Toyo R1R's... What are the chance of that rubbing? I think I read that's ok. A shame I can't get et35's in anything but silver... the ET45's I can get in other colours but then I risk rubbing to the inside... (Just eibach pro-line)
#2407 | |
I love that RPF1 combo, will work well, no rubbing. |
#2408 |
Btw, I had my new tires mounted tonight (255/35R18 RS3) and they just fit.
Here's how close they are, but they still clear, and happy to report there is no rubbing. Will post a pic from the outside shortly.
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
