Old 06-05-2014, 10:08 AM   #1
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Clutch Free Play Adjustment
Hey Guys
I'm back to adjusting the clutch again, soon to remove the return spring to increase stiffness. I was reading through the service manual and it states that we can adjust the pedal by pushing the cruise control switch into the pedal. I have adjusted the pedal to be about even with the brake (by turning the push rod).I have also eliminated 0.2-0.4inches of free play at the top by pushing the cruise control switch in the clutch pedal.
Has anyone else adjusted the free play at the top of the pedal using this method? Should I return the switch back to its original free play amount of about 1.0in?
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 06-05-2014, 10:47 AM   #2
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
I'd be careful about adjusting the free play by moving the clutch switch. If you take up too much, the switch will be continually exerting pressure upon the pedal. I think the ideal adjustment still leaves just a bit of the white switch protruding from its cylindrical housing - or, at least, that's how I set mine after performing the grab adjustment here and the spring removal here.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 06-05-2014, 02:39 PM   #3
Tt3Sheppard
This is good to know as I do have some free play but there is slight pressure against the pedal. Not enough to engage the clutch but enough to move the pedal a few mm's. I think once I remove the spring I can probably go back to full free play. The issue I was having seems to be solved once the spring is removed.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Clutch Adjustment Issues!! FT-86- Scion FR-S / Toyota 86 GT86 General Forum 39 05-28-2015 09:29 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
Free play in clutch subiestyle Scion FR-S / Toyota 86 GT86 General Forum 26 02-24-2014 03:07 AM
Clutch pedal height adjustment, just do it Suberman CANADA 0 10-24-2013 06:00 PM
Clutch Adjustment Concern ZackZ Scion FR-S / Toyota 86 GT86 General Forum 19 09-07-2013 05:01 PM
