Old 06-04-2014, 12:55 AM   #1
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
HKS version 2 R&D supercharger
We are working with HKS and testing the new version 2 supercharger. More info will coming after all the testing is done.
Evasive Motorsports is offline   Reply With Quote
The Following 20 Users Say Thank You to Evasive Motorsports For This Useful Post:
86-tundra (06-07-2014), Astroboy (08-18-2015), Calum (06-04-2014), DAEMANO (07-22-2014), Deep Six (07-07-2014), diss7 (06-04-2014), Efferalgan (06-06-2014), FIREISFUN135 (06-05-2014), ill86 (07-10-2015), Imsteak (06-06-2014), JonAvalon (06-04-2014), jonbonazza (07-06-2014), JS + BRZ (11-07-2014), Kakawate (11-29-2014), mit_peid (06-04-2014), mrk1 (06-05-2014), RUNAMUK (06-04-2014), Scottemad123 (06-04-2014), Turbowned (06-24-2014), Weapon86 (07-29-2015)
Old 06-04-2014, 01:29 AM   #2
D K
Stig's dark passenger
Is this a draw thru MAF setup?
D K is offline   Reply With Quote
Old 06-04-2014, 01:40 AM   #3
BongMan
@D_K Looks like it uses the stock air box, so i'm going to say no.
Will this bad boy be carb legal? We need updates, it's almost been an hour!
BongMan is offline   Reply With Quote
Old 06-04-2014, 01:49 AM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Oh~ interested to see how well it perform.
...at the same time, I'm interested if they gonna release twin charger ver
Sent from my mighty mind
The Following 6 Users Say Thank You to ichitaka05 For This Useful Post:
ill86 (07-10-2015), illmatic (06-04-2014), Kiske (06-04-2014), Lawnik (07-17-2014), SkAsphalt (06-04-2014), sklimo (07-09-2014)
Old 06-04-2014, 02:03 AM   #5
Dezoris
Dezoris's Avatar
Looks like another Rotrex kit but lack up content makes this a big boner kill.
The Following User Says Thank You to Dezoris For This Useful Post:
OICU812 (06-13-2014)
Old 06-04-2014, 02:09 AM   #6
D K
I'm interested in seeing *which* Rotrex this is based off of?
I know the first series was based on a Rotrex design that Rotrex binned. They felt there were reliability issues.
Hopefully the newer ones are based off of more current Rotrex designs.
D
Old 06-04-2014, 02:14 AM   #7
darthwong1138
Drives: Raven FR-S
Pics of intercooler please
darthwong1138 is offline   Reply With Quote
Old 06-04-2014, 06:07 AM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
D
Got any more details on that?
Old 06-04-2014, 06:26 AM   #9
D K
Thats about as far as Im gonna go on that
Old 06-04-2014, 11:09 AM   #10
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
This new setup has a few advantages over a rotrex kit. This new transmission is built to have less parasitic drag.
Originally Posted by motokev View Post
I have seen preliminary data and goals for this kit however, until we install and tune the kit on our vehicle here in America I won't speculate.
I will say I don't see an issue hitting the 300 whp goal.
In addition I am very familiar with Rotrex. Actually, I was quite involved with kit development using the unit on American vehicles around 10 years ago. Upon study of the Rotrex verse HKS unit I can say it's not always about power output although, all the data I have seen leaves me splitting hairs in regards to power comparisons. Both units boast efficient maps, charge temps, and higher impeller speeds but, 3 major changes HKS made to their design make a big difference in a few areas.
Change 1- Increasing the diameter of the impeller shaft. (2mm iirc)
Change 2- Using more than one bolt to mount the supercharger pulley opposed to Rotrex using one bolt.
Change 3- Reducing parasitic drag by spring loading one of the planetary wheels.
Change 3 might be a little confusing so I'll explain. If you look at the attached image you can see a small spring and shaft assembly to the right of the impeller shaft. The addition of this spring allows wheel tension to release during engine idle while progressively ramping up pressure on the impeller shaft to aid slippage during high boost levels.
Personally, I experienced issues with the Rotrex units during my development work directly relating to the HKS changes to their design. I can say they are definitely a step in the right direction for increased strength, longevity, and a more efficient unit. As usual, any of my opinions are quite objective.
marcoaferrer is offline   Reply With Quote
The Following User Says Thank You to marcoaferrer For This Useful Post:
ill86 (07-10-2015)
Old 06-04-2014, 01:02 PM   #11
xwd
Not to derail the thread but the twin-charger setup is kind of ingenious the way they routed everything. The turbo (which looks tiny) feeds directly into the supercharger inlet. I was always curious how well that would work and how efficient the S/C would be at compressing the already compressed air, but apparently works well enough. Have to lose the A/C though so I'm not sure they will make this as a production kit.
The Following User Says Thank You to xwd For This Useful Post:
ill86 (07-10-2015)
Old 06-04-2014, 04:47 PM   #12
Eightysexy
GBC [HI]
Drives: Haole FRS
In, for more info.
Eightysexy is offline   Reply With Quote
Old 06-05-2014, 02:10 AM   #13
D K
Are you saying the new HKS charger has less parasitic drag than the Rotrex?
D
Old 06-05-2014, 10:20 AM   #14
marcoaferrer
D
Yes and no lol, it has less parasitic drag at lower rpms. The transmission is designed to transfer all of its rotating force to the impeller once there is enough centrifugal force. Sorta like an oldschool brake drum. At least that is how it is explained by @motokev in that post.
EDIT: ^^^ I made a stupid typo
North America to get Subaru version but not Toyota version? Ground N Pound BRZ First-Gen (2012+) — General Topics 42 05-29-2014 01:23 AM
Hot Version Vol.116 ft. 86 & BRZ larryw BRZ Photos, Videos, Wallpapers, Gallery Forum 3 08-05-2013 03:14 AM
Hot Version Vol. 122 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 06-12-2013 11:03 AM
New hot version 4agze Other Vehicles & General Automotive Discussions 19 03-07-2012 10:08 PM
Do you think we are going to see a trd version or 5axis version of the FRS next week DIG1992 Scion FR-S / Toyota 86 GT86 General Forum 9 01-04-2012 07:59 AM
