Old 06-04-2014, 02:11 AM   #253
notout86
Drives: GTS 86 auto
A trick!! Try this.
Have your car out in bright sunlight so the sensor on the dash is having its pineal gland stimulated. (Google pineal gland if necessary).
Select reverse and note the brightness in the h/u.
Turn on your headlights.
If it goes too dark for your liking, you can try Day View set in your h/u.
To force Day View always on, click Audio>Info (or scroll down to Info)>Settings>press Link to Day/Night and set to None> set to DAY. In my h/u manual this is on p.28 & 29.
Does this earn me a pint?
GTS86 Auto (Australia)
The Following User Says Thank You to notout86 For This Useful Post:
davesbrz (06-04-2014)
Old 06-04-2014, 01:15 PM   #254
mx555
Originally Posted by notout86 View Post
A trick!! Try this.
You can also flip your illumination switch to max. That'll also force day view.
mx555 is offline   Reply With Quote
The Following User Says Thank You to mx555 For This Useful Post:
Old 06-05-2014, 08:54 PM   #255
TestaRossa
TestaRossa's Avatar
Drives: 2013 DGM BRZ
Does anyone know if the beatsonic harness works with the Duo camera and BRZ HU? and if it does work will the install be easier than using the SVX harness?
I really want to install a rear cam but not good with all the electronic wiring and stuff.
Saorri for mah bad English
TestaRossa is offline   Reply With Quote
Old 06-11-2014, 06:24 AM   #256
notout86
Drives: GTS 86 auto
Here's some helpful homework for you below
In particular I would strongly recommend ensuring you get cameras that are known to work as low as 6Volt to save a lot of hassle and
run camera cabling in from the trunk between the rear seat and tucked up under the edge of the center console then pull off the cover at the base of the kneepad.
With the h/u out you can reach in and down with your arm and grab cabling to pull up.
After reading the links you may well decide you can use little computer-pin female connectors eg for USB or fans or similar instead of getting a harness.
Attach your cam with double sided tape for a few days to see if it fails and check if happy where you want it before making holes.
******************************/index.php?/topic/2270-pin-out-diagram-for-oem-head-unit/
******************************/index.php?/topic/1588-camera-install-under-50/
Old 07-18-2014, 08:24 PM   #257
John_Hulme
Drives: 2014 Subaru BRZ Limited 6MT Black
I bought the same thing. Rydeen Duo but with the BeatSonic Harness.... I am having difficult in just wiring it up. I am unable to get video feedback and i try other options...
John_Hulme is offline   Reply With Quote
Old 07-20-2014, 07:44 PM   #258
Raven23
Is the SVXdc harness needed to install the rydeen cam to a aftermarket headunit or just OEM? I bought the camera to go with my pioneer 4000nex. Wondering if i need to buy that as well.
Raven23 is offline   Reply With Quote
Old 07-20-2014, 07:58 PM   #259
cnk
Drives: '13 DGM BRZ Limited
No. You would use the rca video input on the 4000NEX. The adapter is only for the stock radio. I'm planning on adding a rydeen to my 8000NEX as well, but I still need to do some more research as I want to add a ALP and 1 of the heads is going to sit near where the rear view cam would be.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 07-22-2014, 04:08 AM   #260
JM9ISM
Drives: 2014 BRZ WRB LTD
So SVXdc harness is actually work like Beatsonic's harness? Am I understanding it correct?
JM9ISM is offline   Reply With Quote
Old 07-22-2014, 06:28 AM   #261
btoast
Out of curiosity, if I were to run a Rydeen Duo with the SVXdc harness would I need to splice any wires for power, or would the SVXdc harness make it 100% plug and play (i.e., no cutting or splicing any wires on the car)?
Thanks.
btoast is offline   Reply With Quote
Old 07-22-2014, 03:08 PM   #262
zinzan
zinzan's Avatar
Drives: Subaru BRZ 2014 Limited WRB
The Rydeen Duo comes with an RCA output for video, but the OEM head unit does not have an RCA input. The SVXdc harness adapts the RCA to the 16-pin input in the head unit. That part is plug and play.
As far as power goes, the Rydeen Duo has a power wire at the head unit end. You can get the SVXdc harness with a 6v lead, but you will still have to connect the two wires. This is not "plug-and-play"--you will have to solder, tape, or crimp. Soldering and sleeving is probably the best option, but I chose to crimp with a $1 butt connector.
Alternatively, the Rydeen Duo also has another power wire at the camera end and you can use that one instead, but you'll have to connect it to some power source. Whichever one you chose to use, tape up the other so it doesn't accidentally come into contact with metal or get tangled.
-Z
zinzan is offline   Reply With Quote
The Following User Says Thank You to zinzan For This Useful Post:
tracerit (10-15-2015)
Old 07-22-2014, 05:39 PM   #263
btoast
-Z
Thanks for the response. I figured I would have to solder the camera wires to the SVXdc harness, but did not know if there was anything else to do. The SVXdc harness photos on ae64 shows three wires; video connector, and the other two i figured were power and ground. I assumed I could just connect the camera to the SVXdc harness, plug in the harness and call it a day. My main issue is that I do not want to splice/cut/or otherwise alter the factory wiring in any way.
Old 07-22-2014, 10:57 PM   #264
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
You will not need to cut into ANY car wiring. SVXdc sells a harness(es) that provides all the connectivity you need. The 16-pin camera harness has a 6V power lead in it that gets power when you put the car in reverse. The only issue is if your camera requires 12V to run...which I explain below.
If the camera is 12v be sure to buy the option connector harness that connects to an unused port behind the radio that provides 12V, in addition to the 16-pin camera harness. You will also need a 6v relay to use as a trigger, as well as crimp connectors or solder\shrink wrap.
If the camera is 6v then you just need the one 16-pin harness.
I did my backup cam install in January and it is 100% plug n play. My camera is 12V so I had to wire in a relay along with the option connector harness so I can help you with this if that's what you're working with.
http://ae64.com/Rear-camera-16-pin.htm
Option Connector Harness
For BRZ, FR-S, and 86 models: This 6-pin harness connects to the car's "Option Connector" and has leads for +12V Battery, +12V Accessory, and ground. If your camera requires more than 6V, use this harness to avoid needing to splice into a factory wire for power. Price $4.
Pm me if you need help or have any questions.
B-R-Z is offline   Reply With Quote
The Following User Says Thank You to B-R-Z For This Useful Post:
menikmati (07-23-2014)
Old 07-23-2014, 01:07 AM   #265
greencounty
greencounty's Avatar
This is the harness that I used:
http://www.autoharnesshouse.com/19867.html
I have an Ebay camera, so the 12V is necessary. No complaints thus-far.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
The Following User Says Thank You to greencounty For This Useful Post:
Old 07-23-2014, 01:38 AM   #266
menikmati
Drives: 2015 BRZ, 2005 STI
Thanks for the info. I'm looking at the Rydeen Duo and a harness from SVXdc.
Specs for the Rydeen Duo state a working voltage of 9-16V, so I'm assuming it would need a 12V source.
What exactly is the benefit of the Pass-Thru version of the harness on the SVXdc website? It appears that I would only need the Bypass version and the Option Connector harness.
How exactly would I wire the camera up to receive 12V power? I read that it involves a relay, but I would like to know what relay to buy and how to actually wire it up.
Thanks again.
menikmati is offline   Reply With Quote
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 03:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 03:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 12:32 PM
Want to buy a BRZ Limited AT kgc Northwest 1 06-17-2012 12:45 AM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 01:50 PM
