Old 06-03-2014, 04:31 PM   #1
mamamiaellis
Drives: brz
full exhaust install help?
hey dude and lady dudes,
i already have a perrin catback on my vehicle, and recently my front pipe and over pipe came in the mail.
perrin came with instructions for the over pipe, but the front pipe (berk) didnt.
perrin says to torque the overpipe to the front pipe at 38ft-lb.
does it matter if it is a stock or aftermarket pipe?
sorry for the novice questions. better safe than sorry??
thanks for reading =]
mamamiaellis is offline   Reply With Quote
Old 06-03-2014, 04:37 PM   #2
Malt
Drives: 2015 WRX
Factory service manual says 31.3lbft but the perrin overpipe uses bolts instead of studs. 38 sounds fine to me
Malt is offline   Reply With Quote
Old 06-03-2014, 05:14 PM   #3
mamamiaellis
Drives: brz
thanks for the reassurance =P
Old 06-03-2014, 05:32 PM   #4
mamamiaellis
Drives: brz
i have another questions.
should i use to bolts/flat gasket from my perrin catback to connect it to the front pipe? or should i use the one that berk gave me? or does it matteR?
Old 06-03-2014, 05:34 PM   #5
Malt
Drives: 2015 WRX
Just look at the two choices you have and use the higher quality one (gasket and bolts).
Old 06-03-2014, 05:43 PM   #6
bluesman
Drives: 2015 FR-S
If either bolt set is stainless steel, use that one. It's amazing how solidly even galvanized or plated nuts and bolts corrode and join together over time. If they're both SS and one set is larger in diameter, use that one - it will minimize any opportunity for shifting of one flange against the other. You can probably tell with a small magnet - some SS alloys are ferrous enough to be slightly magnetic, but a mild steel bolt will pull a lot harder toward a magnet than any SS alloy.
The quality of the gasket is harder to determine without seeing it. Thicker vs thinner isn't always a good guide, nor is metal vs fiber. But they're probably both quite fine, since they come from reputable sources.
bluesman is offline   Reply With Quote
Full Blown Stage 2, Rad + Shroud + SPAL install Ironsquid Forced Induction 3 02-11-2014 10:47 PM
Full Stock Exhaust - Anyone content with full stock & NEVER planning for aftermarket? fooddude Engine, Exhaust, Transmission 39 12-15-2013 02:05 PM
Anyone install a full exhaust on a sport bike? Sivtec Other Vehicles & General Automotive Discussions 8 10-26-2013 11:25 PM
SilverSkyline210's Full Blown Turbo Kit Install SilverSkyline210 Forced Induction 22 06-15-2013 04:23 PM
Problems with FX400 full-disk clutch after shady install... ***Help?*** Argento_FR-S Engine, Exhaust, Transmission 4 05-29-2013 02:29 AM
