Old 06-02-2014, 07:55 AM   #5867
shif7i7down
Erected Member
Drives: frs
Originally Posted by mid_life_crisis View Post
Foot to the floor has a slight delay totally stock because of drive by wire. I bet it's just more noticeable with the extra kick of a supercharger.
That might very well be the case, i was only asking to see if it's a normal thing or did i do something wrong and if not then was someone able to reduce or eliminate the delay.
Just for the record i wasnt trying to bash the product or complain about the delay
shif7i7down is offline   Reply With Quote
Old 06-02-2014, 10:56 AM   #5868
Tenthousanddays
Drives: 2013 BRZ Limited
Originally Posted by gtfapollo View Post
I read both of the other threads and some of the other FI threads in that category for the last few hours.
Can't wait for @Robftss Phantom ESC
I think there's several of us who are interested in making the best of the Phantom system over in that thread - and others who are looking to do something a bit different.
There's also some things going on in that thread that wouldn't be of interest to Rob, since it leads to a more complicated set up, with more power requirements. For instance, I've been talking to a vendor who builds solid slot electric motors, coupled with a turbo scroll which can put out close to 9PSI. The downfall is you need 7kw of continuous power to run it at 9PSI. Aka, close to 300 amps of continuous draw power = tons of batteries.
I'm still really into the Phantom setup - awesome price point for decent gains. I'd like to see another few PSI before jumping into it. I'd like to see a bigger motor with a bigger scroll - but that means more batteries. Just the limitations of this system.
Tenthousanddays is offline   Reply With Quote
Old 06-02-2014, 12:42 PM   #5869
shif7i7down
Erected Member
Drives: frs
I got a question. We should be able to use 36v To speed up the brushless motor by roughly 40% without overheating as long ad we keep it 18AH. But will the controller be able to handle the 36v ?
Have Rob experimented with this yet?
Old 06-02-2014, 01:14 PM   #5870
DAEMANO
Time Traveller
I applaud those looking to improve or even develop this concept. At the same time it's interesting to see people looking to re-create and/or improve the design of Rob's Phantom ESC slowly come to understand his design decisions and the depth of the R&D put into his release kit. Rob's been in development and testing for what 7,8,9 (?) years now, maybe longer and it shows in the reliabilty, streetability and viability of his offering. Any new peeps and or ideas are very much welcome however.
The Following 5 Users Say Thank You to DAEMANO For This Useful Post:
enwave (06-03-2014), Gums (06-02-2014), neutron256 (06-02-2014), Robftss (06-02-2014), robwbright (06-02-2014)
Old 06-02-2014, 01:21 PM   #5871
Tenthousanddays
Exactly, it's a very "simple" setup, that can be replicated in many different vehicles without having to change much. The battery system doesn't take up much space, and the install is basically a bolt on. It would be extremely hard to come up with a competing drop in product like his.
As electric motor and battery technology advances, I'm sure some advancements could be made to his already great system to allow for a few extra CFM's.
The Following 2 Users Say Thank You to Tenthousanddays For This Useful Post:
DAEMANO (06-02-2014), robwbright (06-02-2014)
Old 06-02-2014, 01:22 PM   #5872
fenton
Yes I agree. The thing is boost down low is easy to get when the little 2.0 engine is not that efficient. It's up top that is hard.
In talking with Rob I think he said 20kw for 6 psi at redline.
Right now the system uses about 3.5kw and makes 5psi down low. My setup with 1.5 conversion and tq300 is about 4.5kw. The cooling requirements above 5kw change as well same with the amperage requirements of the controller. Everything keeps getting bigger and hotter the more watts you push through the system.
fenton is offline   Reply With Quote
The Following 4 Users Say Thank You to fenton For This Useful Post:
DAEMANO (06-02-2014), Gums (06-02-2014), neutron256 (06-02-2014), robwbright (06-02-2014)
Old 06-02-2014, 04:24 PM   #5873
Tenthousanddays
Holy crap... that's 555A @ 36V. There's a company that makes a 48V brushless with a gearbox incorporated to it. Even still, to make 6PSI up top you'll still need close to 400 amps.
Old 06-02-2014, 04:43 PM   #5874
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
It sucks when physics gets in the way of a great plan.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following 5 Users Say Thank You to Gary in NJ For This Useful Post:
DAEMANO (06-02-2014), fenton (06-02-2014), Gums (06-02-2014), Sojhinn (06-02-2014), Target70 (06-02-2014)
Old 06-02-2014, 04:46 PM   #5875
fenton
Apparently 6kw is a nice number.....
Old 06-02-2014, 04:55 PM   #5876
AN
Drives: 2010 MX-5
I think 6psi - up top is a lot to ask from a compact battery/motor/controller combo as of today. We all know it will change .
However, one thing Rob has proven is that 5psi at the bottom and tapering to 0.5 Psi uptop can be awesome. I think it is reasonable for folks to look into where this system can be improved. e.g. use Li-Fe-Sulfate batteries which are 1/4 the size and weight of Pb-Acid and still affordable .... they can provide a lot of current, have a lot lower internal resistance ..... i.e. custom made for this solution. Similarly , 6kW ~ 7kW hobby motors are available for less than $200. Another easy target to upgrade ...
What Rob has done / shown is simply amazing. But since he had to put something together that is super cheap, easily replica-table / reproducible, flexible enough to be adaptable on other cars ... we can see why he had to make a lot of design decisions that he made.
AN is offline   Reply With Quote
The Following 2 Users Say Thank You to AN For This Useful Post:
Old 06-02-2014, 05:05 PM   #5877
Tenthousanddays
Where in NJ are you at Gary? I'd love to look at your P-FTS.
6kW @ 36v only requires 166A (continuous), which is totally feasible with the right batteries.
Old 06-02-2014, 05:11 PM   #5878
fenton
Rob had done 36v before and it does perform well but there were many things he didn't like about it. Mainly that if people need things up with a 36v system it is easy to do your heart.
Right now his plans are to stay with 24v and push the system from there to my knowledge.
Old 06-02-2014, 05:39 PM   #5879
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Is that gearbox a step-up, or step-down? Usually they are step down which is of no help. On big problem is that just adding more power isn't going to do the trick. You need a faster motor as well, or a larger compressor that will flow more air at the same speed.
Old 06-02-2014, 10:35 PM   #5880
TM
TM's Avatar
Drives: DGM BRZ 6MT
I was driving home on the back roads to enjoy the sound of my new UEL headers and decided to see how it feels with the ESC unarmed. I forgot how slow this car is in its stock form! Even with headers. The car does not pull!
TM is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
