#5867 | |
Erected Member
Drives: frs
Just for the record i wasnt trying to bash the product or complain about the delay
#5868 | |
Drives: 2013 BRZ Limited
There's also some things going on in that thread that wouldn't be of interest to Rob, since it leads to a more complicated set up, with more power requirements. For instance, I've been talking to a vendor who builds solid slot electric motors, coupled with a turbo scroll which can put out close to 9PSI. The downfall is you need 7kw of continuous power to run it at 9PSI. Aka, close to 300 amps of continuous draw power = tons of batteries. I'm still really into the Phantom setup - awesome price point for decent gains. I'd like to see another few PSI before jumping into it. I'd like to see a bigger motor with a bigger scroll - but that means more batteries. Just the limitations of this system. |
#5869 |
Erected Member
Drives: frs
I got a question. We should be able to use 36v To speed up the brushless motor by roughly 40% without overheating as long ad we keep it 18AH. But will the controller be able to handle the 36v ?
Have Rob experimented with this yet?
#5870 | |
Time Traveller
| The Following 5 Users Say Thank You to DAEMANO For This Useful Post: | enwave (06-03-2014), Gums (06-02-2014), neutron256 (06-02-2014), Robftss (06-02-2014), robwbright (06-02-2014) |
#5871 | |
As electric motor and battery technology advances, I'm sure some advancements could be made to his already great system to allow for a few extra CFM's. |
| The Following 2 Users Say Thank You to Tenthousanddays For This Useful Post: | DAEMANO (06-02-2014), robwbright (06-02-2014) |
#5872 | |
In talking with Rob I think he said 20kw for 6 psi at redline. Right now the system uses about 3.5kw and makes 5psi down low. My setup with 1.5 conversion and tq300 is about 4.5kw. The cooling requirements above 5kw change as well same with the amperage requirements of the controller. Everything keeps getting bigger and hotter the more watts you push through the system. |
| The Following 4 Users Say Thank You to fenton For This Useful Post: |
#5873 |
#5874 |
Drives: WR Blue BRZ, 240Z
It sucks when physics gets in the way of a great plan.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#5875 |
#5876 |
Drives: 2010 MX-5
I think 6psi - up top is a lot to ask from a compact battery/motor/controller combo as of today. We all know it will change .
However, one thing Rob has proven is that 5psi at the bottom and tapering to 0.5 Psi uptop can be awesome. I think it is reasonable for folks to look into where this system can be improved. e.g. use Li-Fe-Sulfate batteries which are 1/4 the size and weight of Pb-Acid and still affordable .... they can provide a lot of current, have a lot lower internal resistance ..... i.e. custom made for this solution. Similarly , 6kW ~ 7kW hobby motors are available for less than $200. Another easy target to upgrade ... What Rob has done / shown is simply amazing. But since he had to put something together that is super cheap, easily replica-table / reproducible, flexible enough to be adaptable on other cars ... we can see why he had to make a lot of design decisions that he made. Last edited by AN; 06-02-2014 at 05:09 PM. |
#5877 |
Where in NJ are you at Gary? I'd love to look at your P-FTS.
6kW @ 36v only requires 166A (continuous), which is totally feasible with the right batteries. |
#5878 | |
Right now his plans are to stay with 24v and push the system from there to my knowledge. |
#5879 |
Drives: '13 GBS Subaru BRZ
Is that gearbox a step-up, or step-down? Usually they are step down which is of no help. On big problem is that just adding more power isn't going to do the trick. You need a faster motor as well, or a larger compressor that will flow more air at the same speed.
#5880 |
Drives: DGM BRZ 6MT
I was driving home on the back roads to enjoy the sound of my new UEL headers and decided to see how it feels with the ESC unarmed. I forgot how slow this car is in its stock form! Even with headers. The car does not pull!
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
