Old 05-29-2014, 07:58 PM   #15
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
My friends @ N1 Concepts went 1:53 @ buttonwillow on AirRex with their s2000 i believe the first time out with the car.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 05-29-2014, 09:30 PM   #16
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Originally Posted by TouchMyHonda View Post
This was my friend form ABMotoring that helped Airlift with this video. Those are his cars (Golf R and BRZ) that they are testing with and they have a very close relationship...
Am I wasting my time here trying to offer help? Idk why you would ignore my post. I know the direct contacts to what you need.
I wasnt ignoring your post man, i was just on the go and will be sending you a pm now
mkivalex is offline   Reply With Quote
Old 06-01-2014, 04:25 PM   #17
Andrew@ORT
Drives: BT 6.4 (tow pig) / e46 M3
Originally Posted by mkivalex View Post
Spring rate would be based on pressure in the bags. So I think your right in that it would ride differently at different heights.
Calculating the spring rate of an air bag is much harder than calculating the spring rate of a typical metal coil spring. Spring rate is defined as the amount weight (typically in lbs) needed to compress a spring one inch. Typically spring rates are calculated using the equation:
k = Gd^4/8nD^3
in this equation:
k = spring constant, pounds of load per inch of deflection
G = modulus of rigidity
n = number of active spring coils
D = wire diameter or coil diameter - measured in inches
Because we cannot plug in raw numerical values for air springs, it becomes increasingly harder to figure out the exact spring rate. Furthermore in the world of air springs, both pressure and volume need to be taken into consideration when trying to calculate spring rate - again, it's not as easy as it would be with a set of coil springs.
There are a two things that are certain more often than not and they are: larger bags will lift more weight but have a lower spring rate and smaller bags will not be able to support as much load but will have a higher spring rate. Spring rate with regard to air ride is definitely a function of bag pressure and volume. Another variable that has to be taken into consideration is the material used in bag construction. The thicker the material, the more weight the bag will support and the less pressure it will need to lift the vehicle. It's very tough to calculate the exact spring rate of air springs because there are (in a sense) too many unknowns. Without breaking out paper and an abacus, you could always set your car at maximum height and consistently add weight until the vehicle drops one inch and do the same at ride height. This will show you that spring rate will vary dependent upon pressure and not just volume. It's a pretty 'raw' method of figuring out the spring rate, but it should give you a general idea of the spring rate of your air springs.
Andrew@ORT is offline   Reply With Quote
Old 06-01-2014, 05:13 PM   #18
crazygt
Drives: 6MT frs
off topic, what spolier is on the red BRZ?
crazygt is offline   Reply With Quote
Old 06-02-2014, 01:12 PM   #19
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
think about this, you're paying 3k+ for BC struts with BC dampeners.
does it work? surely. but if you want the best handling car, you really wont beat a dedicated coilover.
bags will be good for the casual tracker, as they do perform decent.
i've also seen the bad side of it, broken lines (car drops out from under you) leaks from improper installation, etc etc. now obviously this doesn't apply if you install it correctly but with air, there is always that slight chance of something going wrong, because if you pop a line god forbid, you're done if you're doing any kind of spirited driving.
with that said, there is a place for bags and they do work and when setup right they ride great, you just need to decide what you want.
you've heard both sides of the story now make up your own mind, but theres a reason no one who is a die hard track rat uses bags, its just not the best option for that. its a good middle ground if you want to be low and have a car that can make it around city streets, but realistically, its two different realms of suspension. apples to oranges here.
Jive Turkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post:
Roxy86 (06-03-2014), Scargod (06-06-2022)
Old 06-02-2014, 01:59 PM   #20
fatoni
i really dont think that happened.
Old 06-03-2014, 10:22 AM   #21
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
Referring to [ame="http://vimeo.com/93260756"]this[/ame] perhaps?
Smudgeous is offline   Reply With Quote
The Following User Says Thank You to Smudgeous For This Useful Post:
zooki (07-04-2014)
Old 06-03-2014, 11:00 AM   #22
Andrew@ORT
I agree this about 90% of what you've said and you've really hit the nail on the head.
Air ride was never meant to be a direct replacement for coilovers, it was meant to be a respectable alternative. As AirLift has shown throughout their videos, marketing, etc. air suspension can perform and it can withstand the abuse on the track.
The video seen here: is a comparison between coils and air suspension. What most people don't know is that all the cars were equipped with KW V2 coilovers. While many say the test was skewed, it was actually pretty fair.
At the end of the day, air suspension will never be coilovers, that's just a fact. However, air suspension is a happy medium for those seeking both performance and comfort from their suspension.
The Following 3 Users Say Thank You to Andrew@ORT For This Useful Post:
diirk (07-08-2014), draggin_az (06-05-2014), Jive Turkey (06-04-2014)
Old 06-03-2014, 11:30 AM   #23
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
Hey Buddy, didn't know you were on this forum, I posted that video earlier in the thread.
Lawn_Mower is offline   Reply With Quote
Old 06-03-2014, 12:14 PM   #24
Andrew@ORT
Hey Max
Old 06-03-2014, 04:39 PM   #25
fatoni
Originally Posted by Smudgeous View Post
Referring to perhaps?
looks like youre right. they were still faster before when they coil springs. i guess sponsorship is a tricky thing.
Old 06-03-2014, 07:18 PM   #26
Jesse@JDLAutodesign
I don't think anyone doubts that...I think it was more along the lines of that it is still capable of running a very respectable time.
Old 06-03-2014, 08:50 PM   #27
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by Lawn_Mower View Post
Obviously this is going to be a little biased, but check this out, a pretty cool video.
Edit: BRZ part starts around 4:40 if you don't want to watch the whole thing.
It's really kind of useless, Using a coilover that costs half what airlift does to the end user?
Would of liked to see them put it up against some MCA reds or golds, Ohlins.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 06-04-2014, 11:10 AM   #28
Andrew@ORT
so, what you're saying is that KW V2's are not a good coilover?
airlift suspension? kendalldwhite Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-07-2014 10:56 PM
AirLift Performance - Video kykiee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 11-11-2013 07:47 PM
Airlift digital combo kit baggedbrz Brakes, Suspension, Chassis 3 09-21-2013 04:38 PM
Airrex VS AirLift? iJason Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-04-2013 08:55 PM
Anybody Running Airlift Suspension Admired Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-04-2013 12:30 PM
