Old 06-02-2014, 05:06 AM   #1
Ghost147
Drives: Needs replacing
The Highest Amount of Horsepower
I'm likely not going to do any track stuff with my FR-S, and I am likely not going to do very much (if any) work to boost this cars Horsepower. However, I am nevertheless interested in just how far a person could go to increase it, without completely replacing everything. I'm not very familiar with how much 'this and that' increases horsepower, but trying to learn.
So, out of curiosity, I'm wondering what's the highest Horsepower you've seen coming from an FR-S? And what was done to achieve that?
Ghost147 is offline   Reply With Quote
Old 06-02-2014, 07:48 AM   #2
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
I'd say I've seen turbo kits (turbo, admission, exhaust, ...) rated 380HP... but obviously if you change everything (motoro included) you can get whatever you want.
I think that by changing the admission + exhaust you can aim 230 and reduce the torque dip (the cosworth kit does that from what I know)
Harvey is offline   Reply With Quote
Old 06-02-2014, 08:05 AM   #3
raven1231
NA like he said around 230 base, 196 wheel, ESC/ bolt on's/ E85 around 235whl, 270base, Traditional FI look at FBM's car .
robwbright (06-02-2014)
Old 06-02-2014, 08:14 AM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I believe at 250whp or so, you're replacing the clutch. Not long after, you need a fuel pump upgrade and better cooling. Then you soon need injectors, axles, a new rear diff, and a return fuel system. Needing to build the bottom depends on design choices you've made in your system. The more torque at lower rpm, the harder the bottom end gets beaten upon. You're not going to go far beyond 300whp without serious upgrades, and you probably won't be able to beat upon the car with that much power unless you make the upgrades. In the meantime, if you're running big power, you should have bigger brakes and upgraded suspension to handle it all. Oh, and to get to 300whp, you're probably looking at a complete exhaust system.
The moral of the story is to buy used parts.
Old 06-02-2014, 08:44 AM   #5
J_kennington
Drives: 2013 asphalt scion FRS
Horsepower has nothing to do with clutch. Torque is the only limiting factor on a clutch. And you think you can get 250 without a full exhaust?
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 06-02-2014, 09:49 AM   #6
Harvey
For my part I'll never do anything like this, I think the car's got a good balance between power and all the rest (just the torque dip is a shame all the same, regardless of maximums)... if you just want power at Nissan 370Z is probably better for a similar price (or a Megane RS, quite popular around here)
Old 06-02-2014, 12:33 PM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Yes, but he asked horsepower, and at 250WHP, you're getting to new clutch torque. As for 250WHP without an exhaust, of course? The stock exhaust flows pretty darn well. It's certainly over-sized for 200hp.
Old 06-02-2014, 12:37 PM   #8
frz06
8686868686
Drives: 00
Not sure if this is the same engine or what's in it, but the description says that this FRS has 470 hp
[ame="http://www.youtube.com/watch?v=QDksXTRVqu8"]GTR vs FRS - YouTube[/ame]
frz06 is offline   Reply With Quote
Old 06-02-2014, 12:55 PM   #9
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
thats @fabron, hes local to Hampton Roads and currently on deployment.
he has the factory engine on stock internals. i believe he's running 20psi, custom header, and custom exhaust on E85.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 06-02-2014, 02:04 PM   #10
J_kennington
Proof of any car making over 200 with full factory exhaust please.
2005 Yamaha yz250f
Old 06-02-2014, 02:31 PM   #11
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
I did 250whp with full factory exhaust ... only mod was vortech supercharger.
Nolan
pheoxs is offline   Reply With Quote
The Following 2 Users Say Thank You to pheoxs For This Useful Post:
EAGLE5 (06-02-2014), SkAsphalt (06-02-2014)
Old 06-02-2014, 02:34 PM   #12
2nd Gen Scion
Drives: Scion FR-S Manual Raven Monogram
Excuse my cluelessness but what are you referring to when you say "admission"?
2nd Gen Scion is offline   Reply With Quote
The Following User Says Thank You to 2nd Gen Scion For This Useful Post:
Ramster (06-02-2014)
Old 06-02-2014, 04:18 PM   #13
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
not sure your definition of "replacing everything" but here is a almost 700hp fa20 got all new internals though. stock transmission!
http://www.ft86club.com/forums/showthread.php?t=65873
G-Man is offline   Reply With Quote
Old 06-02-2014, 04:39 PM   #14
Ghost147
That's pretty ridiculous!
Dynosty Turbo FR-S FA20 Highest Horsepower Record 324WHP Hal@Dynosty Forced Induction 363 11-19-2014 11:03 AM
Re-fueling Timing and Amount Chad86 Scion FR-S / Toyota 86 GT86 General Forum 26 03-15-2014 03:03 PM
Ohlins R&T max amount of low (front)? OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-06-2013 07:28 PM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-14-2013 12:46 AM
