Old 05-29-2014, 11:45 AM   #225
steveoexige
Drives: UK GT86 in White with alcantara
will do - cheers.
steveoexige is offline   Reply With Quote
Old 05-29-2014, 11:55 AM   #226
nelsmar
Originally Posted by JDLAutoDesign View Post
Results of the base turbo on 91oct. Ill let @nelsmar go into detail
I just found out apparently this guy has a stock overpipe, stock front pipe, modified midpipe with a muffler delete. So basically a stock exhaust and no muffler. I am quite surprised it pushed 280HP through that little over pipe... I can only imagine how much more I could have pushed and how much faster the spool would be with a real exhaust!
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
sosick (04-21-2015)
Old 05-29-2014, 12:09 PM   #227
nelsmar
Originally Posted by dwx View Post
Maybe a basic question but what are you guys using for the vacuum/pressure source for the EWG/BOV? I was planning on using the manifold somewhere for the BOV but I hear mixed things about using the manifold vs. the compressor cover for the EWG. I've used the compressor cover in the past but this time around I'd have to drill/tap it and some say use the manifold instead. But then some EWGs do not like seeing vacuum at all on the bottom port...
I have all of mine plumbed to the brake booster. I will be swappingeveeytuuhf wastegate related to te compressor as it has higher pressure when using a 3-4port boost controller to help keep the wastegate shut. You can also use a line for the Evap solenoid under the manifold as a vacuum source for the bov which I wish I would have done as mine is no longer used and it looks much cleaner that way!
Old 05-29-2014, 12:19 PM   #228
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Originally Posted by Ryan P View Post
After dealing with that ass hat I didn't trust the fuel pump or injectors he sent me... they now rest in a box in my closet. I ditched what few parts I actually did receive except the turbo and wastegate, regrettably the turbosmart BOV does not work with the Tial BOV flange. That was my fault for not asking JDL first. Good luck though
If its the new version of the Race Port its said to fit.
JDLAutoDesign is offline   Reply With Quote
Old 05-29-2014, 12:27 PM   #229
JDLAutoDesign
Drives: 13 FRS
Tial recommends a pre throttle body source. Most of the kits until recently have been with Precision turbos. If we start getting more GT/GTX equipped kits we may offer that service for Garret turbos here.
Tials instal guide
http://www.tialsport.com/documents/MV-Install-Guide.jpg
Old 05-29-2014, 12:29 PM   #230
MAPerformance
Drives: Asphalt FRS
Originally Posted by steveoexige View Post
Failing me getting any info on the FA20Club injectors can anyone recommend a suitable injector that is plug and play? I was thinking about the ID725's from full blown but dont know if they'll need some custom wiring.
We also have FIC 770 High Z injectors with plug and play harnesses.
MAPerformance is offline   Reply With Quote
Old 05-29-2014, 12:35 PM   #231
Ryan P
Just to clairfy the ass hat in question was FA20club. The WG fit, as you informed me. I never asked about the BOV as I saw they both were the same size BOV. There lip that holds the o-ring wouldn't fit, again that was 100% my fault for assuming it would fit. NOT JDL's
Ryan P is offline   Reply With Quote
The Following User Says Thank You to Ryan P For This Useful Post:
JDLAutoDesign (05-29-2014)
Old 05-30-2014, 12:26 PM   #232
xwd
Tials instal guide
I have a couple of those "quick tap" fittings I used with my old WRX setup to measure the IC pressure differential. Is there any room between the IC to TB pipe and the TB to put one of those fittings in there?
Otherwise I'll probably just end up putting a fitting in the compressor housing.
Got my coolant fittings and lines yesterday, thanks for the quick turnaround! Those are some beefy coolant lines, a lot more stout than the heater hose I was going to use. I'm assuming by the lengths and lack of additional fittings these are meant to replace the throttle body lines?
Old 05-30-2014, 12:52 PM   #233
JDLAutoDesign
Drives: 13 FRS
The quick taps for silicone? If so the silicone off the turbo outlet would be a better place.
I did @nelsmar coolant lines from the TB coolant hoses. I ran the TB outlet to the turbo coolant inlet and the turbo outlet back to where the TB hose would go back into the coolant system. I tried to make them as discreet as possible
Nelsmars
Another local car that UMS did the install and tune on
Old 05-31-2014, 09:04 PM   #234
kingkai23
Drives: 13 swp limited
How did u guys secure the coolant overflow? Im in middle of install ..i didnt wanna hack up my oem shroud
kingkai23 is offline   Reply With Quote
Old 06-01-2014, 02:13 PM   #235
nelsmar
I zip tied it to the chasis.
Old 06-05-2014, 12:54 PM   #236
steveoexige
Blanket on:
and just for fun:
[ame="https://www.youtube.com/watch?v=U-uAgNFcVQU"]https://www.youtube.com/watch?v=U-uAgNFcVQU[/ame]
Old 06-05-2014, 04:08 PM   #237
sw20kosh
Drives: 2013 Black FR-S
So 320 whp dynojet on AZ91 oct?
Old 06-05-2014, 04:12 PM   #238
FR-S Matt
I think you need a larger turbo, @nelsmar
Glad to see you back up and running bud.
MAPerformance turbo kit thread! MAPerformance Forced Induction 277 02-14-2023 02:49 PM
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 03:55 PM
All TURBO kits compilation thread subatoy Forced Induction 112 04-10-2015 09:14 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
Synack Turbo Drift/Drag/Road Thread Synack Tracking / Autocross / HPDE / Drifting 5 09-20-2012 01:20 AM
