Old 05-29-2014, 02:28 AM   #29
racecat
racecat's Avatar
Drives: Hot Lava FR-S MT
Originally Posted by Jyn View Post
silent as a cat shitting.
Borrowing this for use in everyday life. Thank you.
racecat is offline   Reply With Quote
Old 05-29-2014, 02:29 AM   #30
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Originally Posted by Tromatic View Post
Upshit into at least fourth. Rattle will stop.
Familiar with downshitting. Upshitting...not so much.
Sport-Tech is offline   Reply With Quote
Old 05-29-2014, 03:34 AM   #31
paulca
Drives: Toyota GT86 Coupe Red (UK)
Ball bearings in a washing machine sounds to me like an exhaust heat shield rattling.
paulca is offline   Reply With Quote
Old 05-29-2014, 03:49 AM   #32
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
.............. don't ppl usually just let it coast in neutral between 5-15 miles if u are not accelerating??
I mean.... for real......? Think about it?
Old 05-29-2014, 04:03 AM   #33
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
If your in second gear and anywhere lower than 3mph in gear it will rattle. If your on third gear anything lower than 14mph and in gear it will rattle.
Vincenttam is offline   Reply With Quote
Old 05-29-2014, 05:25 AM   #34
paulca
The gravity of the situation might make it a little messy.
Old 05-29-2014, 05:33 AM   #35
serialk11r
Drives: '06 AM V8V Coupe
Pretty sure it's the clutch springs lol, most manual cars I've seen do it. Engines don't have to be over 2000rpm, there are turbo cars these days that get on the boost below 1500rpm, and cruise at 1000.
That said, if you insist on rolling through stop signs like that, you might want to try...you know, that next gear down?
Old 05-29-2014, 06:04 AM   #36
Shagaliscious
Drives: Firestorm FR-S (MT)
But if I go into 1st gear i'll basically have to stop. I'll lose that .00001 second that I would've saved by staying in 2nd gear.
Old 05-29-2014, 06:20 AM   #37
paulca
Clutch control. If you are going to labor the engine, slip the clutch. In 1st gear when moving slowly, slip the clutch slightly so that it still pulls, but if you blip the throttle the revs rise on the clutch slip. This prevents the lurching as there isn't enough grip on the clutch to lurch the weight of the car. If you are in 2nd and a little slow, but don't think it's worth going to 1st, then just slip the clutch in 2nd and rev it a little, wait for it to accelerate a little, then engage the clutch fully.
And... there is NOTHING wrong with going from 2nd to 1st while rolling. You just have to be good on the clutch and/or rev match.
Old 05-29-2014, 07:25 AM   #38
stock
stock's Avatar
Drives: 2015 FRS Steel (manual)
You should trade the car now and buy that Buick you've been eyeing.
stock is offline   Reply With Quote
Old 05-29-2014, 07:29 AM   #39
jeffsquared
Drives: 2013 FR-S 10 Series #1186
Yes this gearbox and/or clutch/flywheel are noisy, the appropriate threads are linked in the issues forum sticky.
sent via mobile.
jeffsquared is offline   Reply With Quote
Old 05-29-2014, 07:57 AM   #40
WNDSRFR
Drives: FR-S,GTI
Trade it in for an automatic because you obviously don't know how to drive a standard.
A car with as little torque as this one is not designed to be driven below 2k RPM.
Old 05-29-2014, 08:25 AM   #41
paulca
I am proud to say I have never driven an automatic in my life. (If you exclude a CVT transmission motorbike).
Old 05-29-2014, 08:43 AM   #42
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by johnnyfast11 View Post
when the rpm gets too low you can press on the gas to fix it.
i swear this forum...
Stay far far away from the facebook group... seriously, it gets worse.
Rattle above 5k rpm trippinbillies40 Issues | Warranty | Recalls / TSB 1 05-28-2014 02:55 PM
AC Rattle AVodka14 Issues | Warranty | Recalls / TSB 8 05-21-2014 12:08 PM
Anybody Have this Buzz/Rattle? Gary in NJ BRZ First-Gen (2012+) — General Topics 8 10-07-2013 12:36 PM
OEM Audio+ Amp Rattle? husker741 Electronics | Audio | NAV | Infotainment 1 06-17-2013 04:52 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
