Old 05-28-2014, 03:27 AM   #1807
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by Td-d View Post
Only one correction, the OFT also has custom code - launch control and FFS is not OEM.
Ah. I thought those were more a matter of clever settings.
Old 05-28-2014, 03:29 AM   #1808
EAGLE5
Dismember
EAGLE5's Avatar
Originally Posted by Kids Heart View Post
But has anyone so far?
i bet vishnu tuning can set you up. they already managed it with the vortech. may as well get the whole setup from them since you have the oft already. As far as I can tell, the only actually bad setup is fa20club.
Old 05-28-2014, 06:30 AM   #1809
Vash
Drives: Whiteout FR-S
Originally Posted by DC2R View Post
93? Is this only for bpb tune?
Can't wait for 93 tune and open flash header to arrive. Also would like lc support for my ROM version
Sent from my SM-G900T using Tapatalk
Yes, I downloaded the beta files for BPB.
Vash is offline   Reply With Quote
Old 05-28-2014, 08:34 AM   #1810
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
What, you don't like running ~stoich under full boost?
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Td-d (05-28-2014)
Old 05-28-2014, 08:48 AM   #1811
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
So I think I know the answer to this question from sporadic reading of this thread but I'll ask it here anyway in hopes one of you wonderful smart people will confirm...I have an OFT coming later this week. Do I need to have my dealer flash my (Aug 2013 build-date) 2014 to whatever the latest USDM ROM is before I install the OFT, or does the OFT not care? I believe the answer is, it doesn't care. Thanks!
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 05-28-2014, 09:06 AM   #1812
steve99
Drives: FT86
OFT will marry up to whatever rom is in car. If you do go back to dealer flash back to stock then you can marry up to any new rom the dealer flashes.
phobos512 (05-28-2014)
Old 05-28-2014, 11:35 AM   #1813
phobos512
phobos512's Avatar
Ok perfect that is what I thought. Thanks!
Old 05-28-2014, 02:57 PM   #1814
EAGLE5
Dismember
EAGLE5's Avatar
Full boost? It's much better to run lean, ya know.
Old 05-28-2014, 03:31 PM   #1815
Luckrider
Luckrider's Avatar
It was a joke referencing @nelsmar's FA20club supercharger experience.
Old 05-28-2014, 04:20 PM   #1816
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Can't wait for 93 tune and open flash header to arrive...
I want to use the 93 tune with it comes out, but I wonder about the quality of our (local) 93. What should I look for in the log (eg. afr?, knock correction?) to make sure our gas is compatibale with the 93 tune?
Target70 is offline   Reply With Quote
Old 05-28-2014, 04:41 PM   #1817
steve99
Drives: FT86
Check AFR at WOT above 5500rpm is no leaner than about 12 (assuming your N/A) most people would say tune for 12.5 or 12.7 but these motors tend to knock any leaner at higher rpm. arroud 11.8-12 is shiv's target for N/A on petrol maybe 12.2 on E85
If your IAM stays at 1 its a good start
Then check for knock both flkc and fbkc, you may have to put up with max of about -0.7 occasionally in 2000-3500 rpm area but outside that rpm range should be clear of knock.
see here http://www.ft86club.com/forums/showthread.php?t=61820
Target70 (05-28-2014)
Old 05-28-2014, 05:15 PM   #1818
EAGLE5
Dismember
EAGLE5's Avatar
I didn't know which bad tune you meant, but I expected it was from FA20Club. That's why I joked about running lean under boost. Poor Nelsmar, on his second engine. At least he didn't get FA20Club to rebuild his engine. Imagine what a nightmare that would be. It would probably take a year and be done pitifully wrong, or something. Naaaah! Nobody would make that mistake, would they?
Old 05-28-2014, 07:07 PM   #1819
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Is it normal for AFRs to be hitting up to 20?
Been seeing it on the stage 1 as well as the stage 2 UEL tunes. I'm on 92 octane.
http://datazap.me/u/andrew025/stage-2-uel
http://datazap.me/u/andrew025/4-12-2...8?log=0&data=1
Old 05-28-2014, 07:14 PM   #1820
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
you should only see 20's under deceleration, not partial or wide open throttle
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
The Following 2 Users Say Thank You to Danklvr For This Useful Post:
Andrew025 (05-30-2014), Luckrider (05-28-2014)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
