go_a_way1
Old 05-27-2014, 03:26 PM   #491
spitz
spitz's Avatar
Drives: '13 SWP BRZ-L
Originally Posted by Casey10s View Post
With this kit, should I get the installer to install clamps on the vacuum lines as mentioned on some of the other threads?
I agree with Mike above.
Also, only one of the clamps is in line with the install (rear PCV hose near the transmission), so it really isn't a 'do it while you are at it' kinda thing. So unless you have a super nice installer, it probably will be billed extra time. That being said, it shouldn't be more than 30 minute job by a professional, probably less.
spitz is offline   Reply With Quote
Old 05-27-2014, 06:27 PM   #492
4032pauln
Drives: lexus
I would definitely clamp it, mine always pops out. Been too lazy to clamp it
4032pauln is offline   Reply With Quote
Old 05-27-2014, 07:56 PM   #493
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
Thanks, I will tell them to take care of it. I should be getting it installed later this week or probably next week.
Casey10s is offline   Reply With Quote
Old 05-27-2014, 08:30 PM   #494
kasikuusi
kasikuusi's Avatar
Drives: 2014 FRS
Installed my kit this weekend.
Ah-freaking-mazing. It's everything advertised and more. It is, in my opinion, now the perfect DD / Track weapon.
Only small issue I had with the install, as previously stated by other owners, was bumper fitment. The pipes needed some man power to get into place, but this wasn't a big deal at all. Also, if Jackson Racing wanted to make this install completely brainless, they could create a installation guide with BOTH the oil cooler kit and SC kit steps combined. I had to flip back and forth between both kits, but just a suggestion more than a complaint. Install went very smooth.
I had mine installed yesterday. And this little cricket is a beast now. What spitz said above. My install was was flawless tough. I even let Mike have a lunch brake😬. 8.5hrs between the time the counter space garage door opened and I drove out. We also did camber bolts, front rotors, brake pads all around and stainless steel brake lines. Thanks Mike and David.
kasikuusi is offline   Reply With Quote
The Following 4 Users Say Thank You to kasikuusi For This Useful Post:
CSG David (05-27-2014), CSG Mike (05-27-2014), CxG (04-03-2018), JonAvalon (05-27-2014)
Old 05-27-2014, 09:21 PM   #495
doberman8u
Drives: 2013 FR-S, 2004 Z06
@kasikuusi what brake pads did you go with?
doberman8u is offline   Reply With Quote
Old 05-27-2014, 10:22 PM   #496
CSG Mike
CSG Mike's Avatar
Project Mu Club Racer
Old 05-27-2014, 10:22 PM   #497
kasikuusi
kasikuusi's Avatar
Drives: 2014 FRS
Mu club racer pads.
Old 05-28-2014, 03:29 AM   #498
1086
1086's Avatar
Drives: UM86 - 6MT
@CSG David or @CSG Mike I have an OpenFlash Tablet. Is it possible to get the TIY kit initially and run it with the OFT? And then later on down the road I can upgrade to Ecutek?
1086 is offline   Reply With Quote
Old 05-28-2014, 03:31 AM   #499
gbrz
im trying to load the CARB tune and EcuTek tells me that:
a standard tuner license is NOT present in this ECU. Programming will consume a flash license. What am I doing wrong?
gbrz is offline   Reply With Quote
Old 05-28-2014, 03:42 AM   #500
CSG David
CSG David's Avatar
Go into EcuTek and check for updates or licenses. It'll ping EcuTek and then ping you back saying your program is connected or whatever. You should be able to load the tune in from there.
The Following User Says Thank You to CSG David For This Useful Post:
gbrz (05-28-2014)
Old 05-28-2014, 03:45 AM   #501
CSG Mike
CSG Mike's Avatar
That is normal. You have a license, and you marry that license to your ECU during the programming
Call my cell and I can VNC into your laptop from home and program your car for you if need be.
gbrz (05-28-2014)
Old 05-28-2014, 03:47 AM   #502
gbrz
Got it too work. Thanks
The Following User Says Thank You to gbrz For This Useful Post:
CSG Mike (05-28-2014)
Old 05-28-2014, 03:49 AM   #503
CSG Mike
CSG Mike's Avatar
Damn, that's at least 5 installs that I know of that happened this weekend...
*LongFella (05-28-2014)
Old 05-28-2014, 03:58 AM   #504
gbrz
Oil. Oil everywhere
Must not have tightened... ugh to take off the dam bumper and reinstall again
driftguy (04-14-2015)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
