#183 |
Hey @pmccut and @gdrider77, how is the Exedy Stage 1 clutch holding up? Curious about your long term impressions, have been thinking about buying one for my SC install in a couple weeks
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#184 |
Drives: Blue Subarus
No problems so far. Probably only at 250wtq right now though. Still the easiest and most ddable clutch.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1 |
#185 | |
I Love custom Turbo kits
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | alpine (05-27-2014) |
#186 |
Drives: 2015 CWP BRZ
On my old wrx i was using the act heavy duty street clutch held 400wtq just fine and i put over 100 drag passes on it with no problems at all its a nice compromise for street and race not overly stiff and not to noisy
Sent from my SCH-I545 using Tapatalk |
#187 |
King of Kiwi Palace
Drives: Faster than you
FX400 with 4 puck.
Quite a bit of chatter, can be fixed by raising idle speed in EcuTEK to 1,000. The clutch holds power very well. Everyday driving is kinda poor though. What helped was a one-piece driveshaft and rear diff brace/bushing.
#188 |
Drives: 2013 SWP BRZ
ugh I want the Exedy but worried about holding power over time...Limited to probably 250-260wtq at most on my setup.
My stock clutch is slipping bad right now...between Exedy and probably the ACT Street. Exedy long time users please chime in. |
#189 |
Junior
Drives: a car
Would an FX400 with an 8 puck chatter a little less or a lot less?
#190 |
Couldn't tell ya on the 8 puck but my 6 is annoying with the ac on at idle or on decel in 5th over 35mph
The Frozen North
#191 |
Junior
Drives: a car
I wonder if it's really worth spending the extra money for the exedy twin disc for better DD ability.
I just found something interesting on clutch masters website, seems there is an option for a full faces fx400 and a puck style 400...wat
#192 |
Not what you think
Drives: 718 GTS 4.0
| The Following User Says Thank You to alpine For This Useful Post: | Sportsguy83 (05-27-2014) |
#193 |
King of Kiwi Palace
The next 1800 I spend will be exedy
| The Following User Says Thank You to Ironsquid For This Useful Post: | Sportsguy83 (05-27-2014) |
#194 |
Junior
Drives: a car
The clutchmasters 725 series TD is $300 cheaper, I'd love to see a compairison between those two.
#195 |
Drives: Limited BRZ
Whomever has an FX400 and wants less chatter and better drivability, I have the FX350 disc for sale and it uses all components from the FX400 (meaning it will bolt right up to the FX 400 P.P. and FW ), except is full face and DD friendlier.
#196 |
I will never put a puck clutch in a DD. They are a PITA.
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
