Old 05-24-2014, 06:33 AM   #183
SPCorBUST
SPCorBUST's Avatar
Hey @pmccut and @gdrider77, how is the Exedy Stage 1 clutch holding up? Curious about your long term impressions, have been thinking about buying one for my SC install in a couple weeks
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 05-26-2014, 02:47 AM   #184
pmccut
Drives: Blue Subarus
No problems so far. Probably only at 250wtq right now though. Still the easiest and most ddable clutch.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
The Following 2 Users Say Thank You to pmccut For This Useful Post:
alpine (05-27-2014), Khyron686 (06-20-2014)
Old 05-27-2014, 10:08 AM   #185
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@alpine
The Following User Says Thank You to Sportsguy83 For This Useful Post:
alpine (05-27-2014)
Old 05-27-2014, 10:14 AM   #186
Redrex26
Drives: 2015 CWP BRZ
On my old wrx i was using the act heavy duty street clutch held 400wtq just fine and i put over 100 drag passes on it with no problems at all its a nice compromise for street and race not overly stiff and not to noisy
Sent from my SCH-I545 using Tapatalk
Redrex26 is offline   Reply With Quote
Old 05-27-2014, 11:37 AM   #187
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
FX400 with 4 puck.
Quite a bit of chatter, can be fixed by raising idle speed in EcuTEK to 1,000. The clutch holds power very well.
Everyday driving is kinda poor though. What helped was a one-piece driveshaft and rear diff brace/bushing.
Ironsquid is offline   Reply With Quote
Old 05-27-2014, 01:11 PM   #188
xxscaxx
Drives: 2013 SWP BRZ
ugh I want the Exedy but worried about holding power over time...Limited to probably 250-260wtq at most on my setup.
My stock clutch is slipping bad right now...between Exedy and probably the ACT Street.
Exedy long time users please chime in.
xxscaxx is offline   Reply With Quote
Old 05-27-2014, 01:56 PM   #189
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Ironsquid View Post
FX400 with 4 puck.
Would an FX400 with an 8 puck chatter a little less or a lot less?
Old 05-27-2014, 02:11 PM   #190
Dipstik-sportech
Dipstik-sportech's Avatar
Couldn't tell ya on the 8 puck but my 6 is annoying with the ac on at idle or on decel in 5th over 35mph
The Frozen North
Old 05-27-2014, 02:23 PM   #191
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I wonder if it's really worth spending the extra money for the exedy twin disc for better DD ability.
I just found something interesting on clutch masters website, seems there is an option for a full faces fx400 and a puck style 400...wat
Old 05-27-2014, 02:28 PM   #192
alpine
Not what you think
alpine's Avatar
Drives: 718 GTS 4.0
Thats great news! I'll be ordering mine soon
alpine is offline   Reply With Quote
The Following User Says Thank You to alpine For This Useful Post:
Sportsguy83 (05-27-2014)
Old 05-27-2014, 02:34 PM   #193
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
The next 1800 I spend will be exedy
The Following User Says Thank You to Ironsquid For This Useful Post:
Old 05-27-2014, 02:36 PM   #194
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The clutchmasters 725 series TD is $300 cheaper, I'd love to see a compairison between those two.
Old 05-27-2014, 02:39 PM   #195
Sportsguy83
Drives: Limited BRZ
Whomever has an FX400 and wants less chatter and better drivability, I have the FX350 disc for sale and it uses all components from the FX400 (meaning it will bolt right up to the FX 400 P.P. and FW ), except is full face and DD friendlier.
Old 05-27-2014, 02:49 PM   #196
xxscaxx
I will never put a puck clutch in a DD. They are a PITA.
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 01:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
